SOURCE: Can't start Chipper
Unplug the spark plug wire FIRST. DO NOT SKIP THAT. Then, WITH THE SPARK PLUG WIRE UNPLUGGED AND DISCONNECTED AND NOWHERE NEAR THE PLUG TIP, get a good sized stick, and try to turn the cutter wheel assembly in reverse. I suspect you have a piece of wood stuck in there, and it won't come loose unless you turn the thing backwards. You have to disconnect the spark plug because the engine could fire when you turn it. Even if it doesn't start, one good kick could hurt you pretty seriously. So, go unplug the spark plug and do your thing.
SOURCE: I have a yard machinne 6.5hp chipper/shredder -
The blade(s) should have usually two bolts on them depending how many blades you have. Mine only has one blade held on with two bolts and that is only on the side that cuts the larger branches up to two inches in diameter and should be sharpened on a grinding wheel because it has a specific angle to it. The other side that chips smaller branches and twigs it a type of flailer, meaning pieces of metal just swinging around to mash up the sticks and do not need sharpening.
SOURCE: How to sharpen blades on a Yard Machine 6.5 chipper
http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10151
above link will provide a pdf of manual
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
SOURCE: i have a craftsman chipper / shredder and it
SOURCE: need replacement chipper blades for 5HP tomahawk
This is the only source that I know of for the older chipper blades. Problem is you need to know the dimensions.
http://www.wesspur.com/chipper-knives/chipper-knives.html
There is an MTD one that is for troy-bilt but was not able to match it up with your unit due to pub issues here on my end: PN is MTD 1901782MA
I recommend you contact these folks to get it sorted out:
http://www.wesspur.com/contact-wesspur.html
Hope this got you pointed in the right direction.
Thanks for using FixYa.
Kelly
Testimonial: "Fantastic help. Any input is helpful particularlu when associated with other replies. Thanks again! Ralph"
