Question about HP PSC 1410 All-In-One InkJet Printer
My hp psc1400 pretends to print
My printer pretends to print but returns me clean sheets of paper even if it's an office doc
    Problem Solver:
  • 5 Answers
Then there might not be ink in the cartridge. put a new one and u can continue printing
Posted on Nov 16, 2007
Why doesn't paper feed from the tray to print?
There's a chance that the pick up roller has a lot of paper dust on it. You can get cleaning paper from an office supply. It is sticky on both sides of the sheet. You run it through several times to clean all the rollers on the printer.
Mar 05, 2016 | HP Officejet Pro 8610 Wireless All-in-One...
Why does my hp laserjet 1020 keep printing 4 blanks after each printed sheet? HELP!
My solution already posted in FIXYA.. for the same complaint earlier.pl go through..
http://www.fixya.com/support/t10478324-printer_taking_two
You need to clean the paper pick up solenoid located at down right side ...gently remove & clean it as shown..best of luck..
Aug 20, 2014 | HP LaserJet 1020 Printer
Hp printer won't print mac word doc
I wonder whether the Word Doc SDK I am testing these days can help with the related programs?
How to Get Started with VB NET Word
May 01, 2012 | HP Officejet 6500 AllInOne InkJet Printer
HP Officejet 4215v All-in-One paper jam
MOST LIKELY THE PRINTER IS WORN OUT MAKE SURE YOU CHECK THE BACK OF THE PRINTER FOR A CHAMBER THAT YOU CAN REMOVE TO SEE IF THERE IS PARTS OF A PAPER STUCK INSIDE THERE
Feb 12, 2018 | HP Officejet 4215v All-in-One Printer
I have a laser printer 8150n. when i gives 20 print on it. on sheet print after another sheet vacant and third print fourth sheet vacant.. what is the reason
Might be page size mis match> Check paper size in system as well as in printer.> Remove tray &check for paper size.> Clean paper path sensors.
Dec 18, 2011 | HP LaserJet 8150n Printer
My HP 2600n printer always jams if there is more than one sheet in the paper tray. If there is only one sheet in the tray, it never jams but if there is more than one sheet, the first prints and while its...
Hello ,
The pad of solinoied become teared & only gum left on solenoied by which on the paper picking proces it fix on the base,by which the picking rooler continious mooves & pick another paper & become jam.so clean that path & remove the gum & paste the tape .your problem will be resolved 100%.
jm
Sep 07, 2011 | HP Color LaserJet 2600n Printer
My Brother HL-5740 Is jamming after every print jog. It's pulling two sheets through, the first sheet with the print job and the second sheet clear, Its like every job has two sheets. The second sheet...
You probably need to clean the paper pickup roller above the paper tray. A clean cloth dipped in diluted kitchen detergent and a couple of drops of alcohol, will clean the rubber rollers. Stroke the cleaning cloth firmly from side to side all the way around all the rollers. Also clean the paper separation shoe (rubber pad) at the front of the paper tray. The last thing is to make sure your paper is dry. Damp paper sticks together
Oct 16, 2017 | Brother HL 5140 Laser Printer
Jamming paper
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Dec 30, 2008 | HP Photosmart C6180 All-In-One InkJet...
Hp photosmart 2410xi - paper won't feed properly through, jam
Go to an office supply store and pickup printer cleaning sheets. They are sticky on both sides. You run a sheet through it a couple of times to remove paper dust from the rollers. The pickup roller is so slick it is drawing in more that one sheet of paper. Cleaning the rollers and the paper path will solve your problem.
Mar 18, 2017 | HP PSC 2410 All-In-One InkJet Printer
ADF will only feed one sheet then stop
no,just try to clean the roller of the ADF at the same time the separator pad.make sure that you are using paper that is 24lb weight coz if you are using paper that is so thin if may cause also an issue that the ADF could not pick-up...if the issue is still occuring return/replaced the printer...
send feedback for further troubleshooting...
Aug 23, 2008 | HP Officejet 6310 All-In-One InkJet...
HP PSC 1410 All-In-One InkJet Printer Logo
90 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
