Frigidaire Thru-Wall/Window Air Conditioner
Problem for Frigidaire (FAC124) Thru-Wall/Window Air Conditioner
How to install if wall is too deep for wall AC unit
By darakiane on Jul 12, 2009
main concern is the exhaust and drainage don't clear the other side of wall by about 1/4"
Best Solution
posted on Jul 12, 2009
Helpful)
acfxr
Rank: Guru
Rating: 90%, 65 votes
this may be an issue, you need to verify the air flow patterns over the condenser coil. If there are louvers in the sides that would be the "intake" for the coil and it will definitely not work if these are blocked. You may need to make the opening larger and mount the sleeve from outside as it would be better to have the controls closer to the outside wall than the air flow blocked by the wall.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Frigidaire Thru-Wall/Window
Questions and Unsolved Problems for Frigidaire Thru-Wall/Window
Do you recommend Frigidaire (FAC124) Thru-Wall/Window Air Conditioner?
Answer
Answer
I am currently installing my new zw5000 ac. I have followed the instructions and everything is ready... (More)
Answer
I have a window A/C unit. It has worked for years. It worked last month, but it wont turn on now.... (More)
Answer
I have a frigidaire FAA074S7A 6500 BTU window unit from Lowe's. Can window units be mounted in a... (More)
Answer
I have a FRG Model#FAS256R2A only one year old . When it runds it shoots drops of water out of the... (More)
Answer
I got this unit from Amazon. I sent a check for an extended warranty a couple of weeks ago in the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioner Experts
Top Air Conditioner Repairmen
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
