Question about Sony IT M602 Corded Phone
How do I delete the current caller ID numbers and names?
How do I delete the current caller ID numbers and names set on my Sony IT M602?
SOURCE:
cnavarro
  • 2460 Answers
SOURCE: want to delete caller ID from my Panasonic KX-t7730
This is just a guess, because it works on my 848.
While you are displaying the CID directory, press the TRANSFER button. Repeat as necessary.
Carl
Posted on Feb 25, 2009
ynotphone
  • 192 Answers
SOURCE: Need Caller ID displayed on Nortel StarTalk Flash/M7310
A question: -> does your phone ring? -> what software are you running on the system? If you know this will help a little in giving you more information. There is a Feature that you can dial if your phone rings... when there is a call coming in, dial FEATURE 8 1 1 You can even make this a button rather than dialing this feature code everytime: -> Feature * 3 -> press the button that you want to program -> dial Feature 8 1 1
Posted on Jul 16, 2009
cnavarro
  • 2460 Answers
SOURCE: my caller id is not showing name or number of the
Since CID display to the phone comes from the Panasonic phone SYSTEM, you might try looking inside the cabinet to see if it has a caller ID card. The part ends in 93.
It also requires some programming. If you post your model number, I might have a CID card if yours is missing.
Carl
Posted on Dec 04, 2009
SOURCE: no longer can see caller ID numbers
IMI SPUNE CA NAM DRIVERE INSTALAT SI NU MERGE IMI DA EROARE
Posted on Apr 28, 2010
SOURCE: Vodavi Starplus STS Caller ID not saving numbers
Please tell me how to change the number of rings on my Starplus STS before it goes to VM. I'm dying! It goes to VM after 3 rings and were missing tons of calls. Thank you!
Posted on Oct 28, 2010
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
Mar 15, 2016 | Vtech V CS6419-2 DECT 6.0 Cordless Phone,...
Phone doesn't show caller id numbers anymore.
You need to make sure you have programmed your area code...check the manual for setting up caller ID. You can search for the manual on line...go to Retrevo.com
http://www.retrevo.com/support/Sony-IT-M602-Telephones-manual/id/751bh629/t/2/
Mar 10, 2010 | Sony IT M602 Corded Phone
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Uniden Cordless Phone
Caller ID
yes
Menu-settings-call settings- show my caller id-set by network
Or if u are using postpaid connection may be ur clip facility is deactivated
Aug 11, 2009 | Nokia 2630 Cellular Phone
Display most recent Caller ID telephone numbers not old ones
You have a 7730 PHONE. The system is not determined, but in analog going forward it could be a TA-624/824 or TAW-848.
If you have a TA system, it requires programming http://www.fixya.com/support/t2436730-caller_id_stoped_working_dont_know_clear
Carl
Jun 26, 2009 | Panasonic KX-T7730 Corded Phone
On my model 8885 uniden phone, when I try to store a # the screen say's memory full. I only have two numbers stored. help
These phones use a "Shared" memory, the CID information and the Phone book information share the same memory chip. If you clean out the caller ID data you should be able to load more numbers in the phone book. Since you have an 8885 I am assuming you have TCX800 or TCX905 handset(s), to clear the CID memory, Follow these steps:
Deleting Information from the Caller ID List
1) When the phone is in standby mode, view the Caller ID
information to be deleted (see "Viewing the Caller ID
List" on page 50).
2) Press the DELETE soft key. De let e C all er ID appears.
3) Press volume up/down to choose Yes.
4) Press the OK soft key. You will hear a confirmation tone.
To delete all the CID information follow these steps:
Deleting all Caller ID names/numbers
1) When the phone is in standby mode, press cid.
Press the DELETE soft key. De let e A ll? appears.
2) Press volume up/down to choose Y es.
3) Press the OK soft key. You will hear a confirmation tone
Mar 27, 2009 | Uniden 5.8GHz Dual Cordless Phone
Cidco inc caller id box - model # JA-25A-18
When a call is received it will automatically set the time and date. To change the display contrast hold down the 'delete' button while toggling one of the other buttons. Hold the delete button down until the 'select,mem,mode' is displayed and choose between '25 name & number' or '64 numbers' . Make sure the batteries are good and the batt indicator in top left corner of display is off. I think that is all the features this early model unit was capable of.
Sep 29, 2008 | Home Security
Caller id recall
To redisplay the Caller Id Number, press the Line button again.Caller ID Scrolling is possible if you have a MIF-F(C)-10 card in the system and you have a Scroll key programmed on the phone. If you need further assistance, let me know.
Aug 27, 2008 | NEC Electra Professional ETW-16DC-2
Uniden power max 2.4 ghz
I had the same problem but figured it out. For some dumb reason, Caller ID numbers count against your total phonebook memory. So if you just delete all your Caller ID numbers (press the "Caller ID" button and then the "delete" button) then you'll be able to store new numbers in your phonebook.
If I could get my hands on the Uniden engineer that is responsible for this, I'd smack him! :)
May 17, 2008 | Uniden Phone
Sony IT M602 Corded Phone Logo
47 people viewed this question
Top Sony Lands Phones Experts
Marvin
Marvin
Steve Allison
Steve Allison
mark gardner
mark gardner
Are you a Sony Lands Phone Expert? Answer questions, earn points and help others
