SOURCE: Batteries are charged, scooter won't move, no power to display
It is impossible to overcharge with the Pride charger. When the battery is full, it will stop charging and check about oncew a miute to maintain the charge.
Now, when you plug in the key (looks like an audio headset jack) does the battery meter indicate a full charge? Also, the scooter will not move if its in free wheel mode, and it will not move if the charger is plugged in. Beyond these first steps, you will need a voltage meter to troubleshoot.
SOURCE: shoprider cadiz scooter, batteries show full
I think your batteries haven`t been charged properly,or they have been left standing so the charge has leaked out.At a minimum your batteries need to be charged for 12 hrs a day for the first month if not they will not build the capacity and will dwindle and die for example it is at only 25% capacity,but looks like a fullcharge, it says it fully charged but will die
quickly this happens because it is charged to its full capacity but that is only 25% of the batteries true potential
resulting in short battery life.
Unfortunately majority of scooter batteries like this have to be newly replaced.
SOURCE: I have purchased new batteries for my mobility
The control seems to be the issue. I have rewired so many scooters. When you have power and it wont go, it is usually the control. If you cannot afford the part right away, you can rewire it or have it rewired direct
SOURCE: Require instruction book for DMA Merits
PRIDE pdf
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Battery isn't charging, no handbook
be sure of model etc & order a manul from the dealer,then once read the basic guides,if no joy then book will advise you to get in touch with a qualified dealer.
