Question about KitchenAid Dishwashers
THE WATER PUMP IS WORKING BUT IT WONT PUMP THE WATER INTO THE DISHWASHER
Does this always happen? If it's always ben a problem, check the outlet hose to see if waste water is siphoning back into the dishwasher. This happened to me. I just moved the hose under the sink into a loop with the top of the loop ABOVE the drain connector. Think upside down U !! Some newer installations use an air gap device to prevent siphoning; this is usually visible on the counter near the sink. If this gadget gets clogged up for some reason, the anti-siphon function may fail.
Posted on Jul 12, 2009
Dishwasher has water in the bottom
check and be sure you don't have something stuck in the water pump for the drain or else the pump maybe bad and needs replacement. In addition, be sure the pump belt or motor is driving the pump.
Dec 26, 2015 | Frigidaire Dishwashers
Machine won't pump out last water after cycle.
Does not drain the water at the end of cycle - Dishwasher ...
https://www.ifixit.com/.../Does+not+drain+the+water+at+the+end+o...
iFixitThe dishes seem clean, but the water from the last cycle remains in after it has stopped. ..... noticable cracking noise when the machine was triying to drain the water.... to purchase a timer unnecessarily and they usually won't take them back.
Checking a Drain and Circulating Pump in a Dishwasher ...? 4:17www.youtube.com/watch?v=oLPBlkIsB5sMar 26, 2010 - Uploaded by ApplianceHelpOnlineIf your dishwasher doesn't pump out or will not wash watch this video. ... GE Nautilus Dishwasher wont run - fills water and doesnt drain - motor ...How to repair a dishwasher, not draining - troubleshoot ...? 6:18www.youtube.com/watch?v=rO19zoOyNHAFeb 26, 2014 - Uploaded by AdamDIYHow to repair a dishwasher, not draining - troubleshoot Whirlpool ... awhile but now blade on grinder won't spin. what should be my next step? thnx ... from the bottom to access the water pump. but this was much simpler and it worked. thanks. ... If I manage todrain it now, I'll do what this video instructed :).
Oct 19, 2015 | Dishwashers
I've got a Kelvinator dishwasher KD12MM bought second hand, the machine goes on but does not pump water. Please help
Possible that the pump has clogged or is jammed with dirt. you will need to remove the pump and clean the pump assembly for a good spray pressure. If this wont work then the pump is faulty and needs to be replaced.Check this link for tips:
http://www.espares.co.uk/advice/dishwashers/a/3
Mar 12, 2012 | Kelvinator Dishwashers
FDB251OLCC1 dishwasher wont clean top rack
Possible that the main pump for the spraying system is not working, you will need to check the INLET valve , remove and check if there is flow when the washer is switched to start, if not the inlet valve is faulty as it does not allow water to the pump.
check this link for tips to check the pump;
http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html
Oct 18, 2011 | Dishwashers
Dishwasher won't fill with water
Check the power supply to the water pump through a pocket electrical line tester or volt meter.
Poer reaches and the pump mot rotating, check the capacitor associated with the motor.
May 27, 2010 | GE Nautilus 24" Built-in Dishwasher
Inlet/drain light flashes on miele dishwasher and it wont start - I can hear the pump but no water - I have checked and cleaned all pipes etc
The outlet pump is triggered by the anti flood micro switch via the polystyreene float on the base of the washer. If any water for whatever reason (leaky pipe)is on the floor the machiene automatically switches to pump out mode and only works once the water and the cause is rectified
Jan 16, 2010 | Miele 24 in. G638 Plus Free-standing...
Wont go through cycles or drain the 3inches of water.Is getting power
turn on the dishwasher then go to your circuit breaker and, switch off the power to your dishwasher next: reach in to your dishwasher and remove the cover on your pump then remove any broken glass etc. that has fallen into the pump then put the cover back on and, close the dishwasher turn it on and, turn on the breaker you turned off earlier your machine should work again let me know how it goes...
May 02, 2009 | Hotpoint 24 in. HDA2000Z Built-in...
Water isnt draining
Check your drain line and/or drain pump. The drain line should have a high loop at the point prior to where it connects to your drainage system in order to prevent drain water from the kitchen sink from back flowing into the dishwasher. In addition, most drain pumps have a small check valve that prevents this water from backing up as well. However, if you have something lodged in the drain pump (i.e., a toothpick) it can prevent the check valve from closing properly. This can cause water to back up into the dishwasher. You mentioned that the water will not drain. Is the drain pumping runnings at all? Please post back and let me know.
Apr 29, 2008 | Whirlpool 24 in. GU3200XTP Built-in...
Wont drain!!!
Check first the drain lines and the drain pump.
If the drain pump is working, and there is no problem in there, then the problem is usually because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
Jan 06, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Dishwashers Logo
133 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
