Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
The bar brush does not spin. I opened the vacuum head and the drive belt to the bar brush is loose. I don't see how you remove the slack from the belt.
  • 97 Answers
You have to have it in the carpet setting in order to put pressure on the v-belt. there is no way to tighten up the v-belt, but i would try to replace the big flat belt. if you haven't changed this belt in over 6 months, i would change it. ( on average belts need to be changed every 6-8 months). the reason is that the belt streches over time and doesn't have enough tention to ingage the v-belt in order for the brush to work. hope this helps
Posted on Aug 06, 2009
My dyson dc25 brush bar will spin for a few seconds and then stops. What can I do to repair myself? The brush bar is not jammed, it spins freely by hand.
if it spins freely no resistance you probably need a belt..
http://www.vacuum-direct.com/dyson-dc25-drive-belt.aspx
if the belt is ok then the gears may have striped ck amazon for a head assembly complete.
Jan 28, 2018 | Dyson Vacuums
Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
I can think of three things that could be wrong.
The easiest one is that the brush has hair and fluff wrapped around its bearing. This happened to me and was causing a burning rubber smell. Turn it over and remove the base plate. Lift the belt by putting a piece of cord under it and slide the brush out. Remove one end of the brush and slide the spindle out. Clean all the hair out and reassemble.
The internal drive belt is worn, or the nylon bush that it runs on.
The clutch is worn out.
The last two are not as easy to fix as the main drive belt is enclosed in the centre of the clutch. There are videos though that show you the process. Have a read and a watch, but try my first tip first.
  • Dyson DC25, DC29 - Resetting the brush bar (Official Dyson ... www.youtube.com/watch?v=q--faamcC7g
    • BY ASKDYSON
    • 1 MIN
    • 127K VIEWS
    2011-09-29 · Want to watch this again later? Sign in to add this video to a playlist. How to clear and reset the brush bar of your Dyson DC25 or DC29 upright ...
  • Dyson DC25 Upright Vacuum Cleaner - Support ' Dyson.com www.dyson.com/Support/dc25/DC25-ANIMAL Dyson DC25 Upright Vacuum Cleaner Support. Skip to main content X. Shop. Shop vacuums; Shop air treatment ... The Dyson Helpline is available during the following ...
  • My dyson vacuum cleaner brush will not spin. It is not the ... howtomendit.com > ... > Household Appliances, Vacuum Cleaners My dyson vacuum cleaner brush will not spin. It is not the belt. ... How can I fix my dyson dc25? The turbo button is not working... Click here for the answer:
  • Brush bar not rotating - Dyson www.dyson.co.uk/.../brush-bar-not-rotating Brush bar not rotating. ... to ensure vacuums containing Dyson Cinetic™ science maintain constant suction. ... tested at the cleaner head.
  • The Brush Won't Spin on My Dyson Vacuum Cleaner ' eHow www.ehow.com > Home > Home Appliances > Other Home Appliances 2015-06-29 · eHow; Home; Home Appliances; Other Home Appliances; ... My Dyson Vacuum Cleaner's Beater Brush Won't Spin; Dyson Vacuum Brush Roll Not... My Dyson ...
  • Dyson DC25 brush won't spin when touching the floor. If I ... www.fixya.com > Forum > Vacuums > Dyson 2016-03-18 · Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
  • Dc25 animal. front brush not working - Fixya www.fixya.com > ... > Dyson > DC25 Animal Bagless Upright Vacuum 2012-03-29 · ... Dyson DC25 Animal Bagless ... dc25 animal. front brush not ... I have a Dyson DC-25 animal. My brush bar did not spin and has been replaced with a ...
  • Dyson DC24 Brush Bar Motor - Dyson Medic - Dyson Medic dysonmedic.co.uk/dyson-dc24-brush-bar-motor It will not spin when the ... Dyson DC24 Brush Bar ... Unit Motor Dyson DC25 Dyson DC25 beater bar Dyson DC25 brush bar Dyson DC41 Dyson DC50 Dyson Motor Dyson ...
