Question about Toshiba CT-90157 Remote Control
Toshiba CT-9946 volume not working
The volume button on my Toshiba CT-9946 remote control doesn't always work. The other buttons work fine.
SOURCE: Volume go up to MAX, power button does not work
what is a tact switch and can i change it myself?
Posted on Mar 20, 2008
SOURCE: Toshiba CT-877 REMOTE
F*** YoU
Posted on May 11, 2008
  • 89 Answers
SOURCE: toshiba that uses CT-90040 remote
if this is a time warner cable remote. the toshiba code is 015. sometimes a tv has several codes but only one controls everything. dont understand tuning video into tv. sounds like u need to plug rca wire into input plugs on the front or rear and then move switch to video but dont know what wires u r using.
Posted on Dec 27, 2008
djicenova
  • 319 Answers
SOURCE: Toshiba 50HDX82 TV Volume Problem???
IR interface board could be bad
Posted on Feb 27, 2009
  • 164 Answers
SOURCE: Toshiba 32" TV volume and channel buttons turn it on and off
You could try a universal remote
Posted on Jul 19, 2009
Where is the input/source button
The TV/Video button at the bottom left of the Toshiba CT-859 remote toggles between the TV and external video sources. This button is below the Reset button. The CT-859 remote works for several Toshiba TVs, including the 19A24. The manual for this TV describes the remote buttons on page 6. The manual is available online at Sears Parts Direct here: http://www.searspartsdirect.com/partsdirect/user-manuals/19A24-Toshiba-COLOR+TELEVISION-manual . The direct link to the manual is http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0407309.pdf .
I hope this helps.
Jan 04, 2016 | Toshiba CT-859 Remote Control 72795473
It's like the volume button is stuck
all tv sets with keyboards (controls) on the front or side use micro switches which the buttons engage--these are momentary switches=only supposed to work when pressed--they go bad in exactly the way you have described--cheap and after being pressed too hard will not disengage.
The way to prove this (by the way the switches have priority over the remote so it will not work if one is bad) is either access the vol up control and disable (unsolder the two pins) or test the switches with a ohm meter----
If the remote receiver is on same board as buttons/switches you are going to have to unsolder the offending vol button--if it is not you can usually disconnect the control board and set will again work with the remote.
either test/unsolder or have a shop do it.
If set works fine with vol disconnected just use the remote as you would likely have to replace the keyboard to correct it.
If you have the meter and are familiar with reading resistance let me know and I will tell you what to look for.
SD TECH
Apr 27, 2012 | Toshiba Ct-90302 Remote Control
I need a new remote to Toshiba model # 50 A 61
Hello again,
In addition to the suppliers I already identified for you, I also found a couple more;
http://www.remotestogo.com/toshiba/toshiba-ct-9946/prod_4204.html
http://www.electronicadventure.us/Merchant2/merchant.mvc?Screen=PROD&Product_Code=CT-9946&Category_Code=TRC
I'm a little wary about electronicadventure.us as they don't provide any contact details on their website, but i investigated remotestogo.com and could not find ANY complaints posted on the internet. Usually if suppliers are dishonest or unreliable, there are always warning messages posted in various forums about them.
Please can you reply to this message at some point and let me know whether you managed to obtain the remote? Thanks.
BElectric
Nov 19, 2010 | Toshiba Televison & Video
The volume on the TV keeps going down by itself. What should I do?
Dont know what tv you have but. You can remove the batteries from remote and if volume still goes down you ruled out the remote as the problem.. Or just take remote to another room. If the problem still exists then Im guessing either a sticky button on the tv volume down or as I have seen to many times.. People clean their tvs with windex or some cleaner and it drips down into the tv messing up the control buttons. Hopefully its just a sticky button..
Oct 19, 2010 | Toshiba CT-90157 Remote Control
Can I use this for another tv?
It will work, to some extent, with most toshiba tvs. You will find that on differant models, some buttons won't work and others won't do as they say but other functions, but will work 100% for same model.
Jun 13, 2009 | Toshiba CT-90157 Remote Control
Toshiba Remote CT-877 problem
I contacted Toshiba. Take out the batteries. Press every button on the remote. But the batteries back in. The remote will work because you just reset it.
Jan 10, 2008 | Jensen SC-340A Remote Control
Toshiba CT-90157 Remote Control Logo
199 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
