Question about Plumb Pak Laundry Tub Strainer Basket PP820-45
Basket strainer utility sink is old and the strainer has worn out. I cant find a replacement no where i need help
  • 62 Answers
You will need to have the entire basket strainer drain assembly replaced.
Posted on Jul 14, 2009
Leak at new strainer waste fitting
Did you put the rubber gasket and cardboard sleeve on the bottom of the sink(next to the nut and did you use plumbers putty on the top part of the sink under the top section of the basket. Hint if you put some soap on the gasket under the sink between it and the nut it will be easier to tighten also you must secure the top part of the basket as you turn the nut if not the plumbers putty will not seal. If you do not have the strainer basket holding tool wrench you can substitute with a pare of needle nose pliers. Large channel locks or pliers can work to turn the large nut on bottom. If you can recruit a helper to hold the top part of the strainer basket with the needle nose pliers it make the job of tightening the large nut easier. When a large amount of the plumbers putty has squeezed out and the strainer is flush with the sink you should have a tight seal.
Feb 24, 2012 | Blanco Plumbing
Hi When I push down the Franke Strainer Basket in order to fill the sink basin, it appears to leak in the cabinets below. With out pushing down the strainer basket whilst tap is running there is no...
More than likely it's leaking from where the body meets the sink. U might need to pull it apart, clean it up, and re apply plumbers putty to the sink and re apply the body. If you are doing this I would recommend buying a new basket assembly from the hardwear store. Just makes more sence than re using the old one. That is enles it's new. Hope this helps
Mar 29, 2011 | Franke 900SN Strainer Basket: Satin Nickel
What strainer/disposal basket do I need to buy for Porcher Farm Sink? Sink did not come with strainer/disposer trim.
I believe this uses a standard 3 1/2 inch diameter basket strainer.That is also the right size for the disposal. Thank you
Feb 26, 2011 | Porcher 35020 London 30" Single Bowl Farm...
What is the difference between standard strainer and strainer for food erator? I bought a replacement sink wiht standard strainer, which does not seems to fit garbage disposal
If you need new sink strainer basket for disposal side of sink, you have to buy new disposal.
Each garbage disposal comes with its own strainer basket so that disposal can connect and seal.
First, the disposal strainer basket is installed, and then disposal lifts up and attaches from below.
A rubber gasket comes with new disposal.
Rubber gasket fits between disposal and strainer basket so that disposal seals correctly.
Photo below shows how disposal connects to strainer basket using steel connector ring under the sink.
I wrote tips for installing a disposal from days when I worked apartment maintenance.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Feb 16, 2011 | Franke 900 Black Basket Strainer 900
Trying to find basket strainer for Kohler vast
all of kohlers baskets fit their sinks, even older model sinks.
do you have a special strainer, or sink?
have you contacted Kohler direct? or one of their distributors. a wholesale plumbing supply house (NOT lowes or home depot) in your area will be able to help you also
Oct 15, 2009 | Kohler Plumbing
Sink Basket leaks and cant be removed cause of silicon adhesive
steady pressure from under the underside of the sink should cause the silicone to flex and eventually release.
You might also try some caulking remover available ot hardware stores. It's a product that comes in a tube and eases the removal of caulking products.
Be sure to look at the label for cautions and materials that it is safe to use it on.
Oct 07, 2009 | Belle Foret BF-NBBS2-CP Junior Basket...
The sink strainer stem is broke and I can't find anywhere they have replacements.
Go to a plumbing supply house with the old strainer and see if they can match it up for you. You might have to buy a whole new basket assembly. Or if you can't find a match, have the entire basket drain assembly replaced so that you can find replacement baskets in the future
Jul 06, 2009 | Plumbing
Cement sink drain repair
Yes you can still get those basket strainers and you can replumb with plastic pipe. Make sure when you go to the store to get the extra long strainers made for thick sinks, the fitting on the bottom should be made to accept plastic pipe. You may also need a "mission band" or "fernco coupling" to attach the plastic to metal pipe after replacing everything under the sink.
Mar 23, 2009 | Plumbing
I need a new franke sink basket strainer for my franke sink model PRX11021 - stainless steel. What is the model number that will fit this sink and can I order it online or go to a local store?
You should purchase a complete basket strainer assembly. Home Depot or Lowes have some very nice ones. They are a standard size.
Tell them it's for your kitchen sink.
Jan 28, 2009 | Plumbing
Plumb Pak Laundry Tub Strainer Basket PP820-45 Logo
128 people viewed this question
Top Plumb Pak Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumb Pak Plumbing Expert? Answer questions, earn points and help others
