Question about Garden
How to change the line - Garden
Change the fuel line on a buick lesabre
Changing the fuel line on a Buick Lesabre because of rust? usually means changing the fuel pressure line and the fuel return line and the fuel vent line and the brake lines.Touch one and the others fall apart/leak or leak right after.
Mar 02, 2018 | Buick Cars & Trucks
I can change Line2 to line1 in my phone there in no out going n my mobile how to change line 2 to line 1
To change from lines between line 1 and line 2 follow the steps below,
Press menu > Settings > Calls or Line 1 or Line 2 for dual line
phones then press the Change key to change it.
Thank You
Aug 12, 2010 | Motorola Mobility RAZR V3i Cellular Phone
BIS-10 Phone - How to change default line
If you have a "squared" system (each line assigned to a different button), just press a different line button. To change the order of the lines, slide the "T/P" switch to "P" and press the line buttons in the order you want to use them (ie: Line 4, Line 3, Line 2, Line 1).
If your lines are "pooled" you just get the next available line from the pool - no choosing which line you get.
Hope this helps.
Jun 21, 2010 | AT&T Merlin BIS 10 Phone
Transmission line leak howto change lines
You can easily change these by disconnecting one end from the radiator attach point and the other from the transmission attach point, install the new line, check your transmission fluid level (because you will lose a little when you remove the old line) and your done. Fairly simple procedure. Good luck.
Nov 03, 2009 | 1998 Dodge Grand Caravan
HOW DO I CHANGE DEFAULT LINE
use your phone settings to change incoming call
Jul 01, 2009 | Panasonic KX-T7456 Corded Phone
Need to change the phone number assigned to a line
Hi Amy,
Ok ~ first to change the incoming line to a phone, goto the phone and do a:
-> FEATURE * 0,
-> Press the line that rings on that phone... (this will be the target line number ~ maybe somewhere in the 145-256 range)
-> now get into the system programming
-> go to LINE and type in the number you've seen on the display
-> enter and find TRUNK/LINE DATA
-> enter and hit next till you see PRIMESET and change that number to where you want that number to ring to. Hit next, after changing number and hit REL to get out of programming.
Now call the number to ensure it is calling to the correct extension.
Mar 17, 2009 | NorStar Meridian M7310 Phone
M7310 - 3 phone set system - line 3 on one set does no ring tone
Feature * 6 is for the ring tone of the set, it doesn't change the cadence (ring tone) on a line...
The only way to change the ring tone on a line... it would require everyone that has that number to change.
You need to go into the programming
-> look for LINE and enter
-> put in 003 for line 3 and enter
-> under TRUNK/LINE DATA find DISTINCT RING and change
-> REL to end programming...
Now that line 3 will ring differently. But it will ring differently on everyone's sets that has line 3 on their phone
Mar 04, 2009 | NorStar Meridian M7310 Phone
Night ring change the number of rings
Auto Attendant
Answer Lines
1 – Feature 983
2 – Log: Dial 1020000 (3-digit DNs) or 120000 (2-digit DNs)
3 – Press AA
4 – Press LINES
5 – Line number: Dial line number (001-xxx).
6 – Line:xxx Ans:No Press CHNG to AA if auto attendant will always answer theline. If a Night Service key will be used to activate auto attendant answering, leave Ans: at No.
7 – If line has been changed to Ans:AA, press * then press TABLE.
8 – If Table:1 is OK press RINGS. (Table 1 is the default greeting table. Change to a different table (1-4) if alternate answering is required on the line being programmed.)
9 – Rings:0 – Press CHNG, dial number of rings before auto attendant answers the line, or leave at 0 for immediate answering. Allow at least 2 rings if CLID is in use.
10 – Repeat for each line to be programmed.
Notes For Night Service Mode Auto Attendant Answering
If the auto attendant will only answer lines in night service mode, line answering should be set to No as per step 6 above. Using night service will cause the AA to answer lines immediately.
Feb 11, 2009 | NorStar M7324 Telephone
Nokia 6300
If this is a nokia handset, then please long press #. it will ask u change the line from 2 to 1. say yes. otherwise find the menu for line change. then go there and manully change the line
Aug 31, 2007 | Nokia 6300 Cellular Phone
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
