Question about Samsung HLP4663W 46" Rear Projection HDTV
I have the dreaded buzzing noise and no picture. Would a broken color wheel alone cause this or do i need to replace the bulb as well?
  • Samsung Master
  • 8,617 Answers
The buzzing noise is usually related to just the color wheel for your model.
Posted on Jul 13, 2009
Loud humming or buzzing noise have picture but flashes all different colors resets and goes off after awhile good pic after that
The tv problems and causes are 100% is the tv colors wheel it is causes and the tv problems.The tv are having humming or loud buzzing noises sounds are the causes of the tv colors wheel going off and out control of it motor mount and spinning in at high RPM speed and different colors showing up or flahes of black and white color in the tv back ground.The tv colors wheel must have to be replace.Best hire a tv tech to do the replacement of the tv colors wheel,because have to take out many mechanicals parts before can even come to the tv colors wheel is self to replace it.
Aug 19, 2011 | Samsung HLP5067W Television
Originally got blinking lights to indicate a bad bulb. Had a spare bulb that I installed. Now a very loud noise from color wheel and only a black and white picture.
Bad color wheel is cause of noise and black and white picture in tv, please replace color wheel to solve the issue.
Required color wheel is available in SamsungParts for $120
Thanks.
May 13, 2011 | Samsung HLM507W 50" Rear Projection HDTV
The TV just started making a loud buzzing noise last week, the buzzing sounds begins after the TV has been turned on for 15 or so minutes- the sound stops about 15 seconds after the TV is turned off. The...
This tv have a colors wheel. The tv colors wheel is dead.The buzzing noise is the cause of the colors wheel is spinning of is axis and rubbing sides of the motor.Hire a tv tech. for the job.Colors wheel is hard to replaced,because have to take out many other machanical parts,even before can change the colors wheel it self.
Aug 31, 2010 | Samsung HL-P6163W 61" TV
Samsung DLP HLN5065W tv Black & White Picture
Yes,the problem is the colors wheel it dead.That one of the cause by the colors wheel,other are alots of squiling noises and making very loud buzzing sound.The cooling fan that u think is overheating,does it stop sometimes,when the tv is still on?Yes,than replaced it also,no than it still ok.Just hire the tv repairman,the parts he'll take care of it,don't order the parts,u might get the wrong parts or different sizes,that will not fit in ur tv.
May 23, 2010 | Samsung DLP HL-P5663W 56" TV
Buzzing noise, just replaced the lamp, pulled and ...
The colors wheel was defective,was spinning off of it axis that was where the buzzing noise came from.Now the colors wheel it totally dead,that why u not hearing anymore buzzing noise,and not getting a picture.Hire a tv repairman for this job.Replacing DLP tvs colors wheel is not easy,if u have no machanical's skills and never done this before.
May 21, 2010 | Samsung HLN5065W 50" Rear Projection...
My samsung 42 inch hdtv is making a buzzing noise
First. The whirring or buzzing sound you hear is the Color Wheel and it needs to be replaced. Second, since I do not know when and if the original lamp has been replaced it is a good idea to replaced the lamp. The bad Color Wheel is the one causing the set to shut down.
Apr 04, 2010 | Samsung HL-R4266W 42" HDTV-Ready...
Our Mitsubishi WD52525 52" is making a loud buzzing sound. could this be a fan not functioning? We do not have a picture, but have recently replaced the bulb.
This sounds to me like it could be the color wheel or the ballast of the unit. The bulb is always the first step, but it depends on what kind of buzzing you're hearing. The ballast will usually click to ignite the lamp, while it may also buzz when it's not functioning. The color wheel will also buzz if it gets stuck, or rattle when pieces inside are broken.
Feb 04, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Screen went B&W and I hear a loud humming noise from the TV...
Hi John,
If you are hearing this noises,that's your Color Wheel.
The reason fot that is because your color wheel spins 5000rpms(revolution per minute) and something that modifies the balance if the disc can cause different things.Unfortunately in order to check if your color wheel is working properly you need to open your TV and physically check out.
Grinding= Most probably the color disc is broken and you need to replace it.
Spinning / Buzzing = The bearing of the wheel is loose and is loosing its balance,eventually it will brake.
The best thing to do is to take the color wheel out and spin it ,if you feel that the disc kind of wobbles or doesn't spin smoothly you have to replace it.
You can check DM they have very good prices
http://www.discount-merchant.com/SearchResults.asp?Search=samsung%20color%20whee l?click=52978
I hope this will help,please keep us posted
Oct 05, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HLP4663W 46" Rear Projection HDTV Logo
118 people viewed this question
Jerry Greenberg
Jerry Greenberg
