Question about Leisure HOMEPRIDE Electric Fireplace Heater w/ Remote
I just need to know where to getan o/off switch> It is easy to replace.
    Champion:
  • 233 Answers
Try johnstone or graingers
Posted on Jul 12, 2009
Patch not saving,write button is not working from the day i bought.i bought is 2nd hand.plez help
If you buy a second hand, it may have been damaged in mini switch (tact switch) under the WRITE button. You need to replace the tact switch. Easy and inexpensive, you can do yourself, only with a little knowledge of soldering
Tact Switch:patch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-1.jpeg
You may also try the FACTORY RESET.
Restoring the GT-10 to the settings made at the factory is referred to as a "Factory Reset."
Not only can you return all of the settings to the values in effect when the GT-10 was shipped from the factory, you can also specify the range of settings to be reset.
If you do this"Factory Reset", all the setting on user memory (that you create) will be erased, so backup your setting before doing this steps.
patch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-3.jpgpatch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-6.jpg
For more detail on "Factory Reset", read the GT10 user manual:
roland.com/support/article/?q=manuals&p=GT-10&id=1810803
Sep 16, 2015 | Roland Boss Gt-10 Guitar Effects Processor...
Is it comon to find metal shavings when you getan oilchange
No, this indicates internal engine wear and is not a good sign.
Sep 07, 2014 | 2002 Pontiac Sunfire
How to disable "Switch Control" on iOS 7?
Settings ---->General---->Accessibility---->Scroll down ----->Switch Control On/Off. Press Home button to save.
Jan 23, 2014 | Apple iPhone 5S
Turn signal switch when turning off signal keeps making clicking noise
Replace flasher, if that don't work, you need a new blinker switch. Hope this helps, this is a easy one for you. Thanks mike
Jun 17, 2011 | 1999 Pontiac Grand Am GT
Where is the ignition switch located on a 2000 pontiac grand am gt.
you put your ignition key into the lock cylinder. if you put the right key in, it fits and turns the ignition switch. so your ignition switch is more or less directly behind and in line with your key when it is in the lock cylinder. inside the steering column. it is not easy to get at, and you will find that special anti-theft tools are needed to replace it.
Apr 20, 2011 | 2000 Pontiac Grand Am GT
Need visual instructions for 600w-120v ac/c.a./ca 60hz
1) If you are replacing a switch that has two wires, and your dimmer has two screws > then Connect these wires to either screw.
2) If you are replacing a switch that has two wires, and your dimmer has three screws > then Connect one wire to dark-colored screw, and connect other wire to either brass-colored screw.
3) If you are replacing a 3-way switch that has 3 wires > and your dimmer has three screws > then pay close attention: One of the wires on your existing switch is connected to dark-colored screw. Mark that wire. It connects to dark colored screw on dimmer. The other two wires connect to either screw. The dark-colored screw is called the common terminal.
IF you have already removed switch and do not know which wire was connected to dark-colored screw >>> then connect the wires to any screw on dimmer >> turn on power and check if the circuit works >> keep rotating wires until they arrive in the right order >> the circuit simply will not work until the to correct wire is connected to dark-colored screw
THE dark-colored screw is the key
Oct 10, 2010 | Cooper Wiring Devices Aspire Smart Dimmer...
GSS23WSTA refrigerator freezer section is getting warm.
Just the fist indication that defrost is not taking place. Most likely the defrost heater and defrost thermostat will need replaced. part number Click Here=> WR51X10101 for heater and will be easy to spot if burned out and you should also replace the defrost thermostat just in case part number Click here=> WR50X10068 Let me know if you need assistance, you may reach me through Appliance 911 or Sea Breeze Appliance Parts and Technical Services
Thank, Sea Breeze
Dec 25, 2009 | GE GSS23SGSSS Stainless Steel Side by Side...
No power to oven after removing light bulb
What happend is that when the bulb broke the filiments touched (shorted out) and caused the reset switch on the unit to set>>>you need to find the reset button on this unit, look at your service manual. Additionally on some units there is a fused link internally, that may have blown>>>>both are an easy fix, so dont throw it out.
Good luck,
Geodesy
Sep 22, 2009 | LG Over-the-Range Microwave
Oil shoots out bottom only after starting car. The plug has already been tightened.
Hi,I am Ron,It really sounds like a oil pressure switch that has gone a leaking.This can be purchased at your local auto parts store and is fairly easy to replace.The part is not to costly.This is what tells you that the oil presure is not good in the engine.It could be a oil light or a oil gauge,either one will leak,or in this case shoot out.If I can help,let me know.>>>roniecon@gmail.com
Aug 16, 2009 | 1999 Ford Explorer
Need new switch for Shopvac QSP Pro 10 gallon unit
I just went through the same problem with a Shop Vac. The switch is easy to replace but not easy to find. After removing the switch, I found a match made by Sigma Switches. They directed me to contact a local RV dealer and look in either their Coast Supply or Stag/Parkway Supply catalogs for the appropriate switch (an H2-28 in my case for a QPL45 Shop Vac). After ordering the switch and $5 later, it snaps in like the original with no problems. Certainly beats $70 for a whole new motor assembly.
Dec 28, 2008 | Shop Vac 285-00-10 Back Pack Vac Wearable...
Heating & Cooling Logo
59 people viewed this question
Top Leisure Heating & Cooling Experts
Paul Carew
Steve
Colin Stickland
Colin Stickland
Are you a Leisure Heating and Cooling Expert? Answer questions, earn points and help others
