Replaced the battery
The battery light is for the charging system , battery not being charged ! Alternator may have brushes going bad or a diode ! Or lose wiring . ABS light could be coming on because of low power (VOLTAGE) Control modules don't like low voltage . I suggest you take an have it tested !
If the diode/s are going bad in the alternator that can send false codes through the ABS setting a code for that .
SOURCE: Grand Prix wont start
Try checking the starter solenoid wires.Make sure the wire hasnt come loose and the battery to solenoid cable is tight.
SOURCE: all of a sudden wont go forward or rev .
Hello, The first thing to check is the transmission fluid level. When you check the fluid does it have a burnt smell? If so, you probably have an internal failure. Have you had the transmission serviced? Your trans filter may be stopped up.
I hope this helps.
CYA, Gator241
SOURCE: Battery and ABS light coming on
There is a part on the engine called the "Alternator", the alternator is what charges up the battery and supplies the power to the cars electrical system when the engine is running, when the voltage output of the Alternator is to low it causes the Battery warning light in the dash display to come on (to alert you of a problem in the charging system), the low voltage from the alternator also is what is causing the ABS warning to come most likely. So at this point you will need some basic testing done to determine the cause of the low voltage, this can be the alternator is defective (most likely reason) or other things like wiring issues to the alternator.
