Question about Clarion M235-RET CD Player
I can not get any sound from any of the four speakers. It appears to be wired correctly. Is there a fuse somewhere that may be blown
  • 11 Answers
There is no fuse goning to speakers. Fist take a 9 volt batt. and test each speaker to see if there are wired correctly. Then try again. If no sound take raido back..
Posted on Jul 12, 2009
I replaced the radio in my 98 expedition and no sound from speakers
Your car stereo may have an auxiliary amplifier. The fuse for that may be blown and not turning on and no sound coming out.
Mar 28, 2015 | 1998 Ford Expedition
2009 Jeep Sahara sub woofer not working
if the wires are connected then you ether have a blown amp or sub. try hooking up a diff speaker to the wires if it works your sub is blown. if it doesnt your amp is blown
Mar 13, 2013 | Audio Players & Recorders
No sound from speaker when on
You have a blown fuse....
looking at it from the back there are the four fuses [] [] [:] [] the third one over. If not that one and none of the four sub fuses are blown then it's your connection somewhere
Jan 21, 2011 | RCA RT2600 System
The mini fuse(2A/240v) keeps on blowing up on the power supply port, what could be the problem
You can tell a lot from what the blown fuse looks like. If it's all black or even shattered, it's likely a short circuit somewhere. If it's just blown, then you have an overload.
Another way to find out is by figuring out when the fuse usually blows. If it blows when it's tapped, shaked or moved then you have a loose wire that's touching somewhere it shouldn't.
If it blows when you turn it up high, it might just not be able to handle that much power. Remember to ALWAYS turn down amplifiers when you hear noticeable distortion. Or, the sound pressure from the speaker might be jostling things inside the cabinet.
If it blows when you plug it in/ turn it on/ start using it you've got an electrical problem, not a mechanical one. You'll need to get the multimeter and start tracing faults.
Aug 12, 2010 | Gem Sound GemSound TR-15 Speaker
How do run a dual2ohm 12 to a 2 channel amp
You need to match your amp impedance to your speaker impedance. If your amp is a four ohm amp; then follow the wiring diagram for the dual voice coil speaker to have a four ohm load. If you don't have the diagram, look up the model number on the web, it will be posted somewhere. Do not hook it up so that you are mismatched, as you will very soon have a blown amp, a blown speaker, or both!
Apr 07, 2010 | Car Audio & Video
I have a 1999 gl 1500. no sound was coming out the rear or front speakers. I have taken all four speakers out. the back were blown ohm meter said open.the front have 3 ohms. the voltage coming out of the...
not muted,or on headset, with two blown you may have a toasted radio or amp.use a headset to check for sound not voltmeterbefore replacing speakers.check all fuses.
Mar 14, 2010 | 1986 Honda GL 1200 Aspencade Gold Wing
Front speaker just quit
I doubt there is a fuse. There are only four possibilities:
1. Speaker blown. 2. Wire slipped off of speaker terminal. 3. Wires from radio to speaker is shorted (not likely). 4. Radio is bad.
My guess is speaker is bad. Try pushing the cone inward while the radio is playing to see if you are getting any sound from the speaker if you do then the speaker is bad and needs to be replaced.
Jul 07, 2009 | 2001 Harley Davidson FLHTCUI Electra Glide...
Suspected blown fuse somewhere but no sign of it
Am sure that the internal transformer is gone, You would have powered your speaker with a step up/step down transformer, you need to see a technician around you that can help you out, you need to replace a 220V-230V transformer in the speaker since your country requires that.
Jowinson
Jun 20, 2008 | Logitech X-540 Computer Speakers
Stereo display works fine, but no sound to speakers.
The wires may have gotten wet and fried something in the sound output in the stereo.
Jun 16, 2008 | Pioneer DEH-1900MP CD Player
Blown fuses
I used to have one of those amps also (nice amp btw) Did you try another fuse of the same size?
Is it blowing fuses everytime you put one in or did it just blow that one fuse ?
Is the conection on the battery solid and clean of corrosion build up? Because that is a good amp and if wired properly shouldnt blow out or anything and so if the speaker is not blown then maybe connection is weak somewhere? I would try disconnecting the speakers from it and try a new fuse and if it does not blow the new fuse than amp is ok? and if it does blow the new fuse right away then there must be a short somewhere in the wire or the amp. then disconnect the fuse again and reconnect the speakers and if the fuse blows with the speakers connected but doesnt blow with them disconnected then you know it is a blown speaker causing the problem.
Just currious but what size fuse do you have connected at the battery?
Jan 06, 2007 | Rockford Fosgate Punch P4004 Car Audio...
Clarion M235-RET CD Player Logo
105 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
