Question about Sony KP-65WV700 65" Rear Projection HDTV
When pwr on all screen greeen & pwr off - Sony KP-65WV700 65" Rear Projection HDTV
  • Sony Master
  • 8,617 Answers
Thats a common symptom for your model. The green CRT has shorted or the Green CRT drive board is defective.
Posted on Jul 13, 2009
Greeen line from top to bottom. middle left side of the screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 14, 2015 | Samsung PN50C8000 50 in TV
I NEED THIS PART HA13001, PWR AMP 1x17.5W 18V
http://www.amazon.com/HA13001-Power-AMP-1x17-5W-18V/dp/B00EUBHERM
Mar 26, 2014 | Hitachi Drills
Netgear how to recover password
unplug router, including pwr! for 5min then plug back in.connect with comp & with cable back to router & press!!reset on router!!hold for at lest 20 sec should display private info on screen write it all down should include pin & security hopefuly it helps you
Mar 23, 2012 | clearwirelessinternet.com
The unit will not turn on check there is power is there a reset ?
Welcome to FixYa.
Do a soft reset first, if the problem still occurs, do a hard reset.
Soft reset (Does not delete GPS Data)
  • Turn unit OFF
  • Press and hold the PAGES key
  • Press and hold the PWR key
  • Release both buttons when the unit powers up to Full Map Screen
Hard reset (Deletes GPS Data)
  • Turn unit OFF
  • Press and hold the ZIN & ZOUT Keys at the same time
Thank you for using Fixya, have a great day.
Jas247
Jul 22, 2011 | Eagle Industries FishElite 640C GPS...
My 2008 Mariner battery is going dead periodically...the light on the battery looks red after running awhile it looks greeen & red. Is this the battery or the alternator
if you have 12.5 volts at the battery, the battery should be ok. If it reads 14.5 volts when the engine is running, the alternotor should be ok.
Dec 26, 2010 | 2005 Mercury Mariner
USING AC ADAPTER PWR INPUT POWER LED ON YET NO OTHER FUNCTIONS WHEN ATTEMPTING PWR UP - NO FAN - NO DRIVE START ETC.
Your battery might be defective.
A fast check to verify this is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then battery is defective & need to be replaced.
Nov 04, 2009 | HP Compaq Presario 2145US Notebook
Front panel to motherboard, ASRock P4i65G, connections
the power switch is on the 3 and 4 pins....the 7 and 8 pin are the reset pins. Trying it on wrong pins just won't startup the board but won't short circuit anything.
Jul 28, 2009 | Computers & Internet
Sony KP-51WS510 flickering&screen turning green????
Sounds like your focus block is going bad or out of adjustment. It could also be a bad picture tube.
Jul 05, 2009 | Sony KP-51WS510 51" Rear Projection...
Need fuse box pannel to see what fuse is what
FUSE USAGE
1. 10 AMP LOW BEAM-LEFT
2. 10 AMP LOW BEAM-RIGHT
3. 30 AMP BRKR POWER WDO/SUNROOF
4. 30 AMP BRKR PWR ACSRY
5. 20 AMP BRKR LIGHNG CONTROL MODULE
6. 15 AMP IGN/REM ACSRY CONT/INST CSTR
7. 10 AMP SUPPLEMENTAL INFLATABLE RST
8. 20 AMP CORNERING LPS/TURN SIG
9. 10 AMP CRANK SIGNAL-SIR
10. 20 AMP TRK REL/FUEL FILL REL/BACK-UP LPS
11. 15 AMP BAT/RADIO/PWR ANT/CIG LGTR/ INST CSTR
12. 20 AMP ELECTRONIC LEVEL CONTROL
13. 20 AMP BRAKE & HAZARD LAMPS
14. 15 AMP PARK LAMPS
15. 15 AMP COURTESY LPS/PWR MIRRORS
16. 10 AMP COOLING FAN
17. 25 AMP HEATING/AIR CONDITIONING (C67)
18. 15 AMP A/C AUTOMATIC ELECTRONIC (CJ2)
19. 10 AMP ANTILOCK BRAKES
20. 10 AMP LOW COOLANT/LAMP MONITOR
21. 10 AMP IP LIGHTS
22. 10 AMP HI BEAM-RIGHT
23. 10 AMP HI BEAM-LEFT
24 10 AMP IGNITION/RADIO
25 25 AMP WIPER/WASHER
FOR ACCESS TO ADDITIONAL FUSES
REMOVE RIHT SOUND INSULATOR
May 16, 2009 | 1991 Buick Park Avenue
Diagram fuse inside car
Your fuse panel is located by the emergency brake.Depress the two tabs and the fuse box will swing down, the panel diagram is written on the panel door.
Jul 22, 2008 | 1992 Buick Park Avenue
Sony KP-65WV700 65" Rear Projection HDTV Logo
109 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
