Question about Logitech QuickCam Express Web Camera
Blue line middle picture - Logitech QuickCam Express Web Camera
  • 118 Answers
Test on another pc if the blue line persists call tech support for out of warranty credit.
Posted on Jul 15, 2009
Vizio screen problem. Please help!
The screen is ok Your T-Con board quit. You can get a new one from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Aug 03, 2017 | Vizio VO320E LCD TV
When i turn it on it has an horizontal blue line in middle of screen then comes on, when shut down it has the colors in the middle in tight formation then suts off. is it the picture tube
the set having blue scteen when the nosignal condition so blue horizontal line due to failure in vertical deflection section and system control detect the vertical delection failure . so system control farce to set to shut down pls repair the vertical section and system should be ok
Aug 26, 2010 | Samsung SlimFit TX-S3082WH 30" TV
Having a big yellow spot background in the middle of the picture.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 09, 2010 | Hitachi 50VS69 50" Projection HDTV
Yellow stripe across middle of the picture
yes rteh color of the wires(ends)red,blue,green,sounds like they may ahve gone bad or are interchanged, what does it do with a dvd picture
May 23, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Color lines out of focus
dc2eb76.jpg MikeNJ1964
Rank:guru_s.gif Guru sony.gifSony Expert
Rating: 89%, 674 votes
You have a completely different problem. The screen voltage for the blue picture tube is slightly too high on your set. This will put fine lines in the background of the picture, called retrace lines. This is very common and easy to correct. Remove the front speaker cover and the access panel behind it. Look inside and you will see a black box with six controls, each control having a little white glue on it. This is the Focus/Screen block. Three controls are labeled Focus and three are labeled Screen. The screen control in the center is for green but I am not sure if the screen control on the left or right is for blue for your model. With the TV on, set it to VIDEO 1 but do not connect anything to the VIDEO 1 jacks. This will produce a pure dark picture, showing any faint lines in the background. Choose one of the screen controls and increase (turn clockwise) it slightly. If the blue lines do not get brighter it means you are turning the red screen control, so put it back where it was and choose the other screen control. When you find the blue screen control, decrease (turn counter-clockwise) it until just when the blue lines are gone. If you want you can check that the red and green screen controls are set to just below the point where their faint lines are visible. When done, replace the panels and your picture will be back to perfect.
Did you think this was helpful? Yes No
new MessageRate('spn1737581','spn1737581cnt','spn1737581stats','spnRateWord1737581','div1737581_yes','div1737581_no','imgStar1737581','ancChangeRating1737581','divChange1737581',1737581,0,0,0,false); Solution #2 posted on Jul 04, 2008 Asker's Rating 0%20stars_w.png
noavatar_s.gif gator149
Rank:nonexpert_s.gif Apprentice sony.gifSony Expert
Rating: 0%, 0 votes
MikeNJ1964 was exactly right! I have a Sony KP-65WV600 that had horizontal green lines that showed when the picture was darker. I had to remove 3 screws on the right and left side of the tv holding in the speakers...carefully pop out the middle panel from the clips holding it in....remove 4 screws from the cardboard in the middle and remove the cardboard. I then saw the six screws. The adjustment screws were the three below. I turned the middle screw until the lines dissapeared. I tried the left screw and blue lines appeared which I then adjusted away.
THANKS a bunch. SAVED me money!!!
May 15, 2009 | Sony KP-65WV600 65" Rear Projection...
Weird blue flash when tv turns on or off
TV will need service soon, blue CRT is on its way out, will need replacing
Mar 25, 2009 | Sony KP-51HW40 51" Rear Projection...
Curved blue lines on screen.
Apr 11, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Showing black screen with a blue line
Is the blue line running straight across the middle of your screen? If so its a vertical deflection problem. Possible bad Vertical output IC
Feb 20, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Mitsubishi VS-60111 picture distorted
how do I manually switch my t.v. from 480i to 1080i on dtv with remote.
Dec 31, 2007 | Mitsubishi VS-70707 70" Rear Projection...
My Hitachi 65SWX20B Model, made in 02, just developed Picture disturbance
Can you post a picture of the set. This might be a convergence problem. seeing the set will confirm this.
Thank you,
shuttle83
Oct 28, 2007 | Hitachi 65S500 65" HDTV-Ready Rear...
Logitech QuickCam Express Web Camera Logo
91 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
