No voltage to thermostat.none to condenser vltage.main voltage to con.ison.
  • 44 Answers
If your breakers are not triped and your T-Stat is not battery operated your transformer is not putting out the 24Vac needed to power the stat. inside your airhandler there sometimes is a fuse. most times it is the same type that is in your car 5 amp yellow fuse. check it. if blown replace it. if it blows again you got a short in your low volt wiring. all a service tech. Steve
Posted on Jul 12, 2009
    Champion:
  • 233 Answers
Check for proper voltage to the unit , (generally 110VAC) check the transformer secondary for approx 24 volts. Verify the door switch is operating properly and that the door switch engages when the cover is put back on. if all of this proves good then check the wirtes going to the thermosta and the condenser
Is vltage 110 or 220 volts
Would that not depend on which country you bought it and where you are trying to use ? Check the back of the Washing machine for voltage details.
the manual is attached. DAEWOO DW 160C Instruction Manual
Apr 27, 2016 | Washing Machines
Air-con faulty
sounds like an electrical problem check all fuses and ac clutch relay
Jul 20, 2013 | 2005 Mercedes-Benz Sprinter 311CDI
NEED A PART NO. FOR ZENER DIODE D830
It is an easy to get component, All zener diodes will have a breakdown vltage, and it will be marked on it body. Read it, and buy a new one from any electronic spare part selling shops.
May 12, 2012 | Panasonic CT-36D31 36" TV
Compressor didnot turn at all, but the fan in the main machine is working. liquid pressure is all right to
You mean main machine is indoor unit? Then you have to check in condenser unit there is required voltage from indoor. If not check thermostat setting.
If you mean main machine as outdoor unit check the wires in compressor terminal. Do it only after isolating the power. Safety first.
Dec 08, 2010 | Hyundai Heating & Cooling
Common problem and solution on condenser of carrier air con.
dirty evaporator filter and or coil, dirty out door condensing coil, defective thermostat.
Feb 21, 2010 | Carrier BCA101R Air Conditioner
Have a mistral air con, outside unit not working
there is no fuse on your condensing unit outside. pull the disconnect to kill the power to the unit and take off the removable panel above the 2 service valves. there will be an oval shaped capacitor that is marked herm and fan. there will be a rupture disc on the top that may have ruptured. also inspect the low voltage wiring(will still be hot unless you turn off the switch at your furnace). this low voltage wire operates a magnetic coil on the bottom of the contactor that closes a high voltage circuit to the fan and compressor.
Dec 14, 2009 | Heating & Cooling
No heat at night
You have a poor low voltage connection from the thermostat or a bad contactor.The contactor is the main relay control inside the condensing unit. The incoming voltage wires connect to it.
Contactors are inexpensive. I would change that first.
Check all your low voltage wires in the condensing unit for loose connections.
Dec 11, 2009 | Coleman Heating & Cooling
Have a Ruud AC unit the problem I have after installing a new condenser fan motor when I throw the circuit breaker the unit will not turn on but when I push the contacts on the contactor in manualy the fan...
The contactor engages from low voltage power from the thermostat as does the outside condensing unit. You may have blown the low voltage transformer or have a loose thermostat wire. Check line voltage(220 volts) to the transformer. Check load voltage(24 volts) from the transformer. If no voltage out,replace the transformer. If you have voltage out(24) check the thermostat wires and the thermostat. If you have a digital thermostat there is a 5 minute delay in the thermostat after power is restored before it activates.
Oct 08, 2009 | Ruud Central System Air Conditioner
Air con
Could be the thermostat or the low voltage line to the outside. Usually a dog chews through it or the weedeater hits it and breaks connection. Turn on cool, go outside and see if it gets 24 volts to the two wires going to contactor (have to take off cover to get to it) DO NOT TOUCH THE CONTACTOR IT HAS 240 V AT ALL TIMES, unless disconnect is thrown, so turn it off. If you aren't getting anything, then it's either the low voltage wire broken somewhere or the thermostat malfunctioning. Make sure you turn off the inside unit before messing with thermostat or you will pop the transformer. If it pulls the contactor in, and you still aren't getting anything, then check for voltage on the load side of contactor (opposite from the inlet or lead side). If you are and you hear a hum from the compressor and the condensing fan motor is running, then it's your compressor. You'll have to remove the top cover to do the next step. Check to see if it when to ground by using a meter set on resistance and with the connector to the compressor removed, put one lead on one of the copper pipes going up to it and touch the other lead against any or all of the pinouts on the compressor. If you get a reading, it went to ground and you will need a new compressor or whole new condensing unit, depending on the age of the one you have now.
Jan 27, 2008 | Heating & Cooling
Heating & Cooling Logo
75 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
