Question about Honda Quincy 17 - Gallon Air Compressor with 5.5 Hp - G15H17PC3B
Honda 5.5 GX160 ran then wouldnt start again
I have a honda compressor that had spark after i disconnected the oil sensor it started and ran for awhile then i shut it off and now i have no spark i checked the kill switch wire and its good and i let the engine sit for awhile and it fired back up????
  • 98 Answers
Could be a bad coil or plug
Posted on Jul 21, 2009
  • 26 Answers
Machineries with oil level sensors tends to give you problem as the float inside would stuck after times...
just disconnect the yellow wire,the one connected to the sensors,and please check your oil level manually before each start..
i had found so many of them having this kind of problem...
Posted on Aug 22, 2009
Where is oil sensor on honda gx160 5.5
The low oil sensor is on the front of the block the wires are attached to ur start stop switch. It has two wires yellow and black on most models. the sensor itself is internal
Dec 11, 2012 | Honda Quincy 17 - Gallon Air Compressor...
Why does my honda gx160 start and run for minute or two then cut off. Will restart
Hi, check the oil level. If low the oil guardian is cutting the spark. Regards Phil.
Aug 19, 2012 | 5.5 HP GX160 Engine
My honda 5.5 gx160 generator wont start
Is the ignition switch turned to "ON" . Is it full of oil?
Apr 23, 2012 | Honda Horizontal Engine 5.5 HP OHV 12V ES...
I have a honda gx160 5.5 generator will not start with the, i believe oil sensor plugged into the turn off switch oil level ok will i need to change the sensor also is this a big job.
i have never bothered to change onebecause you need to strip the motor,that is not realy such a big job if you have done a few ,but you just need to check the oil when you fill the gas tank , thatis simple enough . the oil alert is realy a gimmick for the dummies, it only takes 10 secs. to chech the oil manually
Dec 31, 2009 | Honda Quincy 17 - Gallon Air Compressor...
I have a honda gx 160 5.5 pressure washer. It's hard to start
do a full service on it , new spark plug /air filter foam , full oil change , also chane the oil in the pump end , carefully remove the carb bowl and remove any dirt/rust/water etc
ive seen gx160 engines last 10 years no problem and those were hire machines
hope this helps if it does please vote
Nov 13, 2009 | Computers & Internet
I have a Honda GX160 5.5hp that will not start
Hi,I have an Ingersol compressor with a Honda 5.5 and found they have a low oil shut off switch.Make sure your oil level is up to normal full.
Oct 06, 2009 | Honda Quincy 17 - Gallon Air Compressor...
Honda GX160 runs fine for 5 minutes then dies like out of fuel.
I would look for the fuel filter. Blow it our. I know you have a new tank of gas, but you might want to empty it out and make sure the clean and put in new. Even with Stabil in the gas you might just have to much condensation in the tank
Sep 07, 2009 | Master Heaters MASTER HONDA POWERED...
Can't start the Honda GX160 5.5 HP Electric motor on my Chore Master 2400psi Pressure Washer. Got gas (checked through feed line), new spark plug, switch on, gas, choke ok, throttle a bit funky (about 12...
Is there an oil sensor unit if it is going bad it tells the engine the oil low and engine wont start. I had same problem with my pressure washer, i just unplugged the sensor unit and it started fine ever since
Apr 27, 2009 | Garden
Honda 5.5 hp air comp. no spark wont run
Most honda engines have an oil sensor that prevents the engine from starting if the oil level is low or oil is dirty. Test coil by disconnecting oil sensor wire. With sensor disconnected coil should fire. If still no fire, check kill wire for short. If still no spark, coil may need to be replaced. enjoy
Nov 28, 2008 | Honda Quincy 17 - Gallon Air Compressor...
Honda Quincy 17 - Gallon  Air Compressor with 5.5 Hp - G15H17PC3B Logo
1,224 people viewed this question
Top Honda Air Tools & Compressors Experts
John Trevino
Renee Knafel-Bullock
Are you a Honda Air Tool and Compressor Expert? Answer questions, earn points and help others
