Question about Troy-Bilt Chipper Shredder
Difficult to start chipper while gears engaged
I recently purchased an 8 HP chipper / shredder at a local auction. I can find no way to dis-engage clutch while starting engine. To pull the cord while chipper blades are engaged is (to say the least) very difficult. I am not a young man and have great difficulty starting this machine in this fashion. Any suggestions?
    Problem Solver:
  • 5 Answers
The drive belt may be the wrong size if there is no play in the clutch. I have a 10 hp, but there is a common manual for the 10 and 8. My belt is a 4L380.
Posted on Aug 22, 2009
Why won't the pull cord budge?
My first idea is that the engine was shut off before the chipper or the shredder had not finished. First remove the spark plug. Next remove the covers on the chipper area and the shredder area. Now remove all material from both areas.Replace all covers, put the sparkplug back and try it.
Sep 28, 2015 | Craftsman LEAFWACKER 3-Way Chipper...
Tip
Fix the self-propelled function (MTD, Yardman, Troy-Built, others)
I just purchased a used Yardman 24A-203C701 which, as the title states, has similar variants among other brands.
If you remove either hubcap from the pneumatic drive wheels, you may see the drive pawls with thin pieces of nylon (like a wire ty-wrap) sticking out either side. This is what passes for the engagement spring for the pawls. The fix is to remove each pawl and modify them as follows: Remove the nylon piece. On the rear side of the pawl, under the short end which engages the axle shaft, there is a place where you can drill a 1/8" pilot hole. Expand the size to 5/32" (the drill will want to catch on the pawl's metal, so drill carefully) and tap for 8-32 threads. Buy four 8-32 Allen head bolts which are 5/8" long and four 8/32 hex nuts. Using Loc-Tite on the threads, install one Allen bolt and hex nut into the front side of each pawl. When the threads are flush with the rear side of the pawl, tighten the hex nuts to jam the fastener in place. Purchase four small extension springs which just fit over the Allen bolts and which have just enough tension to pull the pawls into engagement with the axle shaft. The machine will then pull with both wheels but can still be turned and even pulled backwards.
on Nov 24, 2008 | Troy Bilt Walk Behind...
Craftsmen 24" tiller pull start doesn't engage?
I would first pull off the recoil assembly and clean out the assembly. There should be something in the recoil assembly that should pop out and engage the motor when pulled. Lube/flush that with some light spray lube.
Apr 27, 2014 | Sears Vacuum Shredder Bagger Replacement...
Need new air filter for a tecumseh shredder chipper 10 hp
You can look up the air filter with the model number and order it over the internet from a website such as partstree.com, but there are others. Or, you can get the model number and go to your local small engine repair and parts shop. Mine had it on the shelf. If your chipper/shredder is like my 8 HP Craftsman with a Tecumseh engine, then as you are looking at the engine, look on the left side of the shroud or cover and way down low on the curved portion is a label with the model number on it.
I hope this is helpful for you.
Aug 22, 2011 | Tecumseh Heavy Machinery
Balde wheel is engaged while trying to pull start making the task extremely difficult. is there a clutch mechenism that is not dissengaging?
No. The blade is like a flywheel and is connected directly on the motor shaft. However, these usually have separate choke and throttle handles. I have found that they start easiest if the throttle is set pretty low and the choke is closed. Once it starts to fire, then slowly open the choke - allowing it to pick up a bit of speed before you open the choke all of the way. Then wait a few seconds before turning up the throttle. On the other hand, if you have debris in the machine making it hard to turn, you will have to clean some of it out before you start it. Good luck, Al K
May 22, 2011 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Pull cord just pulls freely. Pull cord doens't seen to engage and I can't start the engine.
Unfortunately, disassembly of the unit will be required to diagnose and replace/ repair the malfunctioning starter recoil unit.
Jan 16, 2011 | Sears Vacuum Shredder Bagger Replacement...
I need a parts and owners manuel for a Super Tomahak Wood chipper made by Garden Way Mfg. Co. where do I go to get one?
Hi and welcome to FixYa. I am Kelly.
Go to this site:
http://www.brentchalmers.com/
I note your looking for the Super Tomahawk. If you can come up with a model number I think I can find your parts manual for sure. (or at least an on-line parts list.) Also.... If you can come up with an engine number like OH120 or L90 off of the engine I can find you a manual for the engine also.
This is the list of Manuals available there:
  • 1983 W-W Grinder Inc. Manual and Parts List Super Tomahawk 5-8-2G/C and Tomahawk 5-8-2G/M Chipper/Shredder (40 Pages)
  • 1989 Troy-Bilt Owner/Operator Manual Junior Tomahawk Chipper/Shredder (24 Pages)
  • 1989 Troy-Bilt Technical Manual 4HP, 5HP, & 8HP Models Tomahawk Chipper/Shredder (12 Pages)
  • 1991 Troy-Bilt Owner/Operator Manual Junior Tomahawk Chipper/Shredder (24 Pages)
  • 1991 Troy-Bilt Knife Kit number 1772231 (1 Page)
  • 1992 Troy-Bilt 5HP Model Service Kit (Part Nos. 1901153 and 1901804) For Chipper/Vac (1 Page)
  • 1992 Troy-Bilt Owner/Operator Manual 47260, 47261, 47271, 47272 Chipper/Vac (60 Pages)
  • 1993 Troy-Bilt Sales Brochure Chipper/Vac (4 Pages)
  • 1993 Troy-Bilt Owner/Operator Manual 47265, 47266, 47267, 47276 Tomahawk Chipper/Shredder (44 Pages)
  • 1993 Troy-Bilt Parts Catalog 47265, 47266, 47267, 47276 Tomahawk Chipper/Shredder (16 Pages)
  • 1994 Troy-Bilt PTO Chipper/Shredder Owners Dog Clutch Kit 1902404 (1 Page)
  • Hopefully your model is one of the above.
    Here is link to the Parts manuals:
    http://www.partsandservice.com/html/TroyBilt/cs/
    There are 90 parts manuals there.
    Again with a good model and engine number I can probably come up with your exact manuals.
    Thanks for chosing FixYa,
    Kelly
    Oct 20, 2010 | Troy-Bilt Chipper Shredder
    Can't pull starter, the cord is stuck.
    I have the same problem. Did you get any help?
    Jul 29, 2010 | Yard Machines 24a 452g729 5.5 Hp Chipper...
    Troy-Bilt Chipper Shredder Logo
    354 people viewed this question
    Top Troy-Bilt Heavy Machinery Experts
    Mike
    lnbn1975
    itsman
    Are you a Troy-Bilt Heavy Machinery Expert? Answer questions, earn points and help others
