Question about Dometic Rooftop RV Air Conditioner
Compressor makes noise, but fans won't run
I have a duo therm model 57915.531. I've used the fans often, and the a/c rarely.
The fans won't run, but a humming sound is coming from the compressor. I've checked the fuses.
This sounds like the same part is needed. Does that sound right?
I'm getting ready to camp for the month of August, and would love expert help.
  • Dometic Master
  • 6,674 Answers
I'm guessing the hum you hear is the fan motor. After sitting for a time, I've had many that develop like a dead spot in the fan motor. Here's what to try. Shut power off to AC. Get someone up on the roof with about a 2 ft.,long fairly strong stick, or rod , about 1/4 inch or so in diameter. Have them carefully poke it through the openings in the cover and spin the fan blades at the back end of it. May be a little stiff at first, so don't break blades on fan, but get stick under one & lift to spin it, or over it & push it downward. Spin it 2 or 3 times all the way around. Turn power back on. Now stand back & try fan mode again. 99% of the time that will do it, but if not, take screws off around cover on roof & remove cover & give fan a bunch of good spins by hand, then turn power back on & try it. Keep me posted on results please ?
Posted on Jul 12, 2009
    Champion:
  • 233 Answers
Usually the humming sound from a compressor is followed by a breaker tripping or a fuse blowing, it is usually an indictor of a larger problem. If it is not tripping the fuses/breaker you may need to replace the start components (relay, start capacitor) if so equipped, if not equipped you may need to look into installing a solid state start assist, you will need to know the tonnage of your unit, and any HVAC parts house or appliance repair house should carry a generic start assist.
3 Suggested Answers
carlsbiz
  • 1124 Answers
SOURCE: i have a duo therm brisk air model 57915-001 leak
Could be the drain path is clogged.. Take the cover off & see if you can get it cleaned..
Posted on Jul 09, 2009
motor1258
  • 6674 Answers
SOURCE: duo therm mod. 57915 air conditioner seems to
Unit may pull as much as 17-18amps when compressor starts up, but level out to 12-15 amps when up and running. Keeping in mind that is all relative to proper 120v incoming voltage, heavy enough wire to run the application etc. If your AC unit needs cleaning , it may draw an extra amp or 2 . With that said, when your at the park, first thing I'd question is their incoming voltage to RV, and try running fridge etc and anything else on propane if possible. The AC alone should not cause 30amp at source breaker to trip, before 15 0r 20 amp breaker in RV that is connected to AC trips. If it doesn't trip your breaker at home, and all is connected same at park, then I certainly would suspect bad breaker or voltage/wiring at park is the cause. P.S. I noticed you said you have 12 gauge wire (rated at 20 amps) connected to a 20amp breaker at panel, but RV is plugged in to a 15amp receptacle, I will assume with a 15 amp adapter from 30 amp plug. Do you see any hazard regarding 15 amp rating on receptacle? ( just a little advice.)
Posted on Oct 09, 2011
Domestic duo therm gets 20volts everywhere I checked. I have yet to check the switch on top of the compressor. Neither fan nor compressor turn on or make noise. Get 120 at breakers.
If you don't have 120 volts at the power connections at the unit, you have an open fuse or wire someplace between the breaker and the unit.
Jun 24, 2014 | Heating & Cooling
Loud Noise
Check if noise comes from compressor or from the unit . If it is from the unit is probably a fan bearing in need of replacement.
Check last pages of your manuals for service repair phone number.
Aug 02, 2008 | Dometic Rooftop RV Air Conditioner
Duo therm fan or compressor do not run
check circuit breaker or bad relay module.
Aug 28, 2012 | Dometic Rooftop RV Air Conditioner
Duo-Therm BRISKAIR on rooftop of houseboat runs, not putting out cold air. Also, fan doesn't seem to be running at top speed
Sometimes a weak capacitor will make a motor run slower so I would check that first. Also make sure the compressor is running. Let me know what you find. You may need to get the refrigerant charge checked too. By the way it may use the same capacitor for the fan and compressor.
May 26, 2010 | Dometic Rooftop RV Air Conditioner
Replacement Fan Motor
Try Johnstonesupply.com. Use the information you provided above.
May 06, 2010 | Dometic Rooftop RV Air Conditioner
Duo Therm Fan Blows, No cool air. Worked yesterday, not today?
most likely compressor running could be capacitor, breaker,relay,or compressor it self start by checking power to unit
Aug 22, 2009 | Heating & Cooling
Duo Therm compressor tries to start and kicks out
I don't think these little units have a start capacitor but what I would do is check that the on/off switch wires to make sure they aren't loose. Also check the wires to the compressor for loose wires as well. It is possible that these are the first signs that the compressor is about to fail. They also can act up some when they haven't been used for awhile and then you try and start them up. Try running the unit for a few hours without asking it to cycle. It might just be a sticky valve.
Apr 13, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
547 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
