Question about Garmin iQue 3600 GPS Receiver
Updating R1 on the ique
I cant update r1, I can do 3 things only. 3 patches for r1. ALL other release
fail. Release 1 is stuck.
I follow the instruction to the T everytime. Same response. When i click on update the green light flashes on then it unit shuts off. A soft reset is required to bring it back to life.
Any help would be appreciated.
  • 174 Answers
Re: Updating R1 on the ique
If you have r1 then you can not upgrade to the latest firmware unless you ugrade to r3 first. Search the internet for r2 and r3 upgrade or call garmin and have them send you a copy of r2 or r3.
Posted on Dec 31, 2007
0 characters
3 Points
Rand mcnally 710 navi.exe has encountered error
go on lione and do the back up anbd reset to factgory setting it should be ok
Mar 05, 2013 | Rand Mcnally TND 710 GPS Receiver
Data card and frozen screen
Please reset it and your problem will be solved.
Jul 15, 2008 | Garmin iQue 3600 GPS Receiver
I have a Garmin iQue 3600, I was changing the battery, when opened the unit the switch marked rec esc on the side of the unit flew apart.I need a diagram of how to reassemble it. Thank You
iQue 3600 Undo engl.V.6 Release
Hallo -
I mistakenly IQUE3600 my system 5 at the english version 6 updated, now I have a white screen,
there's nothing more.
Please help
If your IQUE -Problem is not reparabel - I would sale it, for repair my
If your Garmin is beyond repair, I would rate this unit as a spare part for my broken
Wenn dein Garmin ist unreparierbar, ich würde dieses Gerät als Ersatzteil für mein kaputtes
Oct 26, 2010 | Garmin iQue 3600 GPS Receiver
1 iQue 3600 no Installation Disks or anything else.
You can download for free the installation disk software from You can also download a base map, but may have to buy maps from Garmin for more detailed maps/charts. You may need the serial number of the unit to unlock the maps, this is on a paper sticker under the gps antenna.
Mar 06, 2009 | Garmin iQue 3600 GPS Receiver
No backlight on my Garmin IQue 3600
Have you tried firmware update for your gps .
If you have not tried it try to update the latest firmware .
By updating firmware your problem can be fixed .
If your problem still continues then you need to take your gps to near by shop to get it repaired .
Feb 03, 2009 | Garmin iQue 3600 GPS Receiver
Garmin Nuvi Firmaware Update Complete, Unable to catch satellite signal
my garmin nuvi200 keeps on searches for satellite,but it couldnt able to pick up signal. A question mark over a map is always im seeing througout
Apr 06, 2008 | Garmin nuvi 350 GPS Receiver
IQue 3600 sim card problem
from Garmin:
Question: Why wont the PC recognise my the SD card in my iQue 3600?
--> Answer: Go to My computer and look for the following directory:
  • C: > Program Files > Palm > (user name) > file called 'sync'
  • Double click on this file and delete the four bottom rows that will look something like this:
DisplayName=SecureDigital (SD) Card
  • Then try a HotSync as normal, it should then 'see' your SD card.
  • If all fails delete a second user name as sometimes this interferes.
Mar 14, 2008 | Garmin iQue 3600 GPS Receiver
Ique 3600 updating from r1 to r6
Call Garmin they are very helpfull.
You may have to go step by step, say from r1 to r3, to r5, to r6.
Garmin USA 1-913-397-8200
Tech support 1-800-800-1020
8am to 5pm Mon -Fri
Garmin Europe 44 1794-519944
Garmin Taiwan 886 2-26429199
Nov 05, 2007 | Garmin iQue 3600 GPS Receiver
Garmin Ique 3600
May be a hardware issue. I had similar behavior when I replaced my IQue 3600's battery. If the circuitboard inside wasn't seated properly on the contacts coming from the battery, the iQue would keep rebooting. Start by checking that all the external screws are snug (but not over-tight). If not, you can try to open the case to check the two screws inside holding the circuit board. But I'll leave that up to you, since I can't honestly guarantee that you're experiencing the same problem. (After all, you seem to be sure that it has something to do with the software...and you may be right.)
Feb 03, 2007 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600 GPS Receiver Logo
56 people viewed this question
Top Garmin GPS Devices Experts
Tom Chichester
Jonathon summesfield
Bill Gilhooly
Bill Gilhooly
Are you a Garmin GPS Device Expert? Answer questions, earn points and help others
