Question about Olympus Camedia C-3040 Zoom Digital Camera
3040--Lens cap on when camera turned on
I accidentally left the lens cap on when I turned on the camera. The lens apparatus ground a lot, finally extended when I removed the cap. BUT, the lens does not retract when I turn it off--it makes the grinding sound, but doesn't bring it in. It tries 3 times, then stops. It also makes the grinding sound when I turn it on with no apparent action on the part of the lens. Have I ruined the camera for good?
  • Joe Seibel Dec 09, 2008
    My C-3040 Zoom lens opened & I took some pictures. When I powered off the camera, the mechanizm sounded like it was closing but the lens never retracted. I turned power back on, same mechanical noise. Turned off power and same noise & no lens closure. Does anyone have any suggestions? I stopped by a local camera shop & they said it would be $250 just to look at it plus parts. They said because the camera was 7 years old, I should just trash it & get a new one for that money. I really love the camera & have taken thousands of pictures with it. I'd hate to lose "an old friend" so if anyone has any suggestion, I'd appreciate it. Thanks, Joe
    Sniper:
  • 54 Answers
There is no way either of you or a tech can fix this problem without taking the camera apart. Sounds to me like the worm or drive gear is stripped or displaced...probably a 10 cent part...unless you have the ability to do this type of work...its best left to the techs.
There is a risky thing to do...and that is...perhaps its just "jumped" the gear...so it grinds when it attempts to move either in or out....you may be able to manually turn the lens and "click" it back into place. Gently turn it all the way right...then all the way left.
I would want to look inside first before I do anything else...it may be an easy fix...taking it apart will be the not so easy thing.
Posted on Apr 23, 2009
I left the lens cap on a lot when turning on this camera, and to fix I pressed firmly against one of the sides of the lens housing to trigger the mechanism while turning off after it started doing its clicking thing
After a while, it stopped coming out of the body. I replaced it with a slimmer pocket sized camera, a sony dscw170 in 2008. Fast forward two years to today, I decided to look at it and while cleaning the lens it "snapped" something inside. I popped in some fresh batteries and voila, it works again! I love this old camera because of its wide and fast f1.8 lens. I swear it takes better pics than my sony.
Posted on Sep 04, 2010
Lumix DMC FZ35 Lens Opens and Retracts Continually When Turning the Camera on.
it sounds like it has slipped a gear in the lens.. you could try to manually push the lens in when it comes out and that might reset it but it also might break it.. best is to send it back to panasonic.. is a easy fix
Oct 01, 2012 | Panasonic Lumix DMC FZ35 Digital Cameras
The problem is that the camera cannot open the front eye, when you turn on the camera it does not come out. and at the end it say lens error, restart camera, but still do the same thing. help cause i want...
Its a common error with cameras with retractable lenses. It could be a grain of sand stuck in the slide parts of the lens. Another cause is accidentally pressing the ON button when the camera is in its case.
The solution is usually "helping" the camera lens to come out. This is a tricky job because it requires putting pressure (by pulling) on sensitive lens parts. If you're not comfortable with that, ask someone else to have a look at it.
I've had one IXUS 860 which could not be recovered from the lens error. The second IXUS 860 had the same error - the lens however moved finally after turning the cap for a bit. In the first case it was sand. In the second had tried to push the lens out while in its case - the ON button was pressed.
Jul 04, 2011 | Canon PowerShot SD880 IS / Digital IXUS...
How do I switch the lens on my Olympus evolt e500
1. Switch off the camera
2. Prepare the lens you want to put on
3. Remove the rear lens cap by turning it anticlockwise
4. Put the camera in your left hand's palm so you can press the lens release knob wit the finger, and press it down.
5. rotate the lens anticlockwise, and remove it
6. immediately put another lens on the camera. The both red dots, on the camera and the lens must be aligned
7. Rotate the lens clockwise.
8. Put the rear protectiv cap on the lens you just removed.
9. Now yuo can turn the camera on and take the photos.
May 02, 2011 | Olympus EVOLT E-500 Digital Camera
What can i do if my ixus 55 has been dropped on the ground and it can't work? i mean, i accidentally dropped it on the ground and after that, it could not be turned on again. i tried every thing. how can i...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jun 18, 2010 | Canon Powershot SD450 / IXUS 55 Digital...
Lens error nikon coolpix 4300
This error occurs if camera is turned on before lens cap is removed. If you are removing the lens cap before turning the camera on and still getting this message, camera should be serviced by a qualified technician.
May 17, 2008 | Nikon Coolpix 4300 Digital Camera
Left power on
Hey raggedarmi,
Leaving the camera on for an extended period of time should not cause the camera to no longer turn on. Make sure the lens cap is not on the camera when you turn it on, and make sure you are not using manganese batteries because they don't work with this camera. The camera will not operate while connected to a computer so make sure you are not connected to a computer. The camera might be in sleep mode so try pushing the shutter button or hitting the zoom lever. If none of these options work try putting in a brand new set of AA batteries and see if that works and if it does it probably means your rechargeable batteries are bad.
Sincerely,
Allan
Go Ahead. Use Us.
May 14, 2008 | Olympus Camedia C-3040 Zoom Digital Camera
Zoom Lens doesn't Zoom
Check you haven't accidentally got the camera into some fixed-zoom mode ("Super-Macro" is a favourite for this on Olympus cameras).
A.
Apr 06, 2008 | Olympus Camedia C-765 Digital Camera
E18 error pops up and to make it worse the screen is green and its making a lot of beeps
http://blogs.yucs.org/~dwallach/2004/08/canon_e18_error_repair_instruc.html
The better solution is to send it to Canon's service people.  They can fix he problem is the fixes at the above site won't work.
Mar 05, 2008 | Canon PowerShot A520 Digital Camera
Lens Protection Size!!!
Get a CLA-1 lens tube. It screws into the camera body. The other end accepts 43mm accessories. Put on a 43-49mm step-up ring. Into that screw a 49mm UV filter. (The step-up ring is needed to separate the filter from the extended lens.) Leave the UV filter on at all times. Throw away the lens cap.
Sep 11, 2005 | Olympus Camedia C-3040 Zoom Digital Camera
3040 Issues
A stuck pixel on the LCD is quite common. I have one on my 2020z; lot of people here would tell you the same thing. Long as it's just one, I wouldn't bother trying to get new camera. Far as the lens extension sound: It is a little loud, but a *grinding noise* doesn't sound normal. Go to a store and pick up another one, see if it makes the same sound. If not, you may have a bad camera.
Sep 07, 2005 | Olympus Camedia C-3040 Zoom Digital Camera
Olympus Camedia C-3040 Zoom Digital Camera Logo
153 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
