Question about Hitachi 50UX57B 50" Rear Projection Television
I replaced the convergence IC, now the picture is rolling.
  • Hitachi Master
  • 5,568 Answers
That may be a simple adjustment; there are two synchronization signals embedded in the received signal, one for the vertical 'lock,' the other for horizontal. Your vertical lock has changed for whatever reason and any competent technician should be able to locate make the adjustment.
Without service literature available for the set, it might be tough to find for anyone untrained and I can't tell you where it is located on your set.
Posted on Jul 12, 2009
I have a sony big screen kp57wv600 and the picture looks like I need 3D glasses. The pictures has a green and red hallo all around the outer picture. The picture is clear in the center and goes out and is...
Sir the problem of your tv is the convergence to narrow the problem try to adjust first the convergence settings using your original remote go to setting menu then to the convergence setting, you can adjust the red and blue convergence, you should be able to adjust the red and blue left, right and up, down you should align the red and blue to green but if you cannot move them far enough or if you cant move them in any direction the convergence IC is already defective replacing this IC will fix the problem, you will find this convergence IC attach to a large aluminum plate this aluminum plate is the heat sink. It is easy to locate if you remove the back cover of your unit be sure to unplug your TV
this is the convergence IC if you remove this try to observe also if there is a cold solder or dry joint because sometimes this cause your convergence to malfunction observe the solder part of the convergence.
This is a cold solder or dry joints you can fix this by resoldering using a soldering iron, soldering lead, and desoldering pump but be sure not to connect separated pins it may cause much damage to unit if accidentally solder together. To replace the IC convergence try to check this link http://www.tvrepairkits.com/xcart/product.php?productid=19971&cat=1538&page=1 hope this helps good day and best regards.
Sep 23, 2011 | Sony KP-57WV600 57" Rear Projection...
Tip
61H70 Common Problems According To Local Repair Shop
No Startup = Check Q404 (2SC5570) and pico fuse F470 (2A)
Dead = Check Q801 (strz4369, 23135015) or replace QA02
Intermittent Reset = Add cotton tape and capacitor (0.47uf) across pin 54 of QA01 and GND (CA61 GND side)
Dead Relay Clicks = Replace zener D878 (9.1V)
HOT Fails Often = Replace C403 (22uf/100V)
Picture Fades Comes Back Blurry = Replace Q510 and Q221
When environment temperature rises above 95 grade F, television goes out of convergence and vertical slowly rises from bottom of screen = Connect capacitor (10pF/50V) between R4013 (Q421 collector) and R4012 (Q421 base). Add insulation tape underneath capacitor as necessary.
Intermittently no blue colour. Distorted lines in picture = Replace Q751 (STK392110)
Rolling picture. No convergence. Red foldover = Replace Q751 (STK392110) and R7726 (1.2R)
No picture. Audio and OSD OK = Check R243 and R244 (22K/0.16W)
Q510 replacement = 2 IC types have been alternately used as Q510.a) TA1316Nb) TA1316AN...The 2 types are not interchangable. When replacement of Q510 is necessary, the original type must be used. Do not use part number listed in the service manual. Use part numbers listed. Q510, type IC: TA1316N - Use P/N: 23000358 Q510, Type IC: TA1316An - Use P/N: 23000584
Dead & Power LED flashes = Check fuse F860 (4A) for O/C, Q801 (STR-Z4369), D862 (NTE552). Also check zener diodes D873 (27V), D875 (9.1V), D877 (27V) and D878 (9.1V).
Hope this helps...Unless you know exactly what is going wrong, sending the chassis to http://www.ptscorp.com would be my advice.
on Jan 22, 2008 | Toshiba 61H70 61" Rear Projection...
I have a Toshiba rear projection TV model # 50H71 for about a month the tv would randomly pop off (lose sound and picture) for about 45 seconds and then come back on now th picture is reduced in size by...
Good Day,
The TV has a convergence problem; the IC’s for that circuit will need to be replaced. The cost for this repair runs around $450.00 or more.
Replace the defective Convergence Output IC Part Number
23905094 (STK392-110) using the revised “T” version IC Part Number
23135090 (STK392-110T). When Convergence Output failure is
detected, it’s recommended that both IC’s be changed to the “T” type IC
version. Inspect the Convergence Output IC’s for the “T” type version as
shown in Figure 2. Replace the Convergence Output IC’s using the “T”
type version Part Number 23135090 (STK392-110T).
Thanks for choosing FixYA, Big Irish
Nov 22, 2009 | Toshiba TZ50V51 50" Rear Projection...
My tv is showing a double picture in red
You have convergence problem in your tv . You need to replace convergence IC . YOu can get from the link below .
Convergence ICs
You need to replace both convergence ICs .It will cost you around $30 .
The IC number is STK392-110 .
Hope this helps .
Mar 03, 2009 | Apex Digital GB4308 43" Rear Projection...
Convergance
did you replace both ICs? also samsungs will usually burn at least two of the 3.9 ohm resistors when a ic fails.
Sep 26, 2008 | Samsung PCJ522R 52" Rear Projection...
Toshiba 40who8b convergeance problem
Good Day, harri1234;
Sounds like a convergence problem.
Convergence Output IC Failure
Corrective Action: Replace the defective Convergence Output IC Part Number 23905094 (STK392-110) using the revised “T” version IC Part Number 23135090 (STK392-110T). When Convergence Output failure is
version.
Good Luck, Big Irish.
Jun 23, 2008 | Toshiba 42H81 42" Rear Projection...
No picture red light blinks 7 times
in this model is commom that the convergence ic.s go bad and stop the set from turn on check for a couple of fuses that are in convergence board if is blow replace convergence ic
Feb 01, 2008 | Sony KP-53HS10 TV
Right side convergence
A convergence IC has burned out. If I remember correctly, those Pioneer sets have one huge convergence IC, but that IC only has 5 channels in it so they use another smaller dual STK IC and one half of it is used for the 6th channel and the other half is the vertical output. Look on the convergence board, find the blue convergence jack, identify the blue horizontal channel, follow the traces and replace the IC handling the blue horizontal channel.
Aug 28, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Distorted Color and geometry of Picture
I've posted this solution several times but here goes. Try setting up the convergence through the menu by accessing the convergence setup menu. If this fails to work you have a bad digital convergence box and need a tech to replace it. About $60 to $100 fix.
Nov 03, 2005 | Panasonic PT-47WX49 47" Rear Projection...
Hitachi 50UX57B 50" Rear Projection Television Logo
144 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
