Question about HP Pavilion dv4000 Notebook
PC Won't Power Up
NOTE: I am new to this site and couldn't find the right model for HP. Mine is a desktop PC, HP Pavilion a475c.
We got a "hard drive is bad" error. I did a standard restore which seemed to work until I shut it off and then it came back with the same bad drive error.
I replaced the hard drive with a Western Digital 3000 40-pin conducter. At that time I took out the battery also. Now the pc will not turn on. I took the hard drive back out and put it in a case and I could access it. I unplugged everything including the power cable, held the power button for 5 seconds, switched the red power supply from 115v to 230 and left it for 5 seconds and then switched it back. Still nothing. The green light in the back is flashing. I'm out of troubleshooting ideas. Help!
  • Skids Nov 26, 2007
    I have the same problem with a Pavilion Notebook. There is likely a "system off" (reset) button on back of notebooks that you can push with a pen tip to reset. That usually works. I have the same issue on a Dell Notebook model that does not have a rest button. The last time around I removed the memory modules and the drive, and stripped out all other removeable hardware, then checked for power and fan coming on. After power and fan running, I re-installed all the hardware and it seemed to clear it all up. From what I see, most notebooks with Intel motherboards has a reset button on the back side.
  • Anonymous Sep 27, 2008
    freezes on boot, the only way to fix it is to wiggle the display! strange...
  • 85 Answers
I'd guess the problem is either the hard drive connector in the bay (trying putting in the original drive and seating it very solidly) or else the motherboard hard drive controller (rare problem). You can diagnose which of these it might be by putting the hard drive back in and then booting into the BIOS (F10 or delete at boot up) and then investigating whether the hard drive is being correctly identified by the BIOS. If it is, run any tests or AUTO options it has to see if the BIOS can contact the drive properly. Then, step through the BIOS settings and try turning on and off settings like SMART FOR HARD DRIVE and so forth and rebooting in cycles after every change. It is also possible that with the power problems you've described, the BIOS got reset and may need tweaking to get it working again. If you see evidence t might be a BIOS reset problem (for example, the system clock is crazy wrong), try to LOAD SAFE DEFAULTS AND EXIT option in the BIOS. If you test it all this way and find no problems, and you can access the drive normally on another machine, it is probably the motherboard IDE controlled. Will it boot from a CD/DVD? They are usually on the same IDE channel and so failure to boot from a CD tells you something is wrong in the hardware.
Good luck...
Posted on Nov 16, 2007
  • RIchard Wheeler Nov 16, 2007
    PS: "Hard drive is bad" doesn't in this case actually mean the HD is bad, only that the BIOS could not communicate with it.
How do i change a power supply for hp slimline ?
There are three or four screws at the back of the system at the left side (as you face the back), remove them. Remove the top of the case. Disconnect the power cables from the power supply to the main circuit board (there may be two, but often just one 20 to 24 pin one, the second cable being 4 pin square for the CPU). Disconnect the power to the optical drive and to the hard drive. Slide the power supply toward the front of the system about 1/2 inch and pull up. Note, on some models the clearance is nearly none to none and you may need to remove the screws on the mainboard to slide the mainboard about 1/2 inch toward the right (as viewed facing the back of the system). To put the new power supply back, reverse the process.
Jul 11, 2014 | HP Hewlett Packard Pavilion Slimline...
Why does my hp a475c shut off without warning?
Are there any other signs or more info maybe?
- Is Windows activated properly?
- Have you tried cleaning your system to remove dust (possible overheating)?
- Have you ran a virus or malware scan on the computer? (Kaspersky Internet Security and Malwarebytes Antimalware are 2 products I have used for years.)
May 01, 2014 | HP Pavilion a6532f Desktop PC
When I power on my Hp Pavilion 762c I get no bios menu
If you still have this computer, are you interested in selling it (even if it doesnt work anymore)? I need this model.
Apr 11, 2013 | HP Pavilion 762c (P8628A#ABA) PC Desktop
Hp pavilion a1217n tower won't power up...the green light in the back is blinking!
it could be 3 things eigther the hard drive failed or power supply went out or mother board went bad you can take it to a reputable computer repair store and they will check these for free
Jul 08, 2011 | HP Pavilion a1217n Desktop PC
Can i add an additional hard drive to my hp a1320n desktop computer? I have a hard drive from a computer of mine thats power source/motherboard died out, and i would like to be able to use that hard drive...
Yes it is possible. It depends on the IDE/SATA ports present on the motherboard that how many hard drive/CD drive can be connected to it. Also you can buy an external casing for your old hard drive that will let you connect it with your existing computer using USB port.
Hope this will help...cheers:)
Jan 02, 2011 | HP Pavilion a1320n (882780261747) PC...
How do you replace a hard drive in a HP Pavilion -Model 8674D?
The instructions for removing the back cover or front cover might be in the Owner's manual. You need to remove the access panel and once you remove it just uncrew the old hard drive and install the new one and recoonect the wires.
May 25, 2010 | HP Pavilion (PN153AAR) PC Desktop
30days out of of warrentu dont figure. Issue:
hi there i have the dv8000 i put a 500 gig ide drive in mine and never got any problems you say that you have several (9) issues most of them stated Failed Devices do you mean drivers for laptop as thats all i think you need.
also any 2.5 hd should work..
if its drivers you can go to hp site
Oct 23, 2009 | HP Pavilion DV6700T Notebook PC
Pavilion 525C won't start
HP Pavilion 525c/525c-b
Model Comments - 266MHz FSB, NVIDIA nForce2 IGP Chipset
After installing a new harddrive
The system may not boot and may need to be reconfigured.
You may have setup your new harddrive incorrectly.
Your system BIOS may require you to check it's settings due to the addition of new hardware.
It's recommended that you check your system bios configuration for errors after installing new hardware.
Sep 23, 2008 | HP Pavilion 525c (DD210AR#ABA) PC Desktop
HP Pavilion dv4000 Notebook Logo
409 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
