Question about HP Photosmart C7280 Printer
Printer always sends a blank page thru 1st, then prints the page I have sent to the printer
  • 34 Answers
Try this... ">
Posted on Apr 11, 2011
  • 32 Answers
Check this Fixya post: click here. This problem sound very similar.
Hope this helps,
-samson39
Posted on Jul 26, 2009
I can send but it is a blank piece of paper whats the problwem
I imagine you are using a fax to send a copy in which case the printed page goes face down ( the faxing process actually scans the page , turns the data into signal , transmitted by line to the receiver that deciphers the signal and turns it back into readable data
if you put it in printed side up then the receiver will get a blank page as it is blank on the back of the page
Jan 28, 2016 | Office Equipment & Supplies
My cannon D680 prints a blank page after every print or copy job. the pages print fine but at the end it always feeds 1 blank page. what can it be?
See if there is an option in your settings to print a "job owner" page after each job. That's not what it's actually called but I had a similar issue with a Canon printer and found that you can have the printer automatically print a page after the job that identifies who sent the job to the printer. It's the last page so it lands on top of a finished job and separates it from other jobs sent to the printer before you have a chance to get yours. If you don't have network identifications associated with users it may just print a blank page as a separator.
Jan 14, 2015 | Canon imageCLASS D680 Laser Printer
Paper lodged in printer. First green light on printer flashing. Then the printer was not printing. It sent paper thru blank. Then in took in about 12 pages at once and became lodged???
Turn off printer and computer, remove logged in paper, turn both on again and try to print anew.
That should do it.
Good luck & God bless!
Mar 03, 2011 | HP Deskjet 3747 InkJet Printer
I have an HP C7280 AIO printer. Everytime I print, it always form feeds a blank page bewteen each printed page (print page 1, form feed a blank page, print page 2, form feed a blank page, and so on).
Generally, there are printer set up programs that will let you chose to put a blank sheet or to not do that. If you have a disk or manual, look for the set up utility and go thru the tabs to find paper handling or something similar to that. There should be a check box you can clear to stop the blank page.
I hope that this information was helpful. Have a great day.
Brian
Jan 24, 2010 | HP Photosmart C7280 Printer
The printer is issuing blank sheets - every other sheet being dispensed by printer is blank - i.e. without printed data
This could happen if the text you are sending to the printer spills over slightly onto a new page. To test for this, press Ctrl-P and select "Current Page." This will insure that only one page is being sent.
Aug 12, 2009 | Lexmark Office Equipment & Supplies
The printer is printing an addition page each time a page is sent
Are you using a custom written language application or are you using an application such as Word?
It appears that you are using a PJL wrapper around the print job. Please create a print to file (off of the driver screen) and send it to me at janddgasrepair@verizon.net. I'll be able to look at the job and see what ie happening.
Right now I suspect that you are not clearing out the PJL properly.
Don
Apr 04, 2009 | Lexmark T520 Laser Printer
Faxing multiple pages
If it's only one page.. just place it on the glass face down.
When faxing muliple pages you must place them in the automatic document feeder located on top of the machine.
Place all originals print side up (up to 35 pages). A message will show up in the display letting you know original were loaded up properly. Let me know it this helps.
Apr 02, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP LASERJET 4PLUS PRINTER-PRINT OUT BLANK PAPER AND WITH ERROR MSG 41.3
Get a new printer.
Serious if it is happening repeatedly and it is not because of corrupt data like a bad file being sent to it, then tis biga buckas any way you go, replacing the laser or the Main Control Board. From your description it will be laser, laser units wear out because inside is a little motor working real hard and eventually they wear out or main board the brains behind the operation has lost the plot
here is the code description from manual
41.X Printer Error
A temporary printing error has occurred. The page containing the error will automatically be reprinted. If the error persists:
1. Reseat the connections to the laser scanner and then to the engine controller board.
2. Replace the laser scanner.
3. Replace the engine controller board.
Nov 20, 2007 | HP LaserJet 4 plus Printer
HP 5550 Print issue
When you removed the jammed paper , the jam paper sensor was not reset or positioned correctly. The reason the machine was sending two pieces of paper thru at once was probably due to the paper feed sensor. A lot of H'Ps do this. Try re-aligning the tray and if you pulled the paper out and heard a grinding noise, the whole feed unit is probably out of time.I would only re-install the software as a last resort, since your problem was caused by hardware, not software. Scrivitron
Jun 20, 2007 | HP DeskJet 5550 InkJet Printer
Prints only the 1st page of info. sent by adobe.
No, it is definitely your printer. You need to uninstall it and reinstall it to correct issues.
Nov 18, 2006 | Canon PIXMA iP4200 InkJet Photo Printer
HP Photosmart C7280 Printer Logo
93 people viewed this question
Seeker5211
Seeker5211