  • DC25 brush bar not working - Dyson Spare Parts with Free ... manchestervacs.co.uk/DysonForum/index.php?topic=738.0 DC25 brush bar not working ... My brush bar stopped working on my DC25 ball the other day. ... Manchester Vacs Dyson Engineer
  • Dyson DC24 - Resetting the brush bar (Official Dyson video ... www.youtube.com/watch?v=akGLQ7UbctY
    • BY ASKDYSON
    • 2 MIN
    • 275K VIEWS
    2011-09-29 · How to clear and reset the brush bar of your Dyson DC24 upright vacuum cleaner. DC24's brush bar is engineered to shut off for protection if ...
  • Mar 18, 2016 | Dyson Vacuums
    How do I get the brush bar to spin?
    Is it belt driven? Have you disassembled that part to make sure its not clogged with much and pet hair? Is the belt slack? it has to be tight.
    May 16, 2015 | Dyson Dc50 Animal Bagless Upright Vacuum -...
    When the head is down and the brush is engage for carpet use, the brush does not spin. At the same time there is a high pitch squeal that is heard. If I lift the handle up, lifting the head and the...
    This sounds like a belt issue to me. The belt usually runs from a drive shaft to the rotating beater bar / brush. Both the drive shaft and beater bar / brush that are contact with the belt must be clean. Oils, etc. can interfere with the grip on the belt. If the belt is squealing for very long, the drive shaft can damage the belt. make sure you're using the correct belt - and have all the parts in their right places. Recheck your work and provide the vacuum make and model if you're unable to get it working properly.
    Feb 24, 2015 | Vacuums
    How do i know if the belt needs to be replaced in my hoover spin scrub
    Remove the brush cover. Check belt for cuts or stressed areas.
    Is the belt taut or stretched to the point of being loose. If you see
    any of this replace with the correct size. Pull brush bar out of the
    side slots and remove belt from motor pulley. Place new belt on
    pulley and onto grooved area on the bar....stretch forward and
    push back down into side slots. Remember....groove in brush bar
    must line up with pulley. This is also a good time to remove hair
    and other stuff from the brushes and bar.
    Regards,
    Dennis
    Aug 22, 2014 | Hoover SteamVac F5914-900 SpinScrub...
    Why does Beater Bar Fail to turn
    Per owner's manual
    1. Make sure the brush control is set on carpet mode.
    2. The brush will only spin when the handle is reclined.
    Others:
    The belt has worn out and needs replaced. Although it appears okay, stretching is possible, which would result in too loose a grip to turn the bar.
    If the belt was replaced, it may not have been pulled tight enough to turn the bar. To tighten on many vacuums, simply loosen the screws on each end of the brush, pull toward the front of the power head and hold while tightening the screws.
    Jul 25, 2014 | Dyson DC14 All Floors Upright Vacuum...
    Belt no longer turns the brush
    JKGonzo:
    You'll need to open the vacuum head and remove the beater bar. Clean up the bearings at each end of the beater bar and reassemble the head.
    May 25, 2013 | Rainbow Vacuums
    Twirly thing under the vacuum has stopped spinning
    there is a belt that drives the beater brush. flip the unit over, you can remove the bottom cover by removing a couple of screws. to one side of the brush you will see a channel where the belt should be. go to you local walmart, sears or hardware store and in the vaccume section they will have belts, on each bag of belts will be a list of vaccumes that belt fits simply find yours. with the new belt simply lift the beater brush out at the belt channel side and install the belt around motor shaft and brush. then place brush back in place , be suer brush guides are in properly. this should do ya.
    Aug 18, 2009 | Dirt Devil Featherlite Bagless Vacuum...
    Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
    525 people viewed this question
    Top Hoover Vacuums Experts
    Jim Parker
    Jim Parker
    Gerry Harvey
    Gerry Harvey
    Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
