DRUM NOT SPINNPNG CAN HEAR MOTOR RUNNING
ZANUSSI FLA 1001W.
Before it stopped spinnong there was a lupmpy thumpping noise .dont know if it was the bearing, how do i take it apart firstly. and because it isnt spinning i asume it is the belt. Frank
  • Washing Mach... Master
  • 2,200 Answers
Hi
You need to pull the machine out from the wall and remove the back panel. This will give you access to the belt drives. It sounds as if the belt has either snapped or slipped off the pulleys. Be aware you may also have a bearing problem on the motor which has caused the belt to come off in the first place.
Hope this helps.
Posted on Jul 12, 2009
Loud noise during rinse cycle
Hi
If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary. Also check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)
Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.
Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.
Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.
Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 03, 2011 | Frigidaire Washing Machines
My washer has recently started thumping and banging during the spin cycle. I thought it was uneven weight distribution, but it does it every spin now. And when the spinning slows down it has started...
Hi, . according to your washer problem i m writing solution ,please read and follow it:-
  1. Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
  2. check out this following options one by one to locate the fault in your machine.
  3. 1)Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.2)Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)3)Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.4)Clear thewater pumpfrom obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.5)Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.6)Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
  4. you can get the required partys from
  5. www.repairclinic.com
  6. I hope this will help.
please don't forget to vote me. goodluck.......
Jan 21, 2011 | AEG Lavamat 72640 Front Load Washer
Heard a thumping noise everytime we turned dryer on...lasted a week or so.....drying a blanket last night cycle stopped half way thru.....still getting hot, just not turning. Thinking this is some type of...
The thumping noise comes when the drum is rubbing against the body surface. This could be due to the suspenders/support which is holding the drier drum are not steadfast. May be one has given the way. To know exactly if it is the belt or the coupling with motor or the support for drum , you have to open the back cover which you can do it by removing the screws at the back and then inspecting the machine.
Nov 02, 2010 | Frigidaire Electric Dryer
Zanussi FLA 1001W does NOT spin
You need to check the brushes in the motor first, replace if less than 3 or 4mm long.
If brushes o/k, then could be a module or motor problem, apart from the belt being broken or worn of course.
Hope this helps.
Jan 23, 2010 | Zanussi FLA1001W Front Load Washer
Location of bearings on a zanussi fla100w
how do you change bearings on zanussi fla 1101W
Jan 11, 2010 | Zanussi FLA1101W Front Load Washer
It has been making banging noises and the drum is sqeaking.the wash programme stops mid cycle we have drained it and cleaned the filter, it is a bit better but is still not working properley.
  3. 1)Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.2)Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)3)Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.4)Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.5)Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.6)Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
  6. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 21, 2009 | AEG Washing Machines
Zanussi tc7102w made normal noise when I turned it on, but did not rotate and had a burning smell coming from it. Turned it off and unplugged it immediately. Any ideas? Wendy
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, Or the belt may have come off of the idler arm, or motor.
If you have to replace your drum belt and if you have a front loading machine.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would also recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Oct 18, 2009 | Zanussi TC7102W Electric Dryer
Loud rumbling noise with slight vibration
Normally the noise you hear is caused by the drum rollers having flat spots on them or needing lubricant.
If this is what is wrong It will make a kind of thumping noise.
When they need lubricant they will normally make a squealing noise also. You would lube the shaft and bearing area of the roller, using a good machine oil...something like "3 in One" oil.
Sep 26, 2009 | GE DBXR463ED Electric Dryer
Zanussi FLA 1001W washing machine - Programme selector dial
you can buy a new indicator as a spare - quite cheap. best souyrce would be service force - assuming you are in uk, its in the phone book
Feb 07, 2008 | Zanussi FLA1001W Front Load Washer
My washer wont spin
on the motor there are what you call carbon brushes.. these wear out over time, this then the motor stop spining check and get back to me . cheers doc
Nov 20, 2007 | Zanussi FS1455W Front Load Washer
Washing Machines Logo
94 people viewed this question
Top Washing Machines Experts
