[PDF]Fault Code Bible v1.2 - ResearchGate
www.researchgate.net/publictopics.PublicPostFileLoader.html...
ResearchGatesimple, clear instructions on how to read the faults or use the diagnostic routines. .....Resetting the error indication does not rectify the fault but only erases from .... E53 Input circuit EMC errors Displayed as error code, washing machine start ... if you choose position 10, 11 or 12, the test will terminate without pressing.
Hi Scott Brown: Typically an error code E38 could mean a few things:
· First see if the air trap is clogged. If it is, that is probably the most likely issue.
· If it is not clogged, it could either be the main control board, the water valve assembly or the pressure sensor switch.
· To make sure it is not a false error code, reset the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds.
If the error code continues to display, I would strongly recommend contacting a professional to make the necessary repairs. Unfortunately, most electronic parts cannot be returned so it is always a good idea to get the appropriate diagnosis prior to making any unnecessary part replacements.
Hi Belinda Smith, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? make and model number
