External Speakers to Insignia 22'' TV
I have an insignia 22'' flat screen and I'm trying to hook up external speakers. Is there any way to do this? I'm going insane.
  • 39 Answers
SOURCE: getting stereo speakers to work with flat panel tv
if you hook the low-level audio-out from the tv to an input to the stereo unit, whatever you play on tv will send audio to surround/stereo reciever unit. look on back of tv for red &white AUDIO OUTPUT terminals. plug red/white audio cables from tv to the back of your stereo & plug into audio input of an open source on stereo (tv/video,aux. in,etc.) good luck!
Posted on Mar 09, 2009
SOURCE: How do I hokk up external speakers to the Sharp
I want to hook up external speakers to my new lcd hdtv Sharp and control the audio with my remote.
Posted on May 16, 2009
  • 92 Answers
SOURCE: hooking up external speakers to a VIZIO
There is only one choice of audio out and that is the optical out put which locate on the far right if facing back of TV.
Posted on Jun 16, 2009
  • 171 Answers
SOURCE: connect external pc speakers to flat screen tv
get a 3.5mm -> rca adapter. You need to convert from the 3.5mm jack that your speakers uses to the rca jacks that your tv expects.
Like this:
http://ecx.images-amazon.com/images/I/31TelR%2BsCYL._SS400_.jpg
Posted on Aug 31, 2009
SOURCE: How can I connect external speakers to my Vizio VA26LHDTV10T?
Used the earphone plug with amplified speakers.
Posted on Dec 25, 2009
Testimonial: "That's my answer"
I bought a external Speaker and hooked it up to the TV but i get no sound.
The connections on the back of the TV are a little confusing. The red and white RCA connections are for audio in to the TV as from a game computer.
The choice for connections out of the tv to a amplified speakers are the digital coax out. And the headphone jack.
The best quality audio would be from the digital.
Select menu on the remote to set up the options for audio features.
Nov 30, 2015 | Insignia Solutions NS-39D400NA14 39" LED...
No sound
Check the usual things:
In menu speakers not switched off.
Set not set to external speakers if equipped.
Does the set have sound when a DVD connected to a rear input is used?
Oct 29, 2012 | Insignia NS-LCD32 LCD TV
No sound on my new tv?......do I have to have speakers?
Sounds like you are using RCA jack cables and have the sound cable plugged into the wrong spot? Are you using red white and yellow cables? If so check to make sure that the red and white are in the right and left speaker output area on the back of your television. No you dont have to purchase speakers for your tv to have sound. But there may be a switch to flip to go from internal to external speakers. Check the back of the tv to make sure it is not accidentally swtiched to external.
Aug 17, 2011 | Insignia Televison & Video
Adding remote control activated ''mute'' to TV headphone jack
Generally when the head phone jack is inserted the speakers will get disconnected automatically.
If you are going to use external amplifier you can try the AV sockets. Opening the TV you may require the special screw drivers some times.
Jul 07, 2010 | Televison & Video
There is no sound on my insignia flat screen what do I do
Try hooking up the powered PC speakers to the AUDIO Line out RCA jacks to see if you get the sound there, if you do, then the problem can be in the power amp section (make sure to check the on screen sound setup menu that the speakers are not set to OFF), if no sound at the RCA jacks either, then the problem can be in the sound processor circuit in the main board.
Nov 09, 2009 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
I have a 42 inch Insignia plasma tv. I only hook
If you have the audio cables hook up correctly to where the video cable from DVD is connected to, it should be RED and WHITE wires for audio. Then go to on screen audio setup menu to see if the speakers is turn off in the menu. Also try hooking up the powered PC speakers to the AUDIO LINE out RCA jacks to see if you get the sound OK there.
Nov 03, 2009 | Insignia 15 in. Flat Panel LCD HDTV
Can I attach outside speakers to my tv
You can if your model supports the outside speakers. Check the user manual. Normally TVs do not support external speakers but they have outputs that would allow you to connect them to external amplifiers or surround systems. Again, all this information should be in your user manual with pictures and detailed explanation of how and where to plug the cables.
Sep 06, 2009 | Insignia Televison & Video
How do i wire external rock speakers with 6 wires to my internal sound system with only two wires
Here is a link to the installation guide... for Insignia Simulated Rock Speakers... http://insigniaproducts.com/cms/documents/NS-R2111%20UM%20EN_SP_FR.pdf
Jun 12, 2009 | Insignia Simulated Rock Outdoor Speakers...
Insignia NS-LCD37 TV - no sound
Start checking the cable connection to receiver, try moving or replacing cables.
If you have a surround with external speakers check surround connection cable and speakers wiring.
If the cables are OK, then the unit may be faulty.
In that case the fault can be either the audio board (often audio circuit is integrated on the main board) , or the sinput output signal board.
Also a contact on connection to internal speakers can give you same problem.
May 22, 2009 | Insignia NS-LCD37 37 in. LCD TV
Insignia 26 inch Flat Panel Internal Speakers Stop working
You need to test the unit on a external sound source, to see if the audio amplifier is working correctly. By checking it on another source you can determine if the sound amplifier system is failing or you have had some problem with you speakers. Once you determine the problem. If it is the speakers, you can replace them with new ones. However if it is the audio amplifier section failing you will have to take it to a service center where they have all the service information to do the repairs.If the unit is still under warranty, have it serviced by Insignia. You can reach their customer support with this telephone number !-877-467-4289. Give them the model number of your television and the problems you are having with it. The should be able to tell you how to have it serviced. You can also check out their website for customer support at www.insignia-products.com. If the unit is out of warranty, you must have someone help, you troubleshoot the problem and try buying parts for the repair. You can call this number for insignia parts. 1-888-237-8289. You can also search the Best Buy website for parts on these units. The website is www.bestbuy.com. Go to the parts search section and put in the brand name of you television and put in the model number. The search engine will bring up a parts list with prices. I hope this information has helped you with your problem. You should also be aware that Best Buy has had a recall of some these model units. Check my tips and hints postings for more information.
Feb 28, 2009 | Insignia LCDTV26 26 in. Television
Televison & Video Logo
376 people viewed this question
Top Televison & Video Experts
