Question about Kenmore 24 in. 15252 / 15254 / 15259 Built-in Dishwasher
Kenmore Dishwasher Not Sanitizing
Although my dishes come out clean, dry and spotless, the green "Sanitized" light no longer comes on after the load is finished, only the "Clean" light is on. This problem occurs even if the sanitize button is lit prior to starting the load. Is there an additive I'm supposed to add in order to get my dishes sanitized or to get the light to work, do I have a burnt out sanitized light or do I have a bigger problem?
  • 2 more comments
  • CGdad Nov 17, 2007
    Thanks for the help, but that diagnostic mode did not work on my dishwasher. Maybe its a different method for my model.
    Model #: 587.15072201
    Serial #: TH33587060
    I tried to find a manual for my dishwasher, but had no luck at all.
    Thanks again for all your help.
  • CGdad Nov 19, 2007
    Thank you very much for all your help, I guess it just needed a little diagnostic testing. After a test load the "sanitized" light now comes on.
  • Anonymous Mar 16, 2014
    The clean and sanitize lights do not come on sometimes,
  • Anonymous Mar 23, 2014
    i set the dishwasher to sanitize and when the dishwasher is done, the light is not on and the dishes have a white film
  • 290 Answers
You don't need an additive.
The sanitized LED itself is probably out.
It will not light up if the sensor doesn't sense that the water has reached 155 F. If the dishes are getting clean, I assume the heater is working properly. You could have a failed sensor, but you would usually notice longer than normal wash times and the dishwasher getting hotter than usual.
Alternately press heat dry and hi temp scrub 4 times. This puts washer into diagnostic mode. The first thing that happens is all the LED's light up. If it lights up then it is ok and the problem is somewhere else.
If these instructions don't apply to your machine, please post the complete model number from the decal just inside the front of the tub and I will look it up for you.
Posted on Nov 16, 2007
  • Michael  Lindley
    Michael Lindley Nov 17, 2007
    Thanks for the numbers. This helps alot on Kenmore appliances because there are so many different manufacturers that build them.
    The 587 at the beginning of the model number tells us this is a Frigidaire product. I gave you the sequence for the Whirlpool built Kenmore.
    The manual for this machine covers different configurations of controls that you may have under the Kenmore, Frigidaire, or Amana name brands.
    You should have a tech sheet inside the lower kick panel that gives the correct test procedure for your machine. If it is missing, here are the different ways to enter test mode given in the manual.
    Hold down NO HEAT DRY and START/CANCEL buttons at the same time for 1 1/2 seconds.
    Hold down POWER DRY OFF and START/CANCEL buttons for 1 1/2 seconds.
    Hold down HI-TEMP WASH and START/CANCEL buttons for 1 1/2 seconds
    Hold down WASH BOOST and START/CANCEL buttons for 1 1/2 seconds
    One of these should put your machine into diagnostic cycle and check the controls and components.
    Post back if you have more questions.
What causes grit to dry onto dishes after dishwasher has finished?
Check water hose leading to the dishwasher for deterioration..
May 11, 2014 | LG LDF6920ST Stainless Steel 24 in....
Kenmore ultra wash quiet guard standard. Very little pressure coming out of the jets. Doesn't clean the dishes.
sounds like hard water is the problem and may have clogged the jets. clean it out really well and get the dishwasher filtration system from that will remove the hard minerals and leave your dishes and dishwasher spotless. awesome product and the results are guaranteed.
Jul 08, 2013 | Dishwashers
Kenmore Quiet Guard
You dont really need it, when the washer gets done Open the door for a minute and let the steam out and shut the door dishes will then dry. the reason there still wet is because of the steam from the Hot water
Sep 16, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore elite dishwasher does not dry
one of the buttons on the door will give u heat, just push that button
Apr 19, 2009 | Kenmore 18 in. 14432 / 14439 Built-in...
Glassware and dishes getting water spots lately.
I think your dish washer is starting to go out. We have a Kenmore dish washer (unsure if the model is the same), it started with not cleaning the dishes well to not sanitizing and now it doesnt dry. We are actually replacing ours today. We we noticed that it wasnt cleaning properly (water spots, or not rinsing well) we too added Jet Dry thinking that that would solve it. We soon discovered that it didnt help at all. Hope this helps you.
Mar 17, 2009 | Kenmore Dishwashers
How long is wash cycel in dishwasher. dishwasher does not seem to advance beyond the wash cycle
Normal wash cycle is as follows..
Wash1 8 min
Rinse1 10 min
Wash2 21 min
Rinse 10 min
Rinse 12.5 min
Dry(hot or cool) 23.5 min
Total of 85 min
thats just a normal cycle. Pots and pan cycle is of course longer
Nov 13, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Turning on dishwasher
although the light may be a true indication of a pending problem, try this test: Find the circuit breaker and switch it off to remove power to washer for 30 minutes. Then power back up. Any changes? If light still on, then threat of trouble is real and must be fixed. Not sure what to CLEAN, though. Search for manual online...I'm sure Kenmore put that light on for a real purpose.
Jun 14, 2007 | Kenmore 24 in. 15252 / 15254 / 15259...
Kenmore 24 in. 15252 / 15254 / 15259 Built-in Dishwasher Logo
1,276 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
