Question about Fisher and Paykel Fisher & Paykel Washer
Machine won't start
I have a Fisher & Paykel GWL03 (or 08 as it it known in the USA) the machine powers up as normal but will not start any wash cycle. Checked all switches and in diagnostic mode, ( I can manage to get in there at least but I have no codes) I can get the pump and the solenoid, both hot and cold, to work. After switching the machine out of diagnostic mode all the wash cycle lights light up.
  • dgajjar Jul 13, 2009
    The lid switch was not making, as a result the cycle would not start. Remove the panel housing, two screws at the back. Facing the machine find the plug with a black and blue wires, trace this back to make sure it is the switch wires, this runs toward the front of the machine down the right side ( assuming you facing the machine ) cut the wires near the plug end, join and insulate. That solved my problem at least, and I hope it saves you lots of dollars. I love my Fisher&Paykel.
  • 10 Answers
Hi there
i'm not sure if the fisher and paykel machines are any different in new zealand compared to where you live, but the only thing i can think of if it isn't displaying a fault code is if this machine is fitted with a reed switch(these make sure the machine stops if the lid is opened during operation) this may be faulty and staying open causing the machine to stop when the lid is closed. Hope this helps.
Posted on Aug 02, 2009
Testimonial: "Spot on, but the problem was solved earlier. Thanks"
Fisher and paykel smart drive 5.5 won't start a wash cycle, no lights flashing or beeping looks normal but won't start
Contact Fisher and Paykel Service Center and DO NOT TRY TO OPERATE THIS MACHINE UNTIL CHECKED & VERIFIED BY AUTHORIZED FISHER AND PAYKEL SERVICE PROFESSIONAL.
Apr 28, 2014 | Washing Machines
MW512 Fisher & Paykel Washer Machine...Where is the lint filter located?
Fisher & Paykel machines don't have a lint filter.
Manual cleaning of agitator and s/steel bowl will make your washing cleaner.
Oct 12, 2012 | Fisher and Paykel Washing Machines
My Fisher & Paykel GWL11 top load wahser will only wash in cold after the first cycle. It
the problem other then the thermosat and solenoid valves is probably the main board. to check you need to replace the board with known good second hand board . buy an old machine for parts
Nov 19, 2011 | Fisher and Paykel GWL11 Top Load Washer
Starts and stops
A failed inlet valve is not uncommon in F&P machines. The hot valve is different to the cold one, so don't exchange them. Not a big job for a tech to do in-laundry. Good luck....Nomess
Jun 11, 2010 | Fisher and Paykel Fisher & Paykel Washer
No problem really but our charity has been given a fisher paykel eco washing machine with no instructions. Great really but what we want is a simple operation sheet that we can attach near the machine so...
Pretty much just turn it on & it will do most everything automatically.It will auto sense the water level for you & pretty much do everything itself based on the weight of the clothes..Press (Power Button)..Then press (Start button)..& Bobs your aunties live in lover! Sorry humour.
Jun 01, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Macchine won't fill with water normally
sounds like out of balance switch is faulty please reply if u need help to test.please turn power off b4 working on it.do not want any accidents
Mar 15, 2010 | Fisher and Paykel Washing Machines
Fisher & paykel GW 703-U water flow and the engine sounded choked
sounds like out of balance switch is faulty. does the water start stop start stop then machine beeps. if it does it is most likely out of balance switch.please reply 4 more help
Mar 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel 7.5 smartdrive washing machine, no power
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
Feb 20, 2009 | Fisher Paykel Eco IWL16
Washing Machines Logo
273 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
