Question about Tamron 28-300 MM XR AF F/3.5-6.3 LD ASP for NIKON AF
I have rub marks on inside of lens from contact
I have rub marks on inside of my 28-300xr lens from contact when retracted. It is a perfect circle is something out of adjustment.
Sounds like the flywheel is rubbing when running pulled transmission and it looks like the flywheel is rubbing on stater side
Does your starter fully retract when disengaging? Your problem may be one of geometry if the starter is slightly out of position it will rub on the flywheel, or the Bendix gear isn't fully retracting.Try hitting the starter with a mallet to see if the Bendix gear pops back out fully after you start your car.
Apr 05, 2014 | 2007 Mazda 6 2.0
Lens error
There is a possibility that a bit of grit or debris has got stuck in the retraction mechanism or the lens has been knocked out of alignment.
The camera will have switches inside to tell it when the lens is retracted or extended and if it doesn't make contact within the expected time then it will give this error.
If the there is no warrantee or you dont mind voiding it then I would suggest carefully disassembling the camera and turning the retraction motor by hand to see where the problem is.
Please comment again if you discover anything.
Good luck
Oct 19, 2007 | Nikon Coolpix 5200 Digital Camera
I own a Nikon D50 and the 55-200 lens will not autofocus (lens continually extends then retracts but never locks into focus). Ive read that depressing the lens release button whilst holding the lens in...
Why don't you just clean the sensors properly? Remove the lens and clean the contacts on both the camera body and the lens with a cotton swab lightly dampened with rubbing alcohol. There's a 50-50 chance something else is causing your problem but try the cleaning anyway.
Oct 14, 2010 | Nikon D50 Digital Camera with 18-55mm Lens
Kodak M863
Clean the contacts inside the battery compartment with a cotton swab "dampened" with rubbing alcohol. Do the same to the battery and the charger.
Oct 07, 2009 | Kodak EasyShare M863 Digital Camera
My camera turns on the lens retracts then turns off
a new battery(s) may fix that issue
Sep 07, 2009 | Cameras
Lens wont retract on power off.
Look at the battery near the contacts there is a little rectangle. If it's white then make sure all contacts are very clean. You can clean them with a q-tip dipped in rubbing alcohol. Clean all contacts, charger, battery and battery compartment on camera. If it's pink, you need a new battery.It has gotten moisture inside. Not your fault, this can happen from something as simple as jogging with it in your shirt pocket, yes it's true.
Aug 13, 2009 | Cameras
Lens needs to be manually opened
I just repaired this problem on my daughter's camera today! I took out the 4 tiny screws that hold the front cover on and discovered gunk and goo that were keeping the lens from retracting. Please note the exact position of the screws. They are different sizes. I then very carefully cleaned all the residue using Q-tips dipped in rubbing alcohol. It worked perfectly! Just like new.
Jun 20, 2009 | Kodak EasyShare V610 Digital Camera
Lens will not retract
It seems like some manufacturer defect in S series of samsung. I am facing the same. EIther u can get it serviced free at samsung care or just give a helping hand to the lens when its retract , push it inside with fine touch and it will come & go smooth.
Jun 05, 2009 | Samsung Digimax S730 Digital Camera
Lens retracts with difficulty
1. Do you have a camera case?
2. Or do you not?
The dust fibers from the case might have gotten into the cracks of the lens causing it to jam. So everytime it retracts, it jams. That's what i'm guessing. My old camera got jammed from sand grains on the beach.
- Take a thin strip of paper, and insert it in the cracks of the lens and circle around the lens and find any dust or anything. The paper slip should come out a bit dirty if that's the issue.
- Gently nudge the lens around, until you hear a click. The lens might have jerked into another position from the inside.
Aug 08, 2008 | Canon PowerShot SD600 Digital Camera
Camera fell off TV tray; lens bent and won't retract
i had the same problem. just force the lens back into place. I did that and it worked perfectly!
May 15, 2008 | HP Photosmart R927 Digital Camera
Tamron 28-300 MM XR AF F/3.5-6.3 LD ASP for NIKON AF Logo
41 people viewed this question
Top Tamron Cameras Experts
Steve
Jerry Greenberg
Jerry Greenberg
bhargav
Are you a Tamron Camera Expert? Answer questions, earn points and help others
