Question about Britax Vigour - Plum Standard Stroller
Need to locate O2 sensor
I need to locate the O2 sensor on a 93 acura vigor
  • 3,037 Answers
The O2 sensors will be located directly on the exhaust pipe under the hood in the engine compartment.
Posted on Jul 12, 2009
Can honda accord inspire/vigor 1992 with G25A be replaced with a G20A ?
https://www.ichibanjdm.com/product/jdm-acura-vigor-engine-g25a-5-cylinder-sohc-92-93-94-95-96-97-98-acura-tl-2-5/
G25a. Longblock 1499. Automatic transmission
May 01, 2018 | Honda Cars & Trucks
Would Any other car makers,camshaft fit a 93 acura vigor 5 cyl
Usually, it is not possible, crankshaft is designed specially for the car, not for the others, yours is 5 cyl, inline, definitely unique one.
Your chances are
(1)junk yard,
(2)aftermarket
Sep 03, 2016 | 1993 Acura Vigor
Where is fuse at for fuel pump 93 acura vigor also fuel pump relay
Where is fuse at for fuel pump 93 acura vigor.? relay is a main relay part# RZ-0067 and is a brownish orange color.
Fuel pump relay is located in the trunk behind the back carpet on the back of the seat. OR
  • located just under the steering column behind the lower panel where your knees would touch if you were driving. it is held on by a 10mm screw.
Fuel Pump Fuse is located under the Dash.
Oct 16, 2013 | Vehicle Parts & Accessories
My 93 acura vigor keeps melting my distributor cap what can be the problem?
Are any internal distributor parts damaged? Are they all in good working order? If not, something external to the cap is melting the distributor cap, although that item should be able to withstand NORMAL temperature operations under the hood.
Apr 17, 2013 | 1992 Acura Vigor
What does code po141 mean on a 2001 Acura cl 3.2?
Its o2 sensor error code.-------
P0141-Bank1 Sensor2- code.--------
The "Sensor located after catalytic converter".This o2 sensor needs to be replaced.-------
this will help.thanks.Helpmech.
Aug 04, 2011 | 2001 Acura 3.2CL
I cant find where the starter is located under the hood of my 1994 acura vigor gs i need to change it out.I would like to have a diagram where the starter is located.
follow the positive(+) battery lead from the battery it goes onto the starter motor......hope this helps......cheers.
Jun 26, 2011 | 1994 Acura Vigor
Where are the oxygens censors located on a 1999 Acura CL 3.0, need to replace them
The 3.0 is an ODB2 car so it has 2 o2 sensors. One before the CAT and one after the CAT. Check your headers for the primary heated o2 sensor location, and check on top of the cat for the secondary o2 sensor.
Sep 07, 2010 | Acura CL Cars & Trucks
Radio code
Remove the radio and write down the SERIAL NUMBER and MODEL NUMBER. Go to your nearest Acura dealer with those numbers.
Oct 04, 2009 | 1995 Acura Legend
93 acura vigo's motor turns over but the car don't stay on
Put your foot into it a little. does it stay running with a little pedal. You may need an idle air control valve.
Aug 14, 2009 | 1993 Acura Vigor
93 acura vigor will not start or turnover
You might need to replace your starter.
Dec 26, 2008 | 1993 Acura Vigor
Britax Vigour - Plum Standard Stroller Logo
35 people viewed this question
Top Britax Baby Gear Experts
Jennifer Rock
Jennifer Rock
ray gallant
Tom Chichester
Are you a Britax Baby Gear Expert? Answer questions, earn points and help others
