Question about HP PSC 2175 All-In-One InkJet Printer
The printer says press enter to align cartridges. When you press enter it starts the alignment process but cancels the process after about 20 seconds. Then it repeats the message to press enter to align the cartridges. Would it cancel the process if the color cartridge was empty? When it asks to do the alignment I can't scan or copy anything.
Press the 'setup' and 'options' buttons at same time to override problem
Posted on Jul 22, 2009
ENTER FOR ALLIGNMENT CANCELLED
it is not finding a certain color
You must replace ALL ink cartridges for a sucessful alignment.
Jul 28, 2009 | HP PSC 2210 All-In-One InkJet Printer
Hp all in one printer - printer head alignment problem
Try pressing the reset or off button for a few seconds. Failing that, unplug the printer for 15 min. Let me know if it works, if not, then I will guide you through other steps.
Nov 04, 2007 | HP PSC 2210 All-In-One InkJet Printer
HP 2210, screen says to press enter to aling cartridges
Once you replace a cartridge on a 2210 ya page prints and you must put that page on the scanner window and then press enter. Your computer will go through a calibration to align the print head. once this is done you can throw away the paper and printing will be normal
May 27, 2009 | HP PSC 2210 All-In-One InkJet Printer
Printer keeps showing : Press enter to align cartridges. After doing this it then prints out an alignment page and shows: Alignment failed please: Press enter Alignment failed. This goes on and on. I have...
I have found that if I put in an old aligned page the printer reads it as and the alignment is accepted. As for the cancelled message being in the window, I have had this problem too. I've ignored it and selected the copy button and it took the command. The only problem with hitting cancel is that you cannot turn off your printer. Every time you do you have to repeat the aligning and cancellation process.
May 02, 2009 | HP Officejet 5610 All-In-One InkJet...
Cartridge alignment
Put a teeny tiny bit of oil (3 in one on fingertip) all over the slide (chrome bar that you see looking into the printer from the front) and retry. Just a thin film, NOT enough to drip.
The self test and align 'scan and print' procedure is timing out.
Mar 27, 2009 | HP PSC 2175 All-In-One InkJet Printer
Keep getting message Press Enter to Align Cartridges
after each alignment you press enter key or start key not cancel key,
Dec 12, 2008 | HP PSC 2175 All-In-One InkJet Printer
Actually for a HP deskjet 990cxi
Alignment:
1. Turn on the HP DeskJet.
2. Disconnect the USB cable from the all-in-one.
3. Press the sequence of front panel buttons below to start the print cartridge alignment process.
The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
1. Press and hold Cancel .
2. While holding Cancel , press On .
3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
4. Press Cancel again.
5. Press Copies .
6. Press Paper Type .
7. Press Color Start Copy .
The alignment page will begin printing.
If the alignment page does not print, repeat the button-press sequence in this step.
4. When the alignment page has printed, place the page face down on the scanner glass and press Scan .
The alignment is complete when the On light stops blinking.
5. Reconnect the USB cable.
Jun 03, 2008 | HP DeskJet 940c InkJet Printer
Aligning printer after new ink cartridge inserted
SOLUTION: Start the cartridge alignment by performing a series of button presses from the front panel of the product.
  • HP PSC 1200 and 1300 series:
    1. Turn on the HP PSC 1200 or 1300 series product.
    3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
      5. Press Copies .
      7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
    4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
CAUSE: This can occur if the cartridge alignment is canceled or times out without a valid print cartridge alignment stored in memory.
Oct 29, 2007 | HP PSC 1350v All-In-One InkJet Printer
HP PSC 2175 All-In-One InkJet Printer Logo
343 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
