Question about Maytag MFD2560HES Bottom Freezer French Door Refrigerator
Noisy compressor The compressor is making quite a bit of noise when the electrical connection clicks on and stops when the connection clicks off. I've checked that the fan isn't a cause and that the rubber mounts are firmly seated. This happens every three to four minutes and makes the noise for about 15 seconds or so. Any suggestions?
  • 248 Answers
If it's a buzzing for a few seconds followed by a click, your probably going to need a compressor. This sounds like that problem. Check your warranty. Many manufacturers went to 1 year on this in '06.
Posted on Nov 16, 2007
Suddenly very noisy when running and makes a loud clunking noise when it stops.
Your Compressor is wearing out. Better be prepared for it quitting all together
Mar 09, 2016 | Kenmore Freezers
Noisy compressor
Is the compressor running when you hear this noise or is it noisy when it is trying to start. If the noise you are talking about is the click it may just have a bad relay on the compressor. If it is a loud humming noise when the compressor is trying to start then the compressor is locked up and needs to be replaced. Compressor comes with a 5 yr warranty and relay has a 1 yr warranty.
Nov 16, 2007 | Maytag MFD2560HES Bottom Freezer French...
Flame effect electric fire loud clicking noise
You need a new synchronous motor. This is the small motor which turns the flame effect rod. They are notorious for becoming noisy.
Nov 06, 2012 | ACE Dimplex (r) Compact Electric Fireplace...
I've problem my fridge make it noise & ice
please provide make and model number of the fridge.
also what is the problem. Is it too noisy in operation and there is lot of ice in freezer.
Check the freezer door seal has not come off and the compressor at the back is not too hot.
Oct 13, 2011 | Refrigerators
Why is this kettle so noisy
Kettles generally do this, Here's why: As it's heating up, the water next to the element turns to gas and starts to rise to the top. Since the gas bubbles are small at first, they turn back to water before reaching the surface and water rushes in to fill the space - this is what creates the noise. When the element gets quite hot, however, it can convert the water to gas more quickly which creates bigger bubbles that float to the top and burst into the air.
So, the longer it takes to heat up, the longer it makes noise. Some kettles have a more powerful element that simply gets to the second stage more quickly. The 'cordless' ones like yours have a smaller connection from the power to the element and it takes a bit longer. Worthwile, considering the convenience, in my opinion.
Mar 02, 2011 | General (102105011) Electric Kettle
Viking side by side refrigerator noise
sounds like your fridge is not hooked up to water or water off
the sound is the water valve calling for water if no water is hooked up or supplied the valve is quite noisy
turn water on or lift icemaker arm to up lock position to turn ice maker off
Mar 04, 2017 | Viking VCSB423 Side by Side Refrigerator
I HAVE 4 EA NEW LHD659EBK DEHUMIDIFIER and they make lots of noise and vibrate a bit, this is normal in these Dehumidifiers ..
These can be noisy.
Does the noise only happen when the compressor runs? These compressors float on rubber bushings to isolate the vibrations and maybe one of the three nuts on the mounting studs may be loose.
The fan bearings can also wear out.
Nov 21, 2009 | LG LHD45EL Dehumidifier
Model kbr20etss01 very noisy when compressor is running
If the noise seems to be coming from the compressor That's usually mounts inside the compressor. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge.
Also you have two fans which run when the compressor runs. One is next to the compressor and the other is behind the rear cover inside the freezer. One of them can be hitting something or the fan motor itself could be making the noise which would be a bad motor.
Oct 20, 2009 | KitchenAid Refrigerators
Clicking of Ge Model PDS22SBRBRSS; serial No; DL047209
IF the below mentioned information does not help, then contact a elextrical engineer worksman who can check the circuit board as it might also cause a short cicuit.
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting).
  • The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
  • If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.
  • The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
May 31, 2009 | PDS22SFS Stainless Steel
Noisy compressor
im sorry to inform you that you may have a bad compressor that needs to be replaced. try checking the potential relay located at the side of the compressor and also check the over load relay at the same spot where the potential relay is. be carefull, the compressor is very hot. if they are ok, then you have a bad compressor.
Feb 25, 2008 | Maytag MBF2556HEW / MBF2556HEB /...
Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
216 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
