On
Press the ON/OFF SLEEP/WAKE button until apple logo appears
Off
Press ON/OFF SLEEP/WAKE button until red slider appears, slide you finger across to turn off. http://www.everymac.com/systems/apple/ipod/ipod-troubleshooting-repair-faq/ipod-touch-how-to-reboot-restart-frozen-hung-force-quit-apps.html
SOURCE: i can't open my yahoo messenger from my apple ipod touch
try to get a free app from the app store and install it the may solve ur problem
SOURCE: ipod touch can not boot.It show apple logo
Hope u have back-up...Do a reset..soft one ....
hope it helps...keep the hope:)
SOURCE: apple sign appears when I turn IPOD touch on.
plug it into the computer it is paired with and restore it. Your files should have already been backed up.
SOURCE: ipod touch disabled
If you repeatedly enter the wrong passcode, iPhone or iPod touch
will be disabled for longer intervals, before you can try again. After
too many unsuccessful attempts, you won't be able to try again until
you connect to the computer you normally sync with. Note that starting
with iPhone 2.1 software, there is a setting to cause the device to
erase itself after 10 consecutive incorrect password attempts. This
setting is off by default. It can be turned on by tapping Settings > General > Passcode Lock after you enter a correct passcode.
If you cannot remember the passcode, you will need to restore your
device on the computer that was used to originally sync the iPhone or
iPod touch so that you can reset your passcode and resync the data from
the device (or restore from a backup). If you restore on a different
computer that was never synced to the iPhone or iPod touch, you will be
able to unlock the device for use and remove the passcode but your data
will not be present.
SOURCE: ipod touch freezes at the apple logo
mine did the same thing. plug it into the computer. when it's open in iTunes, set the iPod to manual. sometimes when it's automatic, it'll clear itself out/freeze up until you plug it in again. this worked for me. it could be a glich, or their way of getting us to go onto iTunes more often.
To restart iPod touch, first turn iPod touch off by pressing and holding the Sleep/Wake button until a red slider appears. Slide your finger across the slider and iPod touch will turn off after a few moments.
Next, turn iPod touch on by pressing and holding the Sleep/Wake button until the Apple logo appears.
Is iPod touch not responding? To reset iPod touch, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds, until the Apple logo appears.
If your device does not turn on or displays a red battery icon, try recharging next.
To set a minimum font size for messages:
Choose "Mail, Contacts, Calendars" > Minimum Font Size, then choose Small, Medium, Large, Extra Large, or Giant.
Also, you may need to try the following:
Restarting and Resetting iPod touch
If something isn't working right, restarting, force quitting an application, or resetting iPod touch will likely solve the problem.
Restart iPod touch: Press and hold the Sleep/Wake button until the red slider appears.
Slide your finger across the slider to turn off iPod touch. To turn iPod touch back on, press and hold the Sleep/Wake until the Apple logo appears.
If you can't turn off iPod touch or if the problem continues, you may need to reset. A
reset should be done only if turning iPod touch off and on doesn't resolve the problem.
Force quit an application: Press and hold the Sleep/Wake button on top of iPod touch
for a few seconds until a red slider appears, and then press and hold the Home button
until the application quits.
Reset iPod touch: Press and hold the Sleep/Wake button and the Home button at the
same time for at least ten seconds, until the Apple logo appears.
This information was sourced from the iPod Touch official user guide at:
http://manuals.info.apple.com/en_US/iPod_touch_3.0_User_Guide.pdf
Hope this helps.
Best regards,
CellPhBuddy.
