Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I have a craftsman LT1000 and it will run for about 20 min and die like it isn't getting gas,but it start right back up and die in 1 or 2 min.i changed coil,air filter fuel filter and seat switch,and solenoid.
  • 1,273 Answers
Try cleaning your gas cap vent. It sounds like it may be partially plugged. If it is plugged, the engine will eventually stall.
Regards!, --W/D--
Posted on Jul 15, 2009
Craftsman lt1000
If it has overhead valves, get the specs from the engine manufacturer and reset the valves. this should cure the problem.
Apr 16, 2014 | Garden
My craftsman 200mph/430CFM 25cc leaf blower will start and last for about 5 mins. on half choke and then die out and not start. It cant be put on run or it will die right away.eplaced spark plug. Still...
check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.May need to clean or replace carburetor.
May 12, 2012 | Craftsman Garden
22 In Craftsman Self propelled.Starts easy, runs good for about 15-20 mins. Starts missing and dies. Will start again in about 30 mins New spark plug/ air filter
Oh my, that is so annoying. There is probably dirt in the carb. or the gas tank. What I think happens is, the dirt gets sucked up into the fuel line and clogs the carb, then when the mower sits for a while the dirt goes back into the tank for another couple minutes. I have absolutely no tolerance for this when it happens.
Aug 05, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
Lt1000 20hp. briggs electrics on carb it will run when you pour i
Check fuel lines for clogging.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 13, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
20 HP Craftsman lawn tractor starts easily, but only runs
This is classic dirty gas filter ... I dont say that is all it could be ... but is it classic dirty filter. You might have something in the tank that is blocking gas getting out of the tank.
check it out ...
Oct 20, 2009 | Garden
Craftsman LT1000 ridign mower engine dies after 15 min-deadman on
There are several things that could be going on, but what you said in your description about the dead man switch in the seat may need your attention first. The switch it self could also be bad. After you rule this out the next thing I would check is the fuel shut off solenoid located on the carb when you turn the key on to run you should hear a click and feel it in the solenoid. After this you may have a fuel pump issue or a coil issue. but from what you I have described I believethe first 2 itmes I mentioned should fix your problem
Oct 08, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman lt1000 18 hp briggs keeps wanting to die
could be a dirty carb. Did you use stabil over the winter. Also could be a govener problem.
Jun 23, 2009 | Garden
Craftsman LT1000 starts for awile then dies.
try adjusting the fuel-air ratio on the carb. sounds like it keeps flooding,
Jun 09, 2009 | Craftsman Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
786 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
