Question about Health & Beauty
What could make a Golden Compass electric scooter only run in slow speed?
  • 103 Answers
Have the batteries load tested.
Posted on Jul 14, 2009
My wheeltech mobility scooter running slow on top speed
Hi, sounds like it's due a service , that should involve the brushes being inspected and replaced if required and making sure the brake is releasing okay...
Need more info then contact via my website...
Regards
Rob
www.gewizrepairs.co.uk
Nov 22, 2013 | Electric Health & Beauty
My scooter will not start. The headlight and horn work.
HI,
I AM A GOLDEN TECHNOLOGIES REPAIR TECH.
SEVERAL THINGS CAN BE THE PROBLEM:
1. BATTERY CHARGER CAN BE BAD
2. THROTTLE POT OR SPEED POT CAN BE BAD
3.IF THE FREE WHEEL LEVER IS NOT ENGAGED THE SCOOTER WON'T RUN
4. IF THE CHARGER CORD IS PLUGGED IN IT WON'T RUN
5. FINALLY IF ALL THOSE ITEMS ARE OK YOU HAVE A CONTROLLER PROBLEM, WHICH IS THE MOST LIKLEY PROBLEM...THATS COSTLY
YOU CAN GET HELP BY LOGGING ON TO GOLDEN TECHNOLOGIES.COM AND ENTERING YOUR AREA CODE TO GET LOCAL PROVIDERS TO HELP YOU. OR CALLING 1-800-624-6374
GOOD LUCK
TIM
Apr 27, 2011 | Golden Technologies Companion II Travel...
Scooter runs then stops I turn offf the key and then it runs again and then will stop again also the scooter seems to have lost speed over time
the batteries are worn and problably need replaced , the computer will stop running the scooter at threshold voltage, older batteries and will hit this threshold voltage and slow the scooter
Jul 09, 2010 | Electric Mobility Mobility Electric Power...
My Golden Companion II scooter had to be left out when it rained - I went camping - and it stopped running. Then, a little later, when it had thoroughly dried out, it ran sporadically. Now, it doesn't...
Hi. Most speed problems on scooters, can be the throttle pot ( wig wag ), or the motor brushes.
Also check all battery lead connectors, and the motor lead connectors.
While you are driving along, try moving the speed lever slightly up and down, not in and out as you normally do. If the speed changes, it is probably a faulty pot.
Do you have a high/low switch, or an indoor/outdoor switch that changes the speed? These sometimes cause speed changes. You can fit a new switch or by-pass the switch, and have it on high all the time.
Good luck. Neil.
Jun 15, 2010 | Golden Technologies Golden CompanioN II -...
Golden avenger goes very slow with good batteries
hi,
ok so you're sure the batteries are ok, and the charger is charging the batteries ,
check the battery connections on the terminal are not loose , they must be tight but don't overdo it,
are the brushes ok ? do they move ok within the motor ? sometimes they can stick therefore you lose power and speed,
Lastly but can cause problems is the speedpot, does it have a lot of up and down movement ? you will be suprised the problems they can cause.
~Regards
GeWiz.
Dec 05, 2009 | Golden Technologies Avenger 3 Wheel...
Moving problem
More than likely its the speed pod or engager (paddle assy. This would need to be replaced.
Jun 26, 2009 | Golden Technologies Companion II Travel...
Golden companion 2 scooter moves slow in reverse
i would suggest there is either a loose connection or the speed control has failed, the scooter will still run but at a slow speed, the part is fairly standard in all scooters. if i can be any furthur assitance please email me rick @ lxrixta.co.uk (remove the spaces)
Mar 23, 2009 | Golden Technologies Companion II Travel...
Batteries aren't charging up. Chair want go.(Golden Compass)
That`s most likely your problem. When left uncharged for that long of a period,the batteries will discharge below 12 voltDC. The charger only recognizes 12 volts and up. So the charger can`t bring your batteries back up over 12 volts.  You will need to get them on a slow charger,like a car charger or have them replaced. If you know someone or have a voltmeter,set it on DC and check each battery.  If it is below 12 VDC,they need to be put on a slow charger or replaced.
Mar 10, 2009 | Golden Technologies Compass Electric...
Health & Beauty Logo
153 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
