Question about Dell Dimension 3000 PC Desktop
I changed the CPU fan on Dell dimension 3000 but it does not run.
It gives an error message: "Previous Fan Failure". I changed the settings in bios to : do not report" on keyborad but the fan still did not start though the error message is not coming anymore. Compuer shutts off automatically in 15 min. It seems the problem is with motherboard poer to fan.Anyone can suggest a solution to this problem. Thank You
    President:
  • 1,179 Answers
Dell uses a proprietary fan on it's cpu's. This is more than likely your problem. The motherboard does not recognize the new fan and the motherboard is not powering it on. Without replacing the motherboard you are stuck using dell replacement parts for this model. The motherboard & psu are also proprietary in this model so it would take a whole lot of modification to use anything but Dell replacement parts. Your pc is shutting down due to overheating. Sorry. Hope this helps.
Posted on Jul 12, 2009
Dell dimension 2400 freezes up shortly after boot. I replaced cooling fan but error log shows keyboard failure.
if you see lights get on Keyboard.. your motherboard is fine.. else it is your Keyboard or Super I/o Chip that is not working..
Mar 27, 2013 | Dell Dimension 2400 PC Desktop
Cpu fan stopped working on dell dimension e310
Did you accidentally knock the fans little power plug out of its connection to the motherboard?
May 17, 2012 | Dell Dimension E310 PC Desktop
Help -- CPU Fan Failure bypass or pinout?
Yep I have a link below you can order the correct fan from.
http://store.cwc-group.com/y4574.html
I had the same issue here, we have 20 offices all running Dells. These fans seem to be used only on dell systems.
Feb 23, 2012 | Dell Dimension E310 PC Desktop
Dell Dimension 8250 ,FAN TOO FAST & Noisy but CPU COOL...
The fan settings can be found in the BIOS. On a Dell machine, when you turn the computer on repeatedly hit F2 until you are brought to the BIOS. Search through there until you find something named Acoustics, change the option to run at a lower level. Remember to save the changes before you exit.
Jan 26, 2010 | Dell Dimension 8250 PC Desktop
Dell dimension 2350 cpu fan failure
i can help with the mouse & keyboard.
go into the bios on boot screen you press DEL i think then activate the USB mouse & keyboard option then save & exit.
there will be settings for the cpu fan in there somewhere but i can't remember where sorry.
Aug 16, 2009 | Dell Dimension 2350 PC Desktop
Alert chipset heat sink not detected system halted error message
It is NOT the CPU fan! There is a heatsink over the northbridge chipset adjacent to the CPU. The clip that supplies pressure to maintain contact between the northbridge and the heatsink has detached on one or both ends. There are wire loops at each end of the clip which feed into the motherboard. When the clip detaches (solder failure), it pops the loop out of the motherboard. The BIOS recognizes this condition as a heatsink failure, hence the error message.
Jul 10, 2009 | Dell Dimension 4600C PC Desktop
[Ithr]checkpoint failure dell 8400 dimension
What can cause this error?
Well, this is the problem since quite a variety of problems can trigger the error.
1: the bios can be malfunctioning (a bios reset or flash can give a solution)
2: the cpu can be malfunctioning (this requires a new cpu)
3: the cpu socket can be failing (this requires a new mb)
4: the problem can be with bad usb sockets
5: even a bad uplink to a usb hub can cause this error to appear.
Did you change your monitor lately? I would chase down the USB things first...that and the monitor seem to trip the trigger...
Hope this get you started- I think you were right on target with the flash of the BIOS-try it again using the BIOS flash downloaded from the dell site...and to run the chipset again...it just might
Good luck my friend, hope this helps, please leave rating, thank you kindly
Apr 27, 2009 | Dell Dimension 8400 PC Desktop
Dell Dimension 3000 CPU Fan does not run
I agree with both of you. As long as you are not experiencing any heat event (shutting down and rebooting) just ignore the error message. If the fan is on and running at a fair speed, you shouldn't have and problems.
Now should you start to have heat problems, don't boot the computer until you have a larger CPU fan in place...and too you may be able to add an additional fan to the system for reassurance. the added noise is worth the security of not having a CPU meltdown.
Those large 120 are very quiet and move air, if you can find a place to hang it.
Good luck, hope this helps. please leave rating -thank you kindly
Apr 20, 2009 | Dell Dimension 3000 PC Desktop
CPU cooling fan
Hi...you can press the F2 key to enter setup...and scroll down until the fan is highlited...hit enter and then F10 to save and exit.This tells the computer its OK.
you should have plugged the fan in the same pin port the old fan was in. Usually only 1,.
If the new fan is not from dell..it may be faster and noiser..or it may be faulty..if you bought it locally you may try to return it.
The purpose of the fan of course is to remove the hot air from the CPU to keep it from overheating. If this fan does it it is most likely ok.
Hope this helps..
Squipps
Feb 07, 2008 | Dell Dimension 8200 PC Desktop
CPU fan not detected.....
The cpu fan has a three wire connector that connects to the mother board. Usually located to the right & up from the cpu. If yours is connected currently the wires may be miss aligned. From left to right the pins are: first pin ground/Black; middle pin 12v./Red & last pin rotation/Blue. There may be a bios update that address this issue. Dell does not give up information easly.
Jan 13, 2008 | Dell Dimension 2350 PC Desktop
Dell Dimension 3000 PC Desktop Logo
392 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
