Question about Whirlpool GSC9455 Top Load Washer
Howling noise washer makes weird noise when filling up with water.other than that it works fine
  • 234 Answers
The inlet valve is not open or closed all the way. Repair will run you around 120. If you need help puting one in, let me know. good luck :)
Posted on Jul 13, 2009
Doesn't take water in and makes a weird noise
This is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
Mar 19, 2011 | Zanussi Washing Machines
Front washer fluid is not working but rear is
Most washer solvent bottles share a common resevoir. The rear washer pump is located above the front pump. Try filling resevoir completely. If this does not solve the problem, listen for pump howling when you engage it. If it engages & howls & still wont work, possibly rear nozzle is plugged. Disconnect hose to it. If you engage it & it squirts, nozzle is plugged. Try blowing through it with air hose or pick it out with a fine pick. If no noise or fluid either way pump will need to be replaced.
Sep 07, 2010 | Volvo XC70 Cars & Trucks
Howling noise on start-up
Hi just read your posting.Does the machine make the noise when it is filling?If so then try a cold fill and see if the noise happens and if there is no noise then try a hot fill to see if there is a noise.Please reply with additional information on whether the noise happens on the filling cycle or at another part of the cycle.
Jul 10, 2010 | Fisher and Paykel GWL11 Top Load Washer
MY GE WASHER MACHINE FILLS WITH WATER BUT DOES NOT WORK AFTER THAT. IT DOES MAKE SMALL NOISE LIKE MOTOR BUT DOES NOT WORK.
it is not a maytag washer machine it is G.E it fills fine with water it also drains and spins but does not agitate.
Apr 09, 2009 | Maytag LAT3600A Top Load Washer
When filling bathtub or running two showers, water heater howls
it could be the fact thath the water comming in is what the problem is,, on a well system the water is extra cold and the unit is working hard and with sand aso comming in it makes it harder to keep the temp up on the water,,, flush the tank, put hose on it and open the drin valve with a hose on it turn the cold water on and let it flow till the water comes out clear usually about 5 min,,, get all the sand out and other debris and try it
Apr 03, 2009 | Water Heaters
Howling or squealing noise when the machine is filling with water
there is a restriction in the valve assembly. it is servicable so remove it, open it up on both hot and cold and clean thoroughly. replace and test
Jul 01, 2008 | Whirlpool LSB6200KQ Top Load Washer
Washing machine noise
check the dogs in the agitater
Mar 25, 2008 | Whirlpool GSC9455 Top Load Washer
Whirlpool GSC9455 Top Load Washer Logo
49 people viewed this question
Dan Webster
Dan Webster
Sal De
