Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
I have a 1984 35 hp Mercury outboard that will start but spit and sputter and run for aboout 10-15 seconds then die. I've already rebuilt the carb and added fuel treatment to the tank. Anyone with any advice on what I should do next?
  • bwwatson May 11, 2010
    get rid of the fuel, fuel treatment don't get rid of water. Did you leave the vent unscrewed on the tank? get any amount of rain? A little water in the fuel can cause a lot of trouble. I would go get a new tank, fresh fuel, new fuel line and bulb. Then i would pull the drain bolt on the front of the carb and spray a liberal amount of carb cleaner into the drain hole to push out all the contaminated fuel, reinstall the drain bolt, connect new fuel tank and line, and fire her up. let me know how it works, I think ou'll be suprised. A little water in fuel can cause alot of trouble.
  • 25 Answers
Fill a gas can with straight gas, the disconnect the primer bulb and hose ( enough to insert into the gas can). After you insert the hose into the gas can disconnect the fuel line above your fuel filter. Prime the bulb until fuel runs clear, then re-attach the fuel hose (the one with the filter). Finally remove the drain screws (brass color) off the carburetor or carburetor's, then prime the bulb again until fuel comes out clear (from the drain screws). Spray carb cleaner into the holes of the removed screws. Then replace everything as normal and prime bulb running off your normal gas tank. Re-choke your engine and start it. If this starts easier and better, then you know its your gas.
Posted on Apr 18, 2012
Replace the fuel filter and spark plug and if 2 stroke check fuel mixture
Posted on Jul 14, 2009
  • 636 Answers
Have you checked the CDI module for a cracked wire or rubbed wire yet?
Posted on Jul 26, 2009
Why my 2006 tohatsu 5 h.p outboard will not idle down to trolling speed without spitting sputtering then dieing.
Remove the carburetor and thoroughly clean all of passages by compressed air you probably have blocked passage for fuel on the low idle side
Nov 09, 2014 | Seloc Mercury Outboard Engine Repair...
My 2001 vz800 dies occasionally when i pull in the clutch
possibly, it might be the kickstand safety switch is sticking!
Jul 26, 2013 | 2001 Suzuki VZ 800 Marauder
Spitting gas out of carb with new carb and plugs
could be the coil getting hot and loosing spark
Feb 22, 2013 | Garden
85 hp force eng stops running when put into gear and then given more throttle(only hapens in the water)ok out carbs rebilt ,filters cleaned
check compressions 100psi or more on all cyls ! carbs balanced ? sparks on all cyls ? crank seals could be worn ! tick over 1000rpm then in gear 800rpm ish ! In water !
Oct 29, 2012 | Seloc Mercury Outboard Engine Repair...
When i try to start off the engine starves for gas and dies
sounds like the choke assembly needs adjusted. takes a phillips screwdriver and just back top screw out a little and bottom screw and turn whole assembly towards the plus side.(some have numbers some have + or -. If you adjusted the carb at all it could be in low idle circuit.
Mar 18, 2012 | Clymer EvinrudeJohnson Outboard Shop...
Motor spits and sputters
If it is old enough to have points then I would check them and make shure they are clean and gapped at .020. if that is noth the problem then it sounds like a fuel issue. Either a weak pump or a dirty carb.
Aug 01, 2009 | Light Outboard Motor Boat Bass Fishing...
Hessitation when accelerating
Sounds like you have either old fuel in the tank, wrong fuel/air mixture, or plugged carberator jets. First thing that I would try is to adjust the fuel/air mixture. Near the top of the carb on the front or the side there is a slotted screw. Turn the screw all the way in until it seats. Then turn it counter clockwise 1 1/2 turns. That is your start point. Then with the engine at an idle in gear slowly turn the screw clockwise until you hear the engine start to die. When it when it sounds like it is going to die turn back out 1/2 turn and it should smooth out. this is your correct mixture and should be readjusted anytime you rebuild the carb or run at a different altitude. Second thing that I would try is while running engine get the RPM's all the way up and while still maxed out pull the choke knob out and when it is about to die push knob back in. That will cause a vaccuum inside of the carb and possibly clear jets out. If that doesnt work then I would pull the fuel bowl off of the carb and make sure it smells like fresh fuel and not old fuel. Old fuel has a very distinct smell. if the fuel smells old then you need to have the carb rebuilt and that should be done by an outboard mechanic.
Aug 01, 2009 | Raymarine St6002 Smartpilot Hydraulic...
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
1,403 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
ka4iup
ka4iup
Are you a Light Boating Expert? Answer questions, earn points and help others
