Question about Vacuums
The brush spins but the the dirt is not getting into the bag. i cleaned the hoses now it's not sucking anything up.
  • 691 Answers
If the motor is running you should get some kind of sucktion, if no sucktion or wont blow any air out, check the house making sure is clear of any obtruction, the best way is looking in the house by have one person hold one end and other pull the house straight and look to see any obstruction. if it seem clear, check the motor attach to the fan, yep you have to take the cover to the motor off with phillips screw driver in order to see what causing motor not to **** although the motor may not be attached to the fan; could be loose and not spining the fan to create any sucktion. hope that help some..good luck
Posted on Jul 12, 2009
My dirt deivl want pick up dirt that well. what is the promblem?
Most likely, it needs to be cleaned out. Change the bag (or clean the dirty cup), change or clean all filters and hoses . Clean the brushes. It probably sucked up some water and combined with dirt it clogs up filters and hoses.
Oct 18, 2011 | Vacuums
I have an older upright machine, which has been a great workhorse. It's not picking up suddenly, it seems like the dirt isn't getting sucked up into the bag. Motor sounds good and the brush is spinning.
It probably needs a thorough strip down and clean out as the suction is reduced. Check all pathways, hoses filters etc. and clean out any dust and blockages, also use a new bag after as the bag forms part of the filter.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way.
Mar 05, 2011 | Electrolux Vacuums
No Suction
it is probably the dirt fan. u may have to get it serviced
Jul 09, 2009 | Dirt Devil Featherlite Bagged VacuumVacuum
Vacum not sucking the dirt and the light is not turning on
loss of vaccum brush head not spinning check belt turn over remove bottem plate check belt assmble. remove any string or hair build up sear is the best bet for the belt
Mar 31, 2009 | Kenmore 34923 / 34925 Progressive Bagged...
Not sucking up dirt in upright position
if there is dust flyin around the vacuum u might try lookin for clogs on the bottom where the beater brush pushes the dirt in and maybe where the dirt goes into bag ive used wire clothes hangers to free em up works..hope this helps
Dec 06, 2008 | Dirt Devil Vacuums
My vacuum doesnt **** dirt from the floor but sucks dirt with the nozzle.
Probably have a clogged intake from the beater bar thru to the vac system.. Try this.. with the vac unplugged, flip the vac over so you can get to the bottom of the vac head near where the brush rotates.. then depending on the model.. remove the cover to access the brush ( called a beater bar).
Once the cover has been removed ( may require removing several screws) .. look at the beater bar and make sure the belt is hooked up.. you should be able to lift that brush assembly out of the housing to expose the duct where dirt travels into the bag.. that path ( including the flex hose) is probably clogged up...clean out any debris found there.. ( if you have access to another vacuum..try sucking that junk out with it or use a stick or coat hanger to pry anything lodged in there out.. When that is clear, reassemble things and try it again.. Hope this helps you
Sep 23, 2008 | Eureka Vacuums
Dirt devil mvp not sucking
Could be bad filters, is there suction at the end of the hose. That will tell you which direction to start looking. If no suction at hose end, then filters could be the problem. If you have suction, then the problem is down lower, dirt inlet is clogged, if belt has never been changed, then I am sure it has stretch to the point that under load it doesn't turn like it should. Could even be that although the motor is running, it may be running at a slower speed, in which case it would have to be replaced.
Oct 14, 2007 | Dirt Devil 12 Amp HEPA Filter Vacuum...
My dirt devil vacuum won't suck up anything and its brand new!!
Take the vac bag off and turn on the vac , it should blow air out, if not unclogg the hose where the bag connects, also when you check the roller and belt, unclog the flex hose(located inside base near roller assembly) that sucks up the dirt. As long as the motor works fine the rest is just maint.
Mar 30, 2007 | Dirt Devil M085805 Upright Vacuum
Vacuums Logo
167 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
