Question about Christie LX45 Multimedia Projector
Ghosting problem with Christie LX 45
Getting ghosting on letters when showing a PowerPoint presentation. Adjusted the Contrast and brightness, that seemed to make the lettering on the white background better but not on the colored background. This seemed to start happening after I changed the bulb out. Any ideas???
  • 2,237 Answers
Reset the settings to factory default and make sure the resolution matches. you can adjust the clock and phase in the menu.
Posted on Feb 04, 2010
Royal safari portable typewriter letters ghosting
Usually you are striking incorrectly snap the keys and get off of them. you holding the key down too long.
Jun 28, 2016 | Royal 1966 Safari Portable Typewriter 8247
WD 73835 has ghosting images during dark or red scenes
Make sure your contrast isn't set too high. Most ghosting is caused by either contrast, brightness or tint issues. Try adjusting these settings. Also check if there is a Dynamic contrast setting for your TV as well as this can cause ghosting also.
Apr 06, 2014 | Mitsubishi Diamond 835 Wd-73835 73" 1080p...
My Remington Noiseless 1939 typewriter has ghosting on the letter keys. I have put on a new ribbon but this just shows up the ghosting of each letter more than ever. I notice when typing the carriage
Could also be that your paper is too fibrous of finish. I found this page because my typewriter was ghosting, too. I adjusted some of the settings and there was not a trace of ghosting. I put the settings back and still no trace of ghosting. Then I realized that I tested for ghosting on paper that has a much smoother finish. I was ghosting on cheap paper we use here at work. So, I don't blame the typewriter. I blame the cheap paper. My typewriter just likes good paper.
Nov 14, 2011 | Office Equipment & Supplies
The TV picture shows a double image like "ghosting"?
Ghosting or blurring vision happens due to a faulty video processing board. It may be due to faulty T-con board (BN81-01308A) or a main board ( BN94-01199B ). However, you'll need to check the wiring on both of these boards. Before this I'll suggest you to callibrate the TV by following these settings--
Contrast: 85
Brightness: 46
Color: 56
Tint: G50 / R50
Sharpness: 15
Backlight: 5
Black Adjust: low
Dynamic Contrast: low
Gamma: 1
If this doesn't resolve the issue then turn off and unplug the TV for 4-5 hours and check.
Jun 10, 2011 | Televison & Video
AL 1655CS - We're experiencing ghosting...we've put in new drum and toners...could it be the fuser? Any way to verify the fuser need before we purchase it?
The best way to test for ghosting or Double Imaging caused by the fuser is to run a copy and shut the machine off just as the copy starts to exit the copier. Then open the right side door and open the fuser gate with all the teeth on it. This will release most of the fusing pressure. Gently pull the paper backwards out of the machine. About the bottom 1/2 of the page will have NOT gone thru the fuser yet and you can tell if the ghosting is present. If it is not then the ghosting is coming from the fuser. Note that ghosting caused by the fuser usually does not show up evenly across the whole page. It is usually in bands, lines or one one side or the other.
Good Luck and Thank You for using Fixya.
Sep 24, 2010 | Sharp AL-1655CS Laser Printer
Slight ghosting and color alignment problems
comvergencia that reviews the misaligned with the remote control and traps
Jan 05, 2010 | Televison & Video
Writing on tv
Ghost problem is mainly come from incoming signals - check cable.
Play a DVD player to make sure the TV works fine.
Aug 12, 2009 | Televison & Video
Sony BRAVIA KDL-40W4000
I've been looking into this myself as I've also recently purchased the KDL-40W4000. I was watching a murky old film and was getting a bit of sludgy ghosting but found that by reducing the contrast to 25, setting the backlight on low, colour on neutral and the brightness about 40-60 (and taking ALL advanced noise functions off), this reduced the ghosting considerably.
BUT, this is quite a cool and dark image. If you watch standard TV and films mainly, a variation of the Cinema setting is probably the best overall setting i.e.
backlight: min
contrast: 79
brightness: 50
colour: 53
colour temp: Warm 2 (although Warm 1 is less yellow and still fine)
sharpness: min
noise reduction: off
mpeg nr: off
contrast enhancer: off
colour space: standard
Ben, UK
Oct 11, 2008 | Televison & Video
HItach cp-s860 problem
I have the same Hitachi CP-S860 and have found the problem is with the convergence on the left and right sides of the picture. The one I am working on has a bad ghosting problem also - you can really see the ghosting when the MENU is on the screen. The center convergence is OK. Following Pics show Circle / Cross pattern - 1st pic the red, green and blue are turned on - 2nd pic shows green and blue on only. I do not have the service manual for this set so I do not know the convergence procedure on this one. I have mostly been repairing NEC, Sanyo, Panasonic and Christie LCD & DLP Projectors.
Feb 29, 2008 | Hitachi CP-S860 Multimedia Projector
51 projection tv dark colors
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 20, 2007 | Philips Magnavox 51MP392H Rear Projection...
Christie LX45 Multimedia Projector Logo
411 people viewed this question
Top Christie Office Equipment & Supplies Experts
jasbo
jasbo
Lawrence Oravetz
Are you a Christie Office Equipment and Supply Expert? Answer questions, earn points and help others
