Question about Compaq FS 7550 17" CRT Monitor
Fuse blown repeatedly on CB553H-KL
I've got a fuse blown T5AH250V and i replaced it and the fuse blown again. what is the problem of my monitor? Can anybody help me fix my LG CB553H-KL monitor
    Brigadier General:
  • 6,966 Answers
Re your post/description on an LG CB553H-KL fuse blowing, this is indicative of an over current (>5Amps) flowing through the AC mains supply. If you are comfortable doing component level repair and familiar with electronic parts/circuitry, continuity tester and a soldering iron, please do passive (off-board) test of the following components:
D900 - bridge diode;
C908 (150uF/400V) - filter/power capacitor;
Q901 - regulator.
If Q 901 is shorted, pls likewise check ZD901, D910, R902 & 915.
Just to be sure/safe, check also:
C901, 902 & 904;
TH 901 & 902;
Though unlikely, you may want to check also:
Q706 - Horizontal out transistor (attached to the aluminum wall acting as heatsink;
FBT - Flyback transformer.
Other than the component aforementioned, no other parts would cause enough current flow to blow the fuse. But of course, anything can still be wrong
Hope this be of some help. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Nov 16, 2007
    Scholar:
  • 160 Answers
if it is under warranty contact the vendor where you purchased.  if it is not under warranty do not do on your own.  Contact the nearest expert to fix the error.  Its not only the fuse problem because you are saying that it had burnt so the corresponding ics may also got damaged.  Its better to contact the expert.
Let me know if your problem is solved and rate me as FIXYA!
Posted on Apr 25, 2008
Describe your samsung syncmaster 204bw Problem: I turn the monitor on, the power button turns blue, the screen remains dark, the image on my Powerbook G4 appears flashes on the screen before it goes black...
Check the power supply DC filter cpas first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Nov 08, 2010 | Samsung SyncMaster 204BW LCD Monitor
Monitor goes off and on repeatedly and intermittently. Sometimes stays on for quite a while then goes off for no reason then on again, etc., etc. VERY annoying! HELP!?
It may hace cold solder joints, failing DC filter caps, lamp assemblies.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Replacement board: http://www.lcdrepair.us
Oct 21, 2010 | Dell E173FP 17" LCD Monitor
Image comes for 3 or 4 seconds and them goes off for 20 or 30 seconds. This is repeated again and again.
Check the DC filter caps.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Oct 12, 2010 | AOC LM729 17" LCD Monitor
My Samsung SyncMaster 171N starts up with the computer and stays on but the video dissapears within seconds until i turn it off and back on again at which time it just repeats... what's the problem and how...
Look for bad caps (leaking/bulging tops) as shown in my albums, it is very common problem on all brands of LCD monitors.
Sep 13, 2010 | Samsung SyncMaster 203B LCD Monitor
Monitor goes black immediately after waking from sleep, at the same time the power light changes from green to yellow. Image is just visible on black screen when viewed with a torch, After a wait of about...
Common problem in this model is bad DC filter caps, that will be the first place to look.
Sep 01, 2010 | HP Pavilion F1523 15" LCD Monitor
Backlight repeatedly turns off
Replace the backlight.
Google your make and model, lots of places selling replacements
Jul 31, 2010 | Belinea 10 15 55 15" LCD Monitor
Monitor comes on after repeated use of on-off
You may have failing power supply DC filter caps.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Jun 18, 2010 | Gateway FPD1960 19" Flat Panel LCD Monitor
LG CB553H monitor has power and menu that sais no data. When I connect to a pc there is no display.
A monitor display showing "No Data" indicates that either the PC is not sending any usable video signal or the monitor is not capable of displaying the incoming video signal. To determine which is at fault, you would need either a known good second monitor or a known good second PC.
Additionally, it is also possible that neither is at fault and that you simply need to lower down the Screen Resolution and/or the Screen Refresh Rate of the computer's display properties to match the limitation/capability of the monitor. A method of verifying if this is the case is to start the PC in "Safe Mode" by pressing F8 after POST before Windows boot.
Alternately, there are some instances that it is the video cable that is the issue. To verify, you can try wiggling the cable to the connector end that goes to the PC's Video output.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Thank you for using FixYa.
Jul 02, 2008 | Compaq FS 7550 17" CRT Monitor
T5AH250V
Hi there
You can buy it from your nearest TV or AV Repair shop.
Apr 01, 2008 | Panasonic PTL-520U 2000 ANSI lumens/SVGA...
Compaq FS 7550 17" CRT Monitor Logo
345 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
