It doesn't start and the display panel shows no matter what key I press a 7 accompanied with a flashing dot. Can't find anything on the manual or in the Google
You have activated the delayed start function. Please read following instruction from user manual.
8. Delayed Start button
Allows the start of the programme to be delayed by a minimum of 1 hour, up to 9 hours. How to set the delayed start When the button is pressed, the number appears in the display (4). Press the button again to select the number of hours by which you wish to delay the programme start, up to a maximum of 9. E.g.: if you have selected number , the wash programme will start in 2 hours' time. To cancel the delayed start set, press the button until the number appears. Close the dishwasher door to start the countdown: a long audible signal (about one second) informs you that the function is active. If you open the door again you will see, in the display (4), how long there is to go (in hours) before the programme starts. A flashing dot in the digital display means that the delayed start function has been activated. Opening the door has no effect on a countdown which has already been started. If, during the countdown, you wish to see the programme number selected in the display, press the Programme Selector button (5). If, after having started the countdown by closing the dishwasher door, you wish to cancel the delayed start, press button (9) (Cancel) for about 2 seconds until the short «instruction accepted «signal is heard».
Dado
SOURCE: Dishwasher won't start, turns on but no display
1: Defective door lock switch
2: Defective electronic control board.
Get model and serial number of machine, enter model number on search engine and seek same like conditions. You should find solution to problem, or place model number here for me to correctly tell what is wrong.
SOURCE: Clean light flashing 7 times. Can't start the machine
For KitchenAid Whirlpool KUDS01FLSS0 -- When the clean light is blinking or flashing 7 times in a row and no other front panel controls will work, do the following:
push SaniRinse-EnergySaverDry- SaniRinse - Energy Saver Dry
(Try the Heated Dry button if you don't have a Energy Saver Dry button)
All the lights will then come on as this will put the unit into diagnostic mode.
Then, push Cancel after about 10 seconds. You are no longer locked out. Run the dishwasher normally.
References:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/d12cd4888abce86285256a42005ea985/3976dc6fea92e1c385256fc4006611c9/$FILE/8178496.pdf
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208557727.pdf
Dear Dado, Thank you very much, that was the problem, the kids did it :-)
