Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
I have good suction at brush, but no suction in hose connection.
    Scholar:
  • 190 Answers
Please unscrew the hose connection to the back panel. Is there suction there while in the upright locked position? If so, visually check the hose inside for obstructions.
Posted on Oct 03, 2009
I have a Eureka upright bag less model 5857 az. The hose has suction but not for the carpet. Is there a switch that needs to be turned to floor suction? I do not have a manuel.
I'm just guessing here, but have you laid the vacuum down with the underside of its head showing? There is a channel that runs from the brush section to the hose when it's connected correctly to the head. Look for item(s) that may be jammed into that channel. Ensure that the hose is properly attached to the head. If you feel no suction on that underside channel, you have something jammed in it.
Oct 19, 2014 | Eureka Vacuums
Air not getting to hose
I'm not sure which model you have but this is good for Riccar upright vacuums. If the hose has good suction but is not picking up well check the suction tube that is down by the brush roll. The suction tube starts by the brush roll and goes to the back of the vacuum where you put the suction hose into. If it has a clog or restriction the vacuum will not pick up properly.
Mar 12, 2014 | Riccar Vacuums
There is no suction from the bottom base where the roller brush are, but theres a lot of suction from the hose.
Check between the brush and the hose connection. It sounds like there's a blockage there. It can easily be pushed toward the brush using a wooden spoon handle, or similar blunt object.
Mar 07, 2011 | Dirt Devil 12 Amp HEPA Filter Vacuum...
When vacuuming carpet with the electric power brush it will ocassionly , go to zero suction mode and shut off the brush. I have tried to cause it to happen by playing with the joint areas ( handle to tube...
You gave a good start to giving us good information to help you with solving this problem-- But I need a little more information:
It sounds like you have the Electric Motor driven Power nozzle/ Floor attachment-- am I correct? (Not the type that has a little vacuum motor down at the floor attachment-- Not one that depends upon air flowing thru the unit to power the brush, -- am I correct?)
You can control the motor with a switch at the handle-- correct?
So here is the question: - when you say "the electric power brush -- goes to zero suction" -- what tells you that it 'went to zero suction'?-- the little red flag on the vacuum?-- or what?
I am suspecting something might be caught up in the floor wand-- or at the power nozzle itself-- or even in the flexible hose. Do you know how to take the hose off, and place the hand-held end, in the opening in the Miele Vacuum? Can you do that, and clear out the hose first-- and then the hose with the want connected?
If they are all clear-- we may need to open the floor plate on the floor nozzle, and check for something caught in the air passageway--
Tell us more
Mack B
Dec 28, 2010 | Miele Blue Moon Bagged Canister Vacuum
Kenmore progressive 360 vacuum cleaner has low suction
Check the tube that leads down to the brush head for clogging as well as any motor or HEPA filters. If that still shows nothing, take the cover off the brush head (like you're changing the belt) and look for obstructions in there. Usually, if you have low suction on the accessory hose, the problem is with a motor filter, HEPA filter, or a clog where the hose goes into the unit. If you have good suction on the accessory hose but none on the floor, it's usually in the brush head (clog or broken belt) Good luck
Feb 28, 2010 | Kenmore 35912 / 35913 Progressive Upright...
No suction
Feb 28, 2010 | Euro-Pro EP602 Bagless Stick Cyclonic...
The machine will not suction - it will spray and spin the brushes but will not suction - the power is going to the machine, but it will not suction.
Disconnect the suction hose. While running, check the suction port if it works, by putting a piece of paper. If the paper is taken in, then it is oK. Now, check the suction Hose for breaks or opening before the suction head. Breaks or opening breaks the suction power at the suction head. Loose connection between the suction pipe and the suction port also must be check as this will also cause the same
problem. You may need to replace the suction hose
to correct this problem,
Send us the e-mail and your vote if this solves your problem.
Sep 27, 2009 | Eureka Atlantis 2590A Wet/Dry Vacuum
Brush spin,good suction at hose, no suction at
Air passage from back of brush head, through the joint, and up to bag, may be blocked.
Jul 11, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
No suction or very little
Make sure you have a good bag installed in the vacuum and the door is properly in place. Remove the attachment hose from the bag chamber and turn the machine on. You should have good suction coming from the hose inlet. If you don't you have a problem in the bag chamber. Bad bag, door is not on correct, door is defective, dirty secondary filter.
Connect the hose back to the machine and pull the other end out from the bottom, and turn the machine on. You should have good suction there. If you don't you have a clog or hole in the attachment hose and it needs to be unclogged or relplaced.
Reconnect the to the bottom. Flip the mahine upside down. Take the screws out of the bottom plate and remove. Remove the brushroller and belt. Turn the machine on and you should have suction at the inlet coming off the brushhousing. It you don't, then you have a clog in the nozzle hose and it needs to be removed. It will probably be more accessable from the bottom side since that is the way that it entered.
Sometimes a suction problem can be confused with an brush problem. The belts on that machine should be replaced every 6 to 8 months because they will strentch and wear. This is an inexpensive maitainance that will dramatically improve its function. Part Numbers are 38528-035 and 38528-034
Nov 21, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
101 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
