Question about Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive
My computer completely doesnt see my WD Passport 320gb
I plugged my passport in and it worked fine, then I had the great idea of putting all the files that were already on the device into one folder. Since then I haven't been able to see it let alone do what everyone been talking about.
Please help.
    Sergeant:
  • 175 Answers
Try to use another USB port. Verify hardware status from Device Manager. Try to Uninstall your Passport device from Device Manager and reboot your system.
Just remember to take your time and don't get nervous working on the computer. Please report back to the thread the results of your work.
Regards;
Hassan
Posted on Jul 12, 2009
There is an i/o error on some images and music files, on WD passport external hdd
The disk-drive inside the case is "dying".
Try to copy all the files that you can, before it's completely "dead".
Then, if the drive is still under warranty, exercise the warranty to get a free replacement.
If not under warranty, WD has a "customer loyalty" program -- take the serial-number, and buy a new Passport from WD's web-site, citing the serial-number, to get a big discount on the purchase.
Oct 01, 2010 | Western Digital 320GB MyBook External USB...
Can only see one WD Passport 320GB drive at a time.
This is most likely a classic case of them trying to occupy the same drive letter. If you open disk management Start > Run > type 'diskmgmt.msc' and you should see them both there - One with a drive letter and one without, simply right click on the drive which doesn't have a drive letter and select 'change drive letters and path...'. Change the drive letter to something you know doesn't really get used and they should both appear in my computer.
Hope this solves your problem.
Jan 12, 2010 | Western Digital Passport 320GB External...
My western digital Passport 320Gb usb drive is not detected
hi ,
looks like u primary hard drive is inside the laptop and so should be displayed as c : drive ,
and the reason , the external hard drive is not displayed seperately is csue ., the external HD  may be added as slave to the internal HD .,
can u tell me ,make a right click on c:/ drive and choose properties : and tell the totalsize dispalyed
Jul 23, 2009 | Western Digital Passport WDXML800UE...
I have a WD Passport drive that I want to use through a Targus mini USB hub. The Passport drive has power, but it will not install through the hub. Apparently wants a driver and apparently they don't have...
The reason your full sized drive works fine and the passport doesn't is that the full sized drive has it's own power supply and only uses the USB for data transfer. The Passport drive requires much more power from the USB to spin up, so, if you want to run it through the USB hub at the very least you will need to replace the USB hub with a powered one.
As for a driver, you don't need one to use the passport on XP that's why you can't find one but the Passport does require a dedicated port(2 for Amperage on some systems) or will need to be plugged into a powered hub or it simply won't get enough juice to fire up. That is the reason it won't show up.
In short, buy a powered hub, or plug it in direct. Nothing else is likely to work.
Hope this helps figure it out
Chris
May 07, 2009 | Western Digital Passport 320GB External...
WD passport 320GB Can I use it as storage, not backup?
You can use it as storage if you would like. You can also delete files once they are put on the passport. When it is connected to the computer open my computer and it will be listed there. You can use it as storage by copying files into this way rather than syncing it. Syncing it could cause you to lose files.
Apr 29, 2009 | Western Digital Passport 320GB External...
320GB WD passport essential works with XP os but not with vista
both of my vista machines worked perfectly... i am not using the software that came on the drive. as a mass storage device it works perfectly.
Jan 29, 2009 | Western Digital Passport WDXML800UE...
WD Passport Drive Lights Up But Compu Does Not Find the Drive
Does your drive make any unusual sounds like any of these: http://datacent.com/hard_drive_sounds.php ?
If yes then you got a problem - it's something mechanical with the heads.
If it sounds normal or doesn't spin up at all - try to connect it to another computer and if still no go - remove the internal drive from enclosure and connect directly to PC via SATA port.
Sep 29, 2008 | Western Digital Caviar SE WD1600AAJS 160...
Can I use my passport essential 2.0 to backup my work computer as well as my home computer?
You can use your WD Passport to sychronize data on multiple computers, you just need to set up the other computer name (e.g. "Work computer")using the software.
WARNING: Do not think that theyourWD Passport, using the WD Sync software, is a
backup drive; it is NOT !
As per the documentation with this device:
"synchronization software is intended to synchronize the data from a
computer to the drive (WD Passport) and SHOULD NOT be used as backup
software. To use this software properly, we advise that you do not wipe or
erase the data from the internal hard drive (computer) and resynchronize, as
this will cause the data that WD Sync stored to the Passport to be deleted."
This is why you are hearing so many people saying that they are deleting the
WD Sync software, reformatting, and using the WC Passport as a true backup
drive where you can actually see the files that you are backing up, rather
than a bunch of unrecognizable sync files that likely don't have all the files that you thought you "backed up".
Aug 03, 2008 | Western Digital Passport WDXML800UE...
Hooking up the WD Passport to a USB enabled CD/DVD player possible?
hmmm...it may just be a capacity and interface issue, with the flash drive being more 'accessible' through the USB interface than the wd passport.
Big issue..is the WD on USB 2.0, and the CD/DVD on USB 1.0?
Mar 10, 2008 | Western Digital Passport WDXML800UE...
Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive Logo
575 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
