Question about Toshiba Satellite M115-S1061 Notebook
Screen no probs 'till 2days ago when startup produced really static-filled screen. could move screen a little & would go away. problem gets a little worse as time goes. am 1 month past warranty. new screen would be out of budget. would rather hear of known issues with this particular model. when more demand on power, seems to be worse as far as not being able to clear problem by simply altering angle of screen
  • jmoney2 Nov 16, 2007
    m115-s1064 is actual model # sold @ R-Shack. don't know if that makes a diff in ur evaluation.
  • 85 Answers
Sounds like a hardware problem with the screen. Try switching the video driver temporarily to one of the Microsoft standard drivers (like VGA STANDARD) and check if the problem is any different. If it is, then it is a software driver problem. If the problem is the same, switch the driver back and try this.
These solutions may damage your machine, so do so at your own risk.
Get the machine running normally and then try the following tests, watching for the static on the screen to change (get better, get worse).
- Tap lightly on the sides of the screen unit
- Open and close the screen unit lid to the full extent in both direction
- *Very lightly* twist the base of the computer one way and another - lightly, just enough to put a little pressure on the case
- *Very lightly* twist the screen unit slightly by the corners - lightly, just enough to put a little pressure on the case
- Tap on the corners of the computer's base unit like knocking lightly on a door
If any of these physical tests change the static on the screen significantly, you have hardware troubles. If this is the case, either take it for professional repair, or, at your own risk, try this.
It is very likely that you either have an electrical short or that the ribbon cable connecting the screen to the motherboard has come partially unseated. Find a friend who knows about taking things apart, tell him you think this might be the problem, and ask him or her to help you lovingly disassemble the machine looking for possible hardware problems. Remember to do anything like this with the machine completely unplugged and the battery out, and as a last resort on a machine you need but cannot afford to fix.
Final hint: if tapping or twisting the screen lightly changes the static, you probably have a ribbon cable or other hardware problem *in the screen unit*, while if you have changes in the screen when you knock on the base unit, it is likely where the video signal cabling enters the motherboard.
Good luck.
Posted on Nov 16, 2007
I have a 2001 honda Odyssey van and about a month ago my tcs light would come on every so often along with the check engine light.about a week and a half ago I woke up one morning And my van would not move...
You're out of transmission fluid. Put in a quart where you pull the dip-stick out from and start the engine. Drive it a minute, check the fluid while running, put more in if needed.
Nov 29, 2017 | Honda Cars & Trucks
Speaker produces noice/static/buzzing sound when it is off
That means that if too much power is going to the speaker or extraneous signals are being picked up by the wiring, it can come through the speakers as static. Stopping static requires finding and eliminating that extra electricity from transmitting through your speakers.
If you're still hearing distortion, turn down the volume on your amplifier until the distortion goes away. If the volume is too low to be easily heard, the problem may be that your amplifier produces too much power for your speakers to handle or that your amp and speakers have different impedance ratings.
Apr 04, 2017 | Boston Acoustics Duo-i Horizon Clock Radio
Camry smoke on startup
The key is the color and smell of the smoke.
IF coolant, the smoke is REALLY white and usually lots, and this smoke has a sweet smell. A pressure test may show some loss, and as well, often you get a little misfire that goes away.
If Oil, the color is white, but with a lot of blue, or darker...
Most of the time, after the converter warms up, it eats and converts both types of issues...
Steam, can be normal. Remember that for every gallon of fuel you burn, you actually generate 1 gallon of water. Typically evaporates or exits as steam, and is barely perceptable.
Jun 13, 2010 | 2003 Toyota Camry
I have had my Xbox 360 Elite for about 3 years now and haven't had any problems with it at all. I take great care of it, almost too good. It is completely open and in a cool room on a glass table in the...
Your Console is what's called a virgin Never been
opened . So with a proper re-flow and clamping hardware
not just screws to replace the X clamp but a solid G.P.U support system will produce to most durable repair.
After a good re-flow you can replace the X clamps with
a little bit of tweaking and this will normally get you 6-9 months of solid play time . P.S playing your console verticaliy may seem like a good idea but
it's relay not, due to the fact the thermal paste under
the G.P.U and C.P.U. will eventually seep away form
under the chip , promoting over heating issues
If you have any questions feel free to ask
Mar 02, 2010 | Microsoft Xbox 360 Console
Pavilion dv7 keeps shutting down
  • This may not fix your issue but its worth a try ...let me know how it goes
  • If the computer appears to shutdown and then attempt to restart without displaying an error message, do the following to disable the automatic restart on error setting.
    1. Click Start , right-click Computer , and then select Properties .
    2. Click Advanced system settings , grant permission to continue if prompted, and then click the Advanced tab.
    3. Click Settings in the Startup and Recovery section of the Advanced tab.
    4. Deselect the Automatically restart checkbox under System failure .
    5. Click OK to close the Startup and Recovery window, click OK again to close the System Properties window, and then close the Control Panel window.
    6. Restart the PC.
    Disabling the automatic restart setting allows time to view the error message that displays on the screen. Contact the manufacturer of the program or device that is causing the error for specific information about the error message.
  • Jan 21, 2010 | HP Pavilion DV7-1232nr Notebook
    Missing on startup
    Switch the plug with # 5 and coil with # 3 and see where the miss goes, then replace the part you moved to that cyl.
    Jun 30, 2009 | 2005 Dodge Dakota
    Horizontal ines---original post got wiped. Sorry.
    leaky cap(s) in vertical circuit. shouldn't be more than $125 (plus taxes) parts and labour
    May 14, 2008 | JVC AV-27230 27" TV
    Static screen
    Push the reset button along with the power button. That resets all memory in it and tends to fix the static fuzz.
    FYI: The static show on the screen after putting the batteries in backward.
    Feb 14, 2008 | Palm M100
    White speckly 'snow' on screen
    y sustain board needs adjusting or replacing
    Oct 10, 2007 | LG DU-42PX12XC 42 in. Plasma HDTV
    Washing Machine fills and emptys but does nothing else.....
    sounds like the drum belt has come off the pully or at worse broken.quite simple to mend.good luck.
    May 05, 2007 | Bosch Exxcel WFO 2465 Front Load Washer
    Toshiba Satellite M115-S1061 Notebook Logo
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
