Question about Microsoft Xbox 360 Console
Graphics issue within an hour of playtime. lines and dots flash on screen
  • 51 Answers
This seems like it is your feed cables inless you hear a strange noise from your xbox and then its your xbox and youll either have to send it in to microsoft(need receipt) or take it into best buy.
Posted on Jul 12, 2009
  • trace evans Jul 12, 2009
    this seems like it is your feed cables inless you hear a strange noise from your xbox and then its your xbox and youll either have to send it in to microsoft(need receipt) or take it into best buy.
Yesterdy i was working on an optical drive issue with a comp, got it done by removing an extra drive from this computer...but...the video on this computr is not wrkong now...what issue? what is the...
Hi
What is the Resolution
Refers to the sharpness and clarity of an image. The term is most often used to describe monitors, printers, and bit-mapped graphic images. In the case of dot-matrix and laser printers, the resolution indicates the number of dots per inch. For example, a 300-dpi (dots per inch) printer is one that is capable of printing 300 distinct dots in a line 1 inch long. This means it can print 90,000 dots per square inch.
For graphics monitors, the screen resolution signifies the number of dots (pixels) on the entire screen. For example, a 640-by-480 pixel screen is capable of displaying 640 distinct dots on each of 480 lines, or about 300,000 pixels. This translates into different dpi measurements depending on the size of the screen. For example, a 15-inch VGA monitor (640x480) displays about 50 dots per inch.
Printers, monitors, scanners, and other I/O devices are often classified as high resolution, medium resolution, or low resolution. The actual resolution ranges for each of these grades is constantly shifting as the technology improves.
Solution :
1.
If you not get the proper video image in your screen that mean you have remove the driver of video, for installation the driver, put the Driver -CD in rom, and start the setup is simple set you get the driver.after installing the driver restart your PC
2.
If you change any display setting then also you get the occur.for set the resolution go to the control panel and select the Display and go to setting tab set the ' Screen resolution" as before.
3.
If you still not get the display then open you PC and remove the RAM and put again,and try again.
God Luck
Sep 15, 2011 | Asrock P4I45GV R5 Motherboard
White "press dot" screen
The actual answer is to press the dots, but use a dull plastic tool that fits "within" the dot. Otherwise the width of your finger is too imprecise to calibrate the dots and screen.
Hope you, and others, get this and try it. It works. I just discovered it and did it, successfully after only about 10 presses.
Jul 21, 2010 | Garmin Nuvi 660 GPS Receiver
Does my computer screen need replaced if it has green line on the bottom and green flashing dots
Hello
Ok, well, it does not necessarily mean that your screen needs replacement. It can be a couple of things which can cause this.
Firsly, you need to check your graphics adapter. Test this by plugging it into another screen, if the problem persists it is your graphics card.
If the problem does not appear when you use another screen, the problem is most probably with the screen you are using.
Hope this can steer you in the right direction.
Kind regards
Andrea
Dec 27, 2009 | Computers & Internet
HP compaq nx9420, plays most dvd's, but wont recognize one i am trying to play now. DVD says on front it is DVD 9 technology w/ 6 hours of playtime....??
Try to explore the DVD and see if you see the content. Right clcik on the DVd and select EXPLORE. If the content is viewable the issue could be just specific to the DVd autorun files. You dont need to worry.
Rate if useful.
Jul 28, 2009 | Intervideo WinDVD 5 for PC
Red static in black background ~ thin line running down center
Robjrpena,
Did you find a solution to your "red dot" problem? I'm having the same issue :(
Thanks John
Jun 17, 2009 | Hitachi 50HDA39 50 in. Plasma HDTV
My xbox freezes and lines/dots apear on the screen
The graphics processor, and second graphics chip both require a reflow. A special BGA reflow 'heat' machine is required.
FixMyConsole
May 09, 2009 | Microsoft Xbox 360 Console
Colored dotted lines across the screen
If you understand the components of a computer pretty well, open the case and remove and reseat the graphics card into the slot.
Does it seem to only do it after so long, for example turn the computer of for a few hours, and it wont happen when its first turned on, but then a few moments later it starts after its warmed up?
If this does not resolve the issue, you may be experiencing graphic artifacts which can occur when a gpu is overheating due to a poor cooler. Check to make sure the heatsink is touching the gpu.
Artifacts: http://www.playtool.com/pages/artifacts/badgpu.jpg
Apr 20, 2009 | XFX GeForce 6200 Graphic Card
Coloured And Dotted Lines Across My Screen
Firstly, start your pc in safe mode (f8) on boot up. This will start your pc in vga mode, and hopefully the lines are still there, which will indicate a faulty graphics card, if they aren't it may be a problem driver. If no lines, go to Add/remove programmes and uninstal your graphics driver. Re boot pc then when it finds your card make sure you point Windows to the folder in which you have saved the driver files. The driver should then install, see if any change. You may have to try some older drivers, as Nvidia can be awkward at times. I have had varying problems with Nvidia and replaced with ATI cards with no problems.
Dec 01, 2006 | XFX GeForce 6200 Graphic Card
Microsoft Xbox 360 Console Logo
59 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
