Microwave Ovens Logo
M
Marlene Brandon Posted on Sep 14, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Do you sell the inside round glass tray and the round wheeled thing you place it on?
Louis F Hoholek Jr
Level 3:
  • Master 1,140 Answers
  • Posted on Sep 14, 2015
Louis F Hoholek Jr
Master
Level 3:
Answers
1140
Questions
0
Helped
258845
Points
4510
At fixya, we do not have a warehouse of parts, manuals, ect. We work at home answering questions only. You have to contact the manufacturer for parts.
What size glass tray do I need for my Westinghouse model WCM770B/W microwave? I broke mine and cannot find the answer in the manual.
Frequent thrift stores or yard sales, or take a tape measure to the inside of the microwave
. If your dish was square, the glass plate should likely be about 1 inch less wide and 1 inch less deep that the inside of the box.
If you have a round plastic rotator, the dish should be about 1 -2 inches bigger in diameter than the plastic rotator.
God bless your efforts.
2answers
My turntable does not turn
The turntable motor in the microwave oven needs to be replaced.
1helpful
Maytag Over The Range Microwave: Melted glass turntable, rollers
Considering the melting pooint of glass ...
Normally, microwave travels around round surfaces (Look at the B-1 for example) If you put flat metal in a microwave, you will create sparks ... lots of em. Is it possible you have something going on with one of the wheels ... like a piece of tin foil?
At a minimum, I think id be inspecting everything inside very carefully and then give it a good cleaning.
You might want a pro in your area tale a look at this as well.
a
Turntable wheel under glass tray broken
If the microwave comes with a roller ring to rotate the glass turntable then I would recommend that it needs to be used when the microwave is operating, as the turntable rotates the food so it can be heated evenly.
I would recommend checking with your local Panasonic repairer he may have access to a new roller or even a second hand one to tide you over.
2answers
Kenmore elite microwave/vent hood model 721.80834500 turntable
I bought a Kenmore Elite Microwave Hood Combination Model 721.80823500 at Sears. The installer did not bring the parts to connect the vent to the pipe on the ceiling and never came back. I cannot find the vent/exhaust connetor part to have it installed. No one knows. I appreciate information or installer. Thanks.
[email protected]
Broken glass tray
Even though these are discontinued, there are apparently a few places where you can still get one of these as "new old stock".
The proper part numbers are either MW-7600-11 or MW-7600-12 and you can order one by part number here.
It may take a week or two, and they may reply back that they were unable to find one, in which case they will not charge you.
If you can't find one, you can check eBay or Wal-Mart and other stores to see if they have a Rubbermaid or Nordic Ware (NordicWare) wind-up turntable like this "Micro-Go-Round". (I've seen them at Wal-Mart).
In some cases, two microwave-safe plates can serve as a makeshift replacement for a missing tray. You have to find a saucer that fits securely on your turntable support, though. I've attached a photo of that, too.
Good luck.
We're happy to help and we appreciate your thoughtful rating of our answer.
2helpful
Broken Glass tray
That model number isn't showing up. Could you confirm that?
Then I'll see if anything is still available for it.
Otherwise, here are two suggestions:
You place a microwave-safe saucer upside-down on the roller assembly (if equipped) and then put a microwave-safe plate right-side up on top of the saucer. You can also use another glass turntable tray that doesn't fit instead of the plate.
Be sure both are centered, checking them frequently to be sure shifting does not occur. Otherwise, a spill of hot material could result.
Another option is to check eBay or Wal-Mart and other stores to see if they have a Rubbermaid or Nordic Ware (NordicWare) wind-up turntable like this "Micro-Go-Round".
2helpful
4answers
Rotating ring/ Glide tray comes off the track -Elite Model 80803
Take your round glass tray and plastic three wheeled hoop to a local Sears store, open up the microwaves on display, find the one that is still using something similar, deftly trade out yours for theirs. The new wheeled plastic hoop wheels are slightly bigger and the glass tray raised guides are a bit longer, since the switch no problems like I had. Don't get caught. They do not have those parts for sale at the local Sears store.
1helpful
3answers
Kenmore elite 721.80833 microwave
I purchased a later model glass tray which was redesigned and now it works fine.Just take your tray to the store and compare it to a newer one and you will see the difference.
2answers
Turnaround glass tray problem
Sometimes they get heated up and bend up in the middle so they don't make good contact with the coupler. The way I fix this is to heat the support over a stove flame, then place a heavy weight on it so it holds the legs up in place a bit until it cools. Here it is step by step: 1. Apply heat at points where each legs meet the hub (stove flame) 2. Place end of each leg on an object so that the bottom of the hub is held up about 1/8" off the work surface. 3. Place heavy object on hub so the bottom touches the work surface. 4. Let it cool. 5. Test it. 6. If it still does not work, increase the height of objects in step two. See: http://207.234.249.73/mwd/turntable_support_fix.gif
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
