Question about Star Logic 17" LCD Monitor
WHAT DUZ "OUT OF RANGE MEAN"
STARLOGIC 17" MONITOR HARD WIRED TO MY LAPTOP READS "OUT OF RANGE" HOW FIX?
  • gbforney Jul 14, 2009
    That didn't fix the problem. I think it is because of the following: When I go to SETTINGS as you suggested and rest the mouse arrow on box #2, it reads (Secondary Monitor (800, 0. This , I presume means I have zero vertical or horizontal resolution on the monitor. What do ya think?? How do I fix that? Thanx.
    Scholar:
  • 81 Answers
The laptop is widescreen at a guess. The external monitor is not. You need to change your laptop screen resolution to be something like 1280x1024, or, you need to tell the monitor to be a display EXTENSION not a mirror. Right click the desktop, properties, then Settings. Click on the 2nd screen, and set its resolution to 1024x768 or 1280x1024. It's here you would tell it to extend not mirror too.
Posted on Jul 12, 2009
  • 339 Answers
You have an older monitor apparently and are trying to drive it at either too high of a resolution or too high of a scan rate. Go back to standard VGA on the computer and then experiment to find the best combination that will work with your display.
The easiest way to do this is to right click on the desktiop and slect "Display Properties" or similar(assuming you use Windows, may vary a bit by OS Version).
Monitor displays out of range
reduce the screen resolution and then connect the monitor
Aug 12, 2014 | Star Logic Starlogic 17" Tft Lcd Monitor...
StarLogic- Out of range
The computer needs its screen resolution reducing or changing in aspect ratio to suit the StarLogic monitor. Use a previously-working monitor and reduce the resolution on the computer to 1024 x 768 pixels or less (right-click an unused part of the desktop, click Properties and select Settings; slide the resolution slider to the left to adjust). The StarLogic monitor will now work; plug it in - do the resolution adjustment again as above, but increasing the resolution until you are happy. Going this way around, your computer will failsafe back to the previous (lower) resolution if the monitor says Out Of Range again, so you cannot lose the display along the way..
Sep 07, 2009 | Star Logic 17" LCD Monitor
Starlogic 17" monitor not working with Vista
may need to download some drivers for it. Your operating system has nothing to do with it. Try www.driverguide.com . It also may be a hard ware fault. make sure all your connections are secure. Hope this helped.
Jun 23, 2009 | Star Logic 17" LCD Monitor
Starlogic 17'' as dual display not clear
Check and see if your NVIDIA drivers are up to date. Then try changing the resolution on your laptop to match the native resolution on the monitor and see if it works. If it does then you will need to look for the option to set custom resolutions on each monitor so that you can have both devices working at diferent resolutions if 1 is wide screen and the other is not.
Let me know if this does not work and you need more help.
Apr 20, 2009 | Computers & Internet
17" Starlogic Flatscreen LCD monitor has line across the screen
This problem is called dead pixels. You should try to return it to the seller. If the warranty is still valid they will replace it with a new one because LCD screens are extremly hard to fix.
Oct 27, 2008 | Star Logic 17" LCD Monitor
17'' monitor whte screen power light on
have a 17'' starlogic flatscreen monitor and i opened a game and it went to white screen and stayed there.
Jun 19, 2008 | Star Logic 17" LCD Monitor
Starlogic LCD Computer Monitor
I can't find a website for StarLogic anywhere, so either they have gone out of business (not likely as there should be some reference to them somewhere) or they are imported from a foreign manufacturer and rebranded with the StarLogic name.
May 13, 2008 | Star Logic 17" LCD Monitor
19" starlogic monitor
If you are getting a "No Signal" message, someone may have inadvertantly pressed the wrong button on the monitor. Use up arrow of button #5 below to cycle through RGB (normal VGA connection) and DVI sources. Down arrow will result in "No Signal" message.
There are five buttons at the bottom of the screen on this monitor. From the left:
1 - sound volume
2 - degausser
3 - power on/off
4 - monitor set-up
5 - RGB/DVI source
Nov 20, 2007 | Star Logic 17" LCD Monitor
Star Logic 17" LCD Monitor Logo
173 people viewed this question
Top Star Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
scj103
Jerry Umali
Are you a Star Logic Computer and Internet Expert? Answer questions, earn points and help others
